The quietest starter?
Old Nov 27, 2012 | 09:39 PM
  #41
Italiano's Avatar
Old Nov 28, 2012 | 09:50 PM
  #42
kels_TL's Avatar
Op post some pics
My tl has 52k and ever since 47 it sounds like shit, when it gets warmer I'm pull the starter out and check it over. Also replacing battery this winter just in case.
Old Nov 29, 2012 | 05:01 PM
  #43
anionrings's Avatar
i remember back in the days early high school..i had to sneak my car out of the house...
what i would do is slap it on Neutral...push it down the driveway then start it away from the house...usually in the road...so my parents wont hear it.... then i be gone like the wind
quiet starter no need?... ahhh the young life
Old Dec 5, 2012 | 09:16 PM
  #44
Chad05TL's Avatar
Remove the battery and the battery shelf.
The huge pry bar is resting on the bottom starter bolt. The starter is the round aluminum looking thing with the orange label.
Old Dec 7, 2012 | 12:48 PM
  #45
I hate cars's Avatar
I remember those days. Unfortunately mine had open exhaust so we had to push it at least 1/4 mile or it would wake the parents up. Coming home was the same, kill the ignition and hopefully coast all the way to the house.
Old Dec 7, 2012 | 05:32 PM
  #46
Chad05TL's Avatar
i forgot to add, that if anyone does this starter replacement, make sure you use a torque wrench that is set properly to tighten the bolts. It's important because the bolts are screwed into an aluminum housing and if you strip those threads on that aluminum housing, it will mess you up pretty bad. And one thing I noticed was that 47 ft # was not very tight when I tightened the bolts. It was still easy to go way beyond that, and I was not using that big bar you see in the pic. My torque wrench might be half the length of that big bar you see in the pic. So, be warned. Use a torque wrench. Its very important to use one when you screw into aluminum. Aluminum is much easier to strip than iron or steel or some other harder metal.
Old Dec 7, 2012 | 06:46 PM
  #47
WhiskeyD's Avatar
Originally Posted by Italiano
Here we go again,u and your dumb ass threads
hahaha
Who cares if the starter is noisy as long as it turns over strong theres no problem... Its for starting the car and thats it. Its not like its a belt or something making noise the entire time the engine is running.
Old Dec 7, 2012 | 07:02 PM
  #48
Chad05TL's Avatar
Originally Posted by WhiskeyD
hahaha
I agree. Mine stopped starting the car... And it showed signs of age and degradation by access noise and turning slower.
You might try reading the entire post before you make a stupid comment. You and IHC and Italiano are all alike.
follow the bouncing ball son
Old Dec 7, 2012 | 08:05 PM
  #49
Chad05TL's Avatar
whiskey D, smoken a doobie.. haha
Old Dec 8, 2012 | 09:37 AM
  #50
MikeTC's Avatar
How do you remove the battery shelf? I have a 06' and I couldn't remove the shelf. I may be missing something.
Old Dec 8, 2012 | 10:01 AM
  #51
Chad05TL's Avatar
There are 2 bolts under the shelf. They screw into the side of the car. Use an extension and possibly a short swivel on the end. When ready to put back together, use something to clean the bolts and the place they screw into. Becareful when reinstalling the top screws. I threaded one bolt 1/2 way into the hole, then it decided to strip out on me. So, use a lubricant to clean the rusty holes after you have it dismantled and are ready to put it all back together. The shelf is solid as a rock, but one of my screws needs to be replaced.
Old Dec 8, 2012 | 10:16 AM
  #52
Italiano's Avatar
Chad, you wish you were half the man I Hate Cars is...He is a very knowledgeable member on AZINE on all aspects about cars....Listen and learn Jr.
Old Dec 8, 2012 | 10:50 AM
  #53
Chad05TL's Avatar
Do the world a favor and quit trolling and destroying good threads.
Either be productive or shut up.
Old Dec 8, 2012 | 12:03 PM
  #54
MikeTC's Avatar
Thanks Chad, I saw them but was not comfortable in removing them without first check with someone who done this. Thanks again.
Old Dec 8, 2012 | 12:20 PM
  #55
Chad05TL's Avatar
your welcome. =) My pleasure.
By the way, welcome to acurazine. haha As you can see, it's not always pleasant here. But its good for some things though.
Feel free to click that thanks button to the bottom right. haha
Old Dec 8, 2012 | 12:35 PM
  #56
MikeTC's Avatar
Didn't even know that button was there. Noob...
Old Dec 8, 2012 | 02:30 PM
  #57
pohljm's Avatar
Sez the guy with all sorts of questions but only (1) thank you!
Old Dec 8, 2012 | 03:55 PM
  #58
Italiano's Avatar
This thread was destroyed as soon as you put the title.... Your picture is in the dictionary under the word troll.
Old Dec 8, 2012 | 03:59 PM
  #59
Is this what you consider a good thread because it seems like a typical chad thread. A question is asked and it ends in chad knowing it all telling everyone else they're wrong. It's the same pattern with every thread. Luckily this one was started by yourself so there's really nothing to destroy. I try to look at the bright side. Now you know that sometimes a failing part can make noise or the normal noise can change as it fails. I think we all knew that already but at least it's settled now.
A good thread being destroyed would be the IAC thread that was going great with information being exchanged until you came in and started spreading tons of misinformation that had to be corrected. You didn't bother to read the thread, you just spammed it with tons of crap that had already been answered. I don't care as long as others know not to believe it but I feel bad for a noob that might not know any better.
Old Dec 8, 2012 | 06:33 PM
  #60
Italiano's Avatar
Old May 15, 2013 | 10:52 PM
  #61
Chad05TL's Avatar
Originally Posted by I hate cars
Is this what you consider a good thread because it seems like a typical chad thread. A question is asked and it ends in chad knowing it all telling everyone else they're wrong. .
No a good thread is you going back on what you said was going to fix your car. https://acurazine.com/forums/showthr...1#post14482437
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jul 16, 2017 07:33 AM
agupta3224
Sep 22, 2015 08:08 PM
lovic87
Sep 15, 2015 06:07 PM
