Pros and Cons on K&N air filter
I was reading earlier on the forum here that the K&N filter for the 3rd gen. TL could cause some problems and ruin your engine it the long run. Does anyone know of such facts or do you suggest using the stock filter instead or a short ram?
Ideas and help on this would be great.
06 Anthracite TL
I had a K&N in my 00TL and have one in my 06. They work fine and don't void the warranty. The key is to clean and re-oil at an appropriate interval (the K&N website indicates 50,000 miles, which is likely too long). In that time the oil would likely dry out and the cotton element would likely not filter as well.
The benefits are:
1)better filtration and airflow with cotton gauze/ oil
2)no need to buy more filters- just clean and re-oil
3)possible increase in performance and mpg (although in the stock airbox, the gains would likely be small)
The cons:
1)cleaning / re-oiling
2)cost
The benefits are:
The cons:
2)cost
One on the right for me
Had them on all my cars - never had a problem with them. I was threatened once by a fellow member for using one, can't figure out why.
K&N Not All It's Cracked Up To Be
I'm sure this will receive a lot of negative responses....But don't shoot the messenger. I'm simply trying to provide some factual information from a credible source. I'm not an automotive engineer and neither are many of you. Please follow this link to read for yourself the outcomes of an unbiased air filter test involving the 3 common filter types (foam, paper, fiber) in two areas: 1.) Air Flow and 2.) Filtration.
http://www.bobistheoilguy.com/airfilter/airtest1.htm
I think you'll see that the K&N, while not bad, is mostly hype.
I, too, have had them on both cars I've owned and they work flawlessly. It also saves you the trouble of buying a new filter every time you have to change your air filter. Trade off is that you have to clean and reoil them, which I do not mind doing.
As an engineer for an aerospace company, I can tell you that THE reason why k&n usually gives a little bit of power boost is because the holes/spacing between filter fibers is larger. This allows more air to easily pass through the element. Of course, more small dirt particles pass through the filter and into the engine.
Oil has nothing to do with it. It's a simple matter of the filter having larger holes giving you more air flow but allowing more particles in.
You COULD just not have any air filter. That would give you a huge HP boost but of course your engine won't last very long.
The power increase from using a K&N is not deniable. What is in dispute is exactly how much extra dirt is allowed into the engine and whether or not that dirt could cause any long-term damage. I have not seen any studies on the effects of long-term k&n use on an engine.
Before anyone shoots their mouth off at me, ACTUALLY READ the link posted earlier. That is, unless you are affraid about what it has to say?
The point (and fact) is that as previously posted K&N filters DO allow more to air to pass through which can lead to small increases in engine performance. I'm not disputing that. However, with the increased air that passes through are also small particles of dust, dirt, even sand. IMHO it's not worth a (maybe) 2-3 horsepower gain to get all that junk in your engine. Running a high quality synthetic oil will net as much hp gain and protect your engine better then using a K&N air filter.
OK, now fire away everyone....I wouldn't dish it out if I couldn't take it.
guys its very simple
K&N will allow more dirt into the engine, but nothing where it will make the check engine light go off.
if it were to harm the engine, K&N would be out of business.
not only that, the average amount of time we all keep our cars today is roughly 5 years, and that is pretty darn long.
so 3 years of use with a K&N filter (which i have done) is perfectly fine for the engine. I never noticed any HP gains, and even though it did put a gain, 2-3 hp gain is not noticeable by any man.
not even a CAI hp gains are noticed by an avg person, the avg person just hears the roar of the intake and with human nature we presume that there is a gain in hp.
K&N is low maintenance, easy to clean, and cost effective.
plus it whistles, pretty nice sound.
sang
sang
sang
sang
If you are concerned about dirt passing through the intake and ending up in your engine, then consider sticking with the OEM paper filter. The test linked above still shows dirt going through, just not as much. Whether we like it or not, dirt will pass through and end up in the engine. If you are planning to keep your car for 20+ yrs, then maybe you should rethink the CAI route.
And to OP, IMO just get the CAI. You wont regret it, I haven't.
Originally Posted by rbf351
it doesn't do anything to the engine
all it actually does is collect more dirt than the stock one
First off let me clarify when I used the term "flawlessly". When I said this, I meant that the CAI performed exactly how a CAI should perform. My previous car, 97 Accord, was the prototype car for the Typhoon system out today.
That is true, but for those of us with the CAI installed, we get both performance gains from synthetic and CAI. (not trying to say that it balances the effects out so no flames needed there)
2012 Cadillac CTS-V Coupe
I had a drop-in K&N in my '01 TL for 5 years (80K miles). Never really noticed a performance increase. Noticed a little more growl and slightly better gas mileage. TO be honest though, I replaced that filter when the car only had about a 1000 miles on it so the improved mileage could also have been attributed to the car breaking in.
Never had any issues, but I have heard of Mass Airflow sensors going bad on cars due to oil accumulation dues to people using too much oil after cleaning.
rcs86
08-02-2016 06:52 PM
