rattle
Old Aug 14, 2004 | 03:31 PM
jayz3000's Avatar
rattle
Does anyone else have a damn rattle issue in the shifter or cupholder or something. cause everytime i brake it rattle or hit a bump and i cannot take it anymore... i can hear it over my radio that how annoying it is gettin but please hit me up with some feedback....
george
Old Aug 14, 2004 | 09:00 PM
Tedanddenise's Avatar
Does it only happen with the moonroof in the vent position - if so, I have fixed mine and can share.
Old Aug 14, 2004 | 09:44 PM
yard7man's Avatar
Yes I have a rattle in the center council and it is comming from the bottom storage compartment door
Try opening them both door up it should go away
Old Aug 15, 2004 | 12:26 AM
gregory28_RENAMED's Avatar
Dealer can fix it for you. I had a rattle in my dash which I noticed the night I drove my brand new TL home. It was a loose bolt that was causing the rattle. They fixed it very quickly for me the next day.
greg
Old Aug 15, 2004 | 06:47 AM
bigira's Avatar
9th Gear
I have 5 rattles in my car. One of them is in the cupholder, 3 in the dash, and one over near the passenger side rear door. The dealer has had it 4 times and never gets rid of them. I too am frustrated.
Old Aug 15, 2004 | 09:50 AM
architect55's Avatar
Team Anthracite Member
How did you fix it? I have this rattle too...took it to the dealer and they said they heard it but couldn't find where it was coming from. Thanks.
Old Aug 15, 2004 | 02:42 PM
jayz3000's Avatar
yea my is def. comin from the damn annoying cupholder..lol it makes me just wanna rip it right out and say... foget abouttttt it
Old Aug 16, 2004 | 01:34 AM
da_illist_onE's Avatar
Acurazine Addict
Got the exact same problem here.
Old Aug 16, 2004 | 01:53 AM
DC5_Integra's Avatar
Team Nighthawk Water Boy
I hear a rattle coming out from the console.. but i havent' quite figured out where it is..
Old Aug 16, 2004 | 07:24 AM
Vent rattle fix
My only rattle was occuring ONLY when the moonroof was in the VENT position - a hard bump on the road would cause it. If I hit the headliner in front of the moonroof with my hand, I could replicate the rattle. One of the threads suggested the air deflector may be the culprit (it is!) - the cause = when the moonroof is in the vent position, the air deflector is VERY close to the metallic roof of the car and its attachment is a bit flexible; a bump causes the air deflector to hit the metallic roof of the TL, thus causing the miserable rattle. My fix (which actually works) is to cut 3 strips of the soft part of Velcro (approx. 3/4" x 3") and attach them to the metallic roof of the TL exactly underneath the TL's air deflector (position them when the moonroof is in the full open position). Here are 2 pictures of what my installation looks like. View 1 and View 2. Hope this helps.
Old Aug 16, 2004 | 07:02 PM
Thanks, I'll try this...man that rattle is annoying.
Old Aug 17, 2004 | 01:13 AM
winstrolvtec's Avatar
Anybody have a squeeky belt buckle on the driver side? Goes away in certain positioning, but highly annoying. Also have the center console rattle coming from the top compartment, doesnt happen that often at all but goes away once opened.
Old Aug 28, 2004 | 10:37 AM
psuprav's Avatar
Storage compartment door rattle
I've got the same problem, except mine is the top door. Is there a fix for this? Opening the door works, but it looks bad.
I found that if I push on the upper right part of the door, near the hinge, that stops the rattle, but driving like that is annoying
Old Aug 28, 2004 | 10:48 AM
tlzx9's Avatar
Same exact problem here. When you own a $35K car...you shouldn't have to "live" with rattles, and other annoying engineering flaws with the car. Acura should do all they can to fix them IMHO. The rattles in this car are driving me BATTY, and they don't seem to be getting better, only worse. I also hear a new one somewhere near my rear view mirror area, but cannot find the exact spot. Suggestions?
Old Aug 28, 2004 | 04:10 PM
hp1kw's Avatar
Well since this seems to be a 'general' rattle thread, I have a few I wonder if others have. First I have a rattle in the drivers door. It actually sounds more like a squeaking noise than a rattling noise. The second one I only get occasionally. The second one sounds like it is coming from the dash to the left of the instrument cluster. It seems to only make noise in the morning hours after the car has been out overnight. If someone has any insight or can offer any assistance I would appreciate it.
Old Aug 28, 2004 | 06:09 PM
willz822's Avatar
I too have a rattle coming from the center console storage door. Did anyone out here have a dealer that was able to fix this problem? It is driving me crazy and I shouldn't have to keep the storage doors open for the noise to go away.
Old Aug 28, 2004 | 07:50 PM
KawBoy's Avatar
I have one in the center console, right in the CD/NAV area. It sounds like a loose bolt or something, just like gregory28 said. I also have a rattle on the front/right speaker. Very annoying.
Old Aug 29, 2004 | 01:21 AM
tl_soso's Avatar
Blue is so so
YES, rattles galore with mine as well. Mine come from the seat belt area on both front sides as well as the console area. Grrrrrrrrrrrr GRRRRRRRRRRRRRRrrrr
marcelft
Jul 10, 2018 06:17 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
