Removing the A on the trunk lid
Old Apr 9, 2011 | 03:25 PM
Tom Champagne's Avatar
My A logo is starting to pit after 7 Michigan winters and would like to get a new one. I've removed the trunk lining and see the 2 plastic push pins the hold the emblem on the trunk lid,but I don't know how to push them thru(out)to remove the emblem. You'd think Acura would put some kind of hole directly behind the emblem so you could tap them out with a punch or similar tool. Any help is greatly appreciated.
Old Apr 9, 2011 | 03:29 PM
Bearcat94's Avatar
AZ Community Team
Check these:
E-016: DIY: Emblems and badges-removing and replacing
https://acurazine.com/forums/car-parts-sale-361/cl-body-kit-85353/
https://acurazine.com/forums/showthread.php?t=121019 (with scans for locations of emblems)
https://acurazine.com/forums/showthread.php?t=122040 (from 2G TL)
Old Apr 9, 2011 | 03:52 PM
I guess I have to try and remove from outside the trunk lid?? Are the clips attached to the push pins? Does anew emblem come with new clips?. I still have to order a new A so I've got some time. Thanks for the reply...but I'm more confused after reading those posts. Sounds like not many people have done this.
Old Apr 9, 2011 | 04:16 PM
Bearcat94's Avatar
AZ Community Team
New emblem (the decklid "A") does not come with clips. Just the emblem with the pins and pre-attatched 2-sided tape.
I've thought about doing mine black, but have never removed/replaced it, so I can't say for sure how it works.
I've got another link that might help. brb.
Here, see if this helps: https://acurazine.com/forums/showpos...0&postcount=12
Old Apr 9, 2011 | 04:58 PM
Jesstzn's Avatar
I have had mine off prolly 6 times.
Just saw it off with fishing line or dental floss . Clean up the rest with Goo Gone.
Old Apr 9, 2011 | 05:11 PM
Thanks Bearcat...that link helps out much better. I did order new clips for the pins as well.
Old Apr 9, 2011 | 05:13 PM
Do I take it that you still reuse the clips on the push pins? or just the double-sided tape. I thought that they would break on removal.
Old Apr 9, 2011 | 05:14 PM
Jesstzn's Avatar
The clips are like guides to hold it in place and align it ..I have used the same ones over and over.
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Desert Ridge
Sep 27, 2015 02:37 PM
STL TL-S
Sep 23, 2015 08:52 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
