Remote start and with 6MT
Old Aug 10, 2006 | 06:32 PM
rimike's Avatar
I might be buying an 06 TL 6MT soon. I want to have a remote start installed. Has anyone added a good quality "stand alone" remote starter that could be triggered by the OEM fob? If so which one? How is the range on the OEM fob? Exactly what is the process you go through when you stop the car, park it, get out and shut the car off with the remote?
Old Aug 10, 2006 | 06:58 PM
holybear's Avatar
B A N N E D
I am intrested also in this too.
Old Aug 10, 2006 | 07:21 PM
bklynpanman's Avatar
321 whp SAE
get compustar.. have to use they're remote.. when the car is on and in park.. pull up emergency break... pull out key.. car stays on.. open door.. shut door- car turns itself off.. now you can remote start
Old Aug 10, 2006 | 07:24 PM
rimike's Avatar
We`re talking 6 speed here, so you mean put it in neutral, pull parking brake up.......
Old Aug 10, 2006 | 07:50 PM
Laxplaya11385's Avatar
isn't that dangerous? Cause, what if you're on a hill, and you remote start the car. The e-brake isn't going to stop the car from rolling down unless the incline is less than a certain degree. Unless you can remote start it while the car is in 1st gear, but then wouldn't it just stall?
Old Aug 10, 2006 | 08:12 PM
chfields's Avatar
I don't think you can have remote start with manual tranny.....
Old Aug 10, 2006 | 08:20 PM
xRivalNightTimeTL's Avatar
Yea, you can put a remote starter in a manual transmission car. My friend has it in his Scion tC
Old Aug 10, 2006 | 08:25 PM
rimike's Avatar
Yes you can, the alarm brain knows the car is in neutral because you got out of it and it`s still running.
Old Aug 10, 2006 | 08:39 PM
havokgroup's Avatar
This is possible. It's about the installation. I know alot of shop won't do it due to the risk of someone leaving it in gear and it gets remote started.
I have a remote system on my EK hatch that's a manual and it works fine
Old Aug 10, 2006 | 08:57 PM
rced's Avatar
Please don't quote me on this, but I think they (the installers) use a magnetic switch. For example when the car is in neutral the magnetic switch completes the circuit and the car starts. In any of the gears the circuit is broken and no start.
Let us know how you make out.
Old Aug 10, 2006 | 09:01 PM
HEK's Avatar
HEK
Team Nighthawk Mambo King
How would you by-pass the clutch, meaning you have to have it "pressed" while you turn the key either in neutral or in gear...I wouldn't want that safety feature dissabled...
Old Aug 10, 2006 | 09:28 PM
there was someone on the TSX forum that had a remote starter installed in his 6 spd, and a valet used the remote start and the car went crashing into something. Messed the driver side panel and the front wheel pretty badly.
Old Aug 10, 2006 | 09:33 PM
randomthought's Avatar
rebmeM deretsigeR
^^ I remember that. Did q
Old Aug 10, 2006 | 09:36 PM
rebmeM deretsigeR
^^ i remember that. Did quite a bit of damage i think. Remote start on a manaul is dangerous and I would not recommended it. I would rather have the ability to park while in gear rather than having remote start. There might be some info on a remote started floating somewhere around here.
Old Aug 10, 2006 | 09:52 PM
chfields's Avatar
I would think it would be dangerous, since you would have to disable the clutch being engaged to start. I don't see why you would need remote start, is it that hard to turn the key???
Old Aug 10, 2006 | 11:11 PM
Kikaida's Avatar
My friend had a remote start on his SHO with a manual transmission. He always left the car in neutral with the e-brake on.
One day, he took it in to the shop. While picking it up, he did the remote start and started signing his paperwork. The car was left in gear by the repairman, and every time the starter turned over the motor, the car lurched forward. It ended up hitting another car in the lot, but luckily the damage was fairly minimal.
After that experience, he took apart his shifter and put magnetic switches (the type used to detect open windows and doors for home burgler alarms) so it would detect if the car was in gear. If I remember correctly, he had to put in several sensors as it was not designed to detect neutral, it was detecting if the shifter was in gear.
Old Aug 10, 2006 | 11:38 PM
chfields's Avatar
Doesn't that seem like an awful lot of time and effort, just so you don't have to turn the key?
Old Aug 10, 2006 | 11:48 PM
coykiam's Avatar
Is this really possible for the TL ? I just got my 06' Auto TL and the dealer told me that they cant put a remote start because of the Navi and all that other BS....is this true? anyone with auto TL that has remote start ?
Old Aug 11, 2006 | 12:00 AM
Kikaida's Avatar
You still have to turn the key. I have remote start on my TL (Auto), and if I do not put the key in, the engine will kill if the brake or gas pedal is pressed. Also, it the key were not put in, the steering would be locked (and probably the shifter too since it is an auto).
Here in Hawaii, it is pretty warm all year round. Remote starting lets me cool the car a little with the air conditioner. For you cold climate ppl, you could warm up the car with the heater.
That and I like to warm up the engine a little before I take off.
coykiam: I can't think of any reason the NAV would be adversely affected... I could not tell you though as I do not have NAV
Old Aug 11, 2006 | 08:58 AM
DeadLock's Avatar
Forced Induction
I had the compustat on a 5spd integra, it worked great, a bit pricey, but it had the FM trasmitter.....but I wouldnt want to lose the OEM remote for some reason.
They can retrofit stuff into the OEM remotes, but I don't know if those systems are 6spd safe.
Old Aug 11, 2006 | 09:04 AM
321 whp SAE
People it is failsafe!! With the sequence that has to be followed, it is impossible to remote start the car while in gear. Car has to be in neutral, running, pull e-brake.. remove key, car stays on then when the door shuts, the car shuts off and it is ready. if you then unlock the doors, the sequence is cancelled and you have to go through it again.
Old Aug 11, 2006 | 09:41 AM
CUNextTuesday's Avatar
A friend of mine has a manual transmission Nissan Xterra. He was looking to get remote start installed and the shop he goes to told him they won't put them on manual transmission cars anymore cause they had one start and just take off going forward :-/
Old Aug 11, 2006 | 10:25 AM
TranTL's Avatar
CompuStar was the first to create a remote start that is safe for a manual transmission. Now if I were to park my car on a hill...I would't want to remotely start it to begin with. Everything that the compustar does to make it safe is all in the Brain. I would only have the compustar installed by a certified compustar installer. It is spendy but wait till you see all the features it has to offer.
www.compustar.org
Old Aug 11, 2006 | 10:39 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
I had a clifford alarm w/ remote start on an old car that was a manual transmission. The alarm was specifically for manual vehicles. Basically, when you're exiting the vehicle, you have to press a specific button on the remote while the key is still in the ignition (and the car is still running). When you press the button to activate the remote start, the system checks wheter or not you have the vehicle in nuetral and the e-brake on. When it runs the check and everything is good-to-go, you can remove the key off the ignition and the vehicle remains on (similar to a turbo timer). Once you exit the vehicle and activate the alarm, the car will shut off. As an added safety feature, if the alarm is triggered while parked... the vehicle will NOT remote start. I had the alarm for over 3 years and I NEVER HAD A PROBLEM. Like everyone else stated above... IT'S GOING TO COST YOU....
Old Aug 11, 2006 | 02:54 PM
burnurass's Avatar
7th Gear
I have remote start on my 03 Maxima 6speed. Have to leave it in neutral of course..but my car has a built in neutral safety switch....so it WILL NOT start in gear EVER. Maybe you guys have it too and you just don't know? FSM anyone?
Old Aug 11, 2006 | 08:54 PM
ubnpast's Avatar
to bypass the clutch you need to cut the 2 wires on the clutch pedal switch and splice them together. I had an UltraStart alarm on my 93 5 speed integra, and when I sold it I switched it into my 3000gt vr4. This is an excellent alarm, and the model I had was the fm frequency which worked and paged you from A TRUE 1 Mile Radius. Check them out here: http://www.ultrastarters.com/
Old Aug 11, 2006 | 09:30 PM
JERU's Avatar
Man just does no seem like it is worth the effort. No matter what happens and who does the work, if you have a warranty issue I can't imagine them being cool with safeties being jumped. Its basically a modded car. Unless you live in Texas, parking on hills are a fact of life and that e-brake is not a guarantee. Get the Auto and call it a day....
Old Aug 12, 2006 | 06:25 AM
rimike's Avatar
The 6 speed is more fun.
What is range like with the oem remote?
Old Aug 12, 2006 | 07:06 AM
JERU's Avatar
Horrible. I had a 96 Maxima whose remote could work the car from half way across the state. Acura is the opposite. You have to get so close to the damn car, you might as well use the key
The range is below average from my experience with other companies like Jeep, Ford and Nissan.
Old Aug 25, 2006 | 09:13 PM
rimike's Avatar
Bump! I bought the 6 speed.
Old Aug 30, 2006 | 12:40 AM
ubnpast's Avatar
the car or alarm?
oyayjoe
Jan 1, 2019 10:17 PM
oyayjoe
Sep 12, 2015 04:40 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
