Removing the A on the trunk lid
My A logo is starting to pit after 7 Michigan winters and would like to get a new one. I've removed the trunk lining and see the 2 plastic push pins the hold the emblem on the trunk lid,but I don't know how to push them thru(out)to remove the emblem. You'd think Acura would put some kind of hole directly behind the emblem so you could tap them out with a punch or similar tool. Any help is greatly appreciated.
Check these:
E-016: DIY: Emblems and badges-removing and replacing
https://acurazine.com/forums/car-parts-sale-361/cl-body-kit-85353/
https://acurazine.com/forums/showthread.php?t=121019 (with scans for locations of emblems)
https://acurazine.com/forums/showthread.php?t=122040 (from 2G TL)
I guess I have to try and remove from outside the trunk lid?? Are the clips attached to the push pins? Does anew emblem come with new clips?. I still have to order a new A so I've got some time. Thanks for the reply...but I'm more confused after reading those posts. Sounds like not many people have done this.
New emblem (the decklid "A") does not come with clips. Just the emblem with the pins and pre-attatched 2-sided tape.
I've thought about doing mine black, but have never removed/replaced it, so I can't say for sure how it works.
I've got another link that might help. brb.
Here, see if this helps: https://acurazine.com/forums/showpos...0&postcount=12
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
STL TL-S
Sep 23, 2015 08:52 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
