Purchasing 2007 TL with 90k mi
Hey guys, I'm looking at buying a 2007 TL with 90k miles. I'm new to the forum and new to the Acura community but excited about Joining it. Other than standard used car buying cautions, what things should I be paying attention to specifically to the TL when buying a used one?
Any input would be great, thanks in advance.
Motor mounts would be a good thing to check. Make sure the HFL works too, if it doesn't fixing it is possible but it involves either baking the board or replacing it. Check for power steering noises when cold also. Keep in mind the 105k service (timing belt, water pump etc) probably won't be done so you'll have a good 1000$ to spend quite soon.
Robospinner (11-25-2014)
smart purchase, Acura is agood buy no matter what . 90 thou. just break in in.
hey guys, i'm looking at buying a 2007 tl with 90k miles. I'm new to the forum and new to the acura community but excited about joining it. Other than standard used car buying cautions, what things should i be paying attention to specifically to the tl when buying a used one?
Great, thanks guys. I have bought several used cars before and will do the routine checks with a mechanic for fluids, leaks, noise ect. Just wanted to be aware of specific things to watch for that Acura TLs might be known for when coming up on 90k-100k miles. This helps
Good point on 105k timing service. I'm sure this has not been done
Received 6,470 Likes
Welcome Rob. Also, just know that the major tune at 105,000 is coming up too.
good luck
love my 2007!
love my 2007!
HFL and message "Gas Cap Tighten" is the two common things could happened with 07-08 TL.
The car is in excellent shape. The previous owner had the 105K service done in July, including a transmission fluid and filter change. The selling dealer replaced the control arm bushings, did a synthetic oil change, and replaced the air and cabin air filters. They also put new Uniroyal TigerPaw tires on the car. After I purchased the car I ditched the Uniroyals for Michelin PS AS/3s. I also did a brake fluid flush, replaced the battery with an AGM battery, changed the PS fluid (turkey baster method), and cleaned and conditioned the leather with Lexol.
I'm in the same boat as you, looking for a TL and thinking the same thing.
I had a look at this page and found what TSB's would apply to a candidate TL so I know what things to check for:
https://acurazine.com/forums/third-g...-016-a-613659/
Some items are VIN specific so be sure make sure to take note of that!
