Quick question
Old Nov 18, 2015 | 09:05 PM
paperboy42190's Avatar
Quick question
I just have a quick question. Is it okay to turn the crank pulley without removing the spark plugs? I am pretty sure it's okay, but I want to double check since I dont want to remove my spark plugs again
Old Nov 18, 2015 | 09:07 PM
MonkeyTrucker's Avatar
Life Connoisseur
I don't know...maybe thoiboi can chime in and Google that for you...
Edit - For relevance
Old Nov 18, 2015 | 09:13 PM
cu2wagon's Avatar
You mean like just putting a ratchet on the pulley hex and turning it by hand without the ignition on or anything?
Shouldn't be a problem. I mean, that's sort of what the starter does when it runs, albiet from the other end if the engine. That's also one of the defacto methods of checking for a siezed engine or for checking compression (at least in my olden days).
Old Nov 18, 2015 | 09:31 PM
Jboat's Avatar
Perfectly fine, but will require quite a bit more elbow grease...
I never removed mine when I did my timing belt because they were new...
Old Nov 18, 2015 | 11:20 PM
thanks guys just wanted to confirm. need to do my oil pump seals and would have to take off my timing belt to get to it. however I did my spark plugs and valve adjustment a couple weeks ago so I wouldn't want to remove my spark plugs again unless I have to
Old Nov 18, 2015 | 11:37 PM
nfnsquared's Avatar
You're fine. I really couldn't tell a difference with or without the plugs in. Seems to me the valve springs create most of the resistance....
Mabarin Pacheco
Nov 20, 2015 11:16 AM
JWvegas
1G RDX (2007-2012)
Nov 20, 2015 08:46 AM
jaimbot
4G TL Problems & Fixes
Nov 19, 2015 07:38 AM
Sevenfold
Nov 16, 2015 12:43 PM
23109VC
Nov 14, 2015 01:22 PM
