View Poll Results: Ratchet Wrench Length
Snub
0%
Regular
50.00%
Extended
50.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Ratchet length
Old Sep 19, 2021 | 05:59 PM
Avalos0310's Avatar
4th Gear
Ratchet length
Hello TL family. I have always worked on my 2008 Acura TL with my hand powered tools but lately I've been wanting to use a battery powered ratchet wrench. My only question is: What length would be best/beneficial while working on the engine, etc? Should I get the extended, snub or regular? Thank you for your ideas.
Old Sep 19, 2021 | 06:15 PM
peter6's Avatar
If you want to wrench on small stuff, get the M12 1/4 2456 ratchet. Together with 1/4 sockets (and swivel sockets like
this one this one
) you will be able to get to most annoying bolts and is small enough to fit into tight places. Like for example taking all those 10mm M6 bolts that hold timing covers is a breeze with this tool (well except for like 2 of them on TL if memory serves right).
There are cheaper alternatives available but I never used them.
Old Sep 21, 2021 | 10:17 AM
Legend2TL's Avatar
AZ Community Team
FWIW, this is the 3/8" power ratchet I use from China
https://www.banggood.com/3-or-8-inch...1&rmmds=search
Makes getting the timing belt cover bolts off so much easier, it cuts the time from ~15 minutes with a 1/4" or 3/8" hand ratchet down to ~3minutes for those bolts alone.
Old Sep 21, 2021 | 10:24 AM
Originally Posted by peter6
If you want to wrench on small stuff, get the M12 1/4 2456 ratchet. Together with 1/4 sockets (and swivel sockets like this one) you will be able to get to most annoying bolts and is small enough to fit into tight places. Like for example taking all those 10mm M6 bolts that hold timing covers is a breeze with this tool (well except for like 2 of them on TL if memory serves right).
I have the 3/8" version of this but want to pick up the 1/4" extended reach ratchet to complement it. I find that sometimes, it's not long enough and the 1/4" extended will give me the flexibility i need.
Old Sep 21, 2021 | 01:07 PM
Avalos0310's Avatar
4th Gear
is there much of a difference in size between the 1/4 and the 3/4 ratchet?
Old Sep 21, 2021 | 07:01 PM
peter6's Avatar
For Milwaukee I believe head is the same size, but most 1/4 drive sockets are shorter than 3/8 versions.
Old Sep 22, 2021 | 02:27 PM
Avalos0310's Avatar
4th Gear
hmm... I wonder if the body is similar in size. I just don't want to buy 2 different sizes. But, if I have too, I will..
Old Sep 22, 2021 | 03:36 PM
go to a home depot and compare them in person
KMcPeak
Sep 6, 2021 05:46 PM
Honeysuckle143
Jul 15, 2019 04:59 PM
mashina2010
Jul 8, 2013 06:30 AM
niner
1G RDX Problems & Fixes
Jun 9, 2009 10:00 PM
