Removing LCA Ball Joint trick
Old 11-17-2018, 07:50 AM
VictorTL's Avatar
Does the socket wedging trick will work to remove the ballpoint from the LCA?
Old 11-18-2018, 11:06 PM
Ashleyroachclip's Avatar
6 pound hammer , smack the spindle at the ball joint , it will come out .
do not strike the ball joint itself .
Old 11-19-2018, 10:45 AM
VictorTL's Avatar
i just read some where on this thread that either method will likely pop out the sleeve on the LCA
Old 11-19-2018, 12:15 PM
Received 8,691 Likes on 6,705 Posts
https://www.google.com/search?q=remo...hrome&ie=UTF-8
Old 11-19-2018, 01:33 PM
VictorTL's Avatar
thamks. So these are the recommended tools
Old 11-19-2018, 01:36 PM
losiglow's Avatar
My "method" consisted of a 4lb. sledge for about 30 minutes. My triceps were mighty sore the next day.
Old 11-19-2018, 06:44 PM
t-rd's Avatar
I wedge a craftsman wrench's handle in between the knuckle and the LCA while it's supported on a hydraulic jack with the space there. Then I drop the jack fast, and KICK DOWN on the rotor's top edge HARD, WITH YOUR FOOT. Pop it goes. It actually works, and no damage to the ball joint.
nisif
07-04-2023 08:45 AM
EagleEye
04-04-2015 04:49 PM
jdm_BOB
09-10-2012 07:35 AM
MOBB
06-19-2012 03:19 PM
Carmodifier
06-29-2010 02:18 PM
Quick Reply: Removing LCA Ball Joint trick
