removing pinstriping
Old Apr 30, 2008 | 08:31 PM
MaCe's Avatar
fellow MASShole
I have a royal blue 04 and absolutely love the car .. but is has a pinstripe down the side of the car .. i have never scene another TL with a pinstripe and its really starting to bother me ..
how could i get rid of it without having to repaint the whole car?? is it even possible ?
i'll try to take some pics tomorrow in the daylite
thanks
MaCe
Old Apr 30, 2008 | 08:33 PM
VQPower37's Avatar
heat it up, pull it off
Old Apr 30, 2008 | 08:45 PM
MaCe's Avatar
fellow MASShole
think its painted
Old Apr 30, 2008 | 08:59 PM
Bearcat94's Avatar
AZ Community Team
Could be, but a lot them get pin-stripped at the dealer with decals/stickers.
Old Apr 30, 2008 | 09:21 PM
MaCe's Avatar
fellow MASShole
i'll have to check if its painted or not ... so basically a hair dryer and some carefull pulling should get it off it its a decal ??
Old Apr 30, 2008 | 09:31 PM
Jesstzn's Avatar
Exactly ... thats if its a decal. Pull at a radical angle .. like 135 degrees etc as you apply the heat .. don't get the paint to hot not to thermal stress it.
If you have any adhesive residue left over us Goo Gone to remove it .. be patient and let it do its job .. if you start rubbing too hard you may mar the area.
If its painted on stop at a body shop they will tell you what to use. Don't try outguessing or use advise from here on that side of it as some things that will remove a painted stripe may also not be clear coat friendly.
Old Apr 30, 2008 | 09:55 PM
blueninja36695's Avatar
06 RBP non navi
I have pinstripe on my 2006 RBP
Old Apr 30, 2008 | 11:04 PM
MWalsh9152's Avatar
all work and no play
its rare that you will see the pinstriping painted on coming from the dealer....though for the price they charge you would think its gold leaf! My 08 came with it I couldnt get it off fast enough
just do what Jess said if its a decal and you will be fine....may need to have it buffed though as the lines might still be visable due to fade
Old May 1, 2008 | 09:10 AM
LoveMyTL-S's Avatar
You may want to post this up in the Wash and Wax section. I'm sure the detailers in there may have some good advice. Good luck with the removal.
Old May 1, 2008 | 09:13 AM
TeknoKing's Avatar
once removed, buff the car, wax it.
I never understood the beauty of the stripe
Old May 1, 2008 | 10:24 AM
mikehenryjr's Avatar
You could also wait for a hot day an let the car sit in the sun. If they are a vinyl sticker they should peel right off. The paint under them will most likey be a little different shade. But if you wax and after a while in the sun they should not be noticeable.
Old May 1, 2008 | 11:55 AM
MWalsh9152's Avatar
Jesstzn who posted a few above is one of the detailers that gives a huge amount of support in the wash and wax section
Old May 1, 2008 | 01:23 PM
theklassic's Avatar
Another member recently PM'd me this same question, here's what our senior shop guy relayed to me:
Originally Posted by theklassic
C,
I just got word from my guy that he can do it. But he also told me that it's something you can usually take off yourself rather easily and cheapily. He said if you have a heatgun (or blow dryer) you can just heat it for a few seconds and start peeling.
If it's painted on then you'll need a body shop to rub it down with a special bit. Other wise if it isn't coming off easily we can have it done at our shop.
Hit me up if you're having trouble with it.
I reccommend you give a shot first before dropping any cash needlessly on it. Hit me back and let me know how it goes.
Thanks!
Collin
Old May 1, 2008 | 01:28 PM
flydog's Avatar
If it is painted on use laquer thinner or acetone. It will not harm the paint, but most painted-on pinstripes will come right off. I used this on a BMW I once owned. Do not use regular paint thinner because it evaporates too quickly.
Another way to take it off is to apply fineline tape along the top and bottom edges and then wetsand it off with 2000 grit. That will be more work and you will have to compound the entire side panel to blend it when you are done. However, you could lightly go over it with 2000 grit and then remove most of it with laquer thinner, which will make it go quicker.
Old May 2, 2008 | 03:23 PM
MaCe's Avatar
fellow MASShole
its def painted on .. i got up close on personal with a razor blade to try and start an edge to peel it up .. and it started to chip off ...
Old May 2, 2008 | 03:42 PM
Bearcat94's Avatar
AZ Community Team
Ouch. That sucks man.
Although, this may or may not apply to the OP, it is something to think about when buying a car.
If you're buying the car from a dealer, especially if new, before you take delivery of the car, tell them to take stuff like pinstripes and dealer stickers off.
It's no big deal, they do it all the time.
Both Acura's I've bought, I told the dealer, "No pin stripe, no dealer sticker, no mud guards". They were removed, no problem, before we showed up to sign the papers.
Old May 4, 2008 | 09:04 PM
MaCe's Avatar
fellow MASShole
so basically my options are to talk to a detailer?
Old May 4, 2008 | 09:13 PM
MWalsh9152's Avatar
if you arent comfortable with wetsanding and buffing then it is probably your safest bet....where in Ma are you?
Old May 4, 2008 | 09:40 PM
MaCe's Avatar
fellow MASShole
western mass ... springfield area
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
