Pressure switches
Old Mar 12, 2014 | 03:43 PM
Bill C.'s Avatar
Pressure switches
I have 94 k on my 08 TLS, AT. I have never replaced the pressure switches. I did ask at the dealer sometime ago about replacing them. The answer was I believe," not recommended"
Also, I have changed all the fluids with the exception of the rear end. Opinions and suggestions welcomed, Thanks in advaance.
Bill C.
Old Mar 12, 2014 | 03:46 PM
cruc1a7's Avatar
There is no rear end?
Old Mar 12, 2014 | 04:58 PM
paperboy42190's Avatar
the TL doesnt not have a pumpkin in the rear....what rear end fluids are you talking about?
Old Mar 12, 2014 | 05:20 PM
tones160's Avatar
[x] FWCC [x]
*confused*
Old Mar 12, 2014 | 05:23 PM
topdollr's Avatar
9th Gear
^x2
Old Mar 12, 2014 | 05:39 PM
Conan O'Brien's Avatar
blinker fluid, guys. have yall not been changing it at the recommended 3K mile intervals??
Old Mar 12, 2014 | 07:31 PM
Due_Diligence's Avatar
Bill C.
After reading countless times on the forum that changing the pressure switches has made a positive difference in the way the transmission reacts, I'm going to go with its recommended. Waiting on mine to arrive within the next week hopefully.
Old Mar 12, 2014 | 07:53 PM
raindogt's Avatar
Sure, I've been changing it at the 3K intervals..... That still doesn't explain the 'rear end' fluid-- to change mine, I just open the kenooter valve right underneath the Wilikson joint on the front right side of the engine bay.
Old Mar 12, 2014 | 09:36 PM
sure, that is all fine and dandy to change the FRONT blinker fluid reservoir. i think you are getting the front and rear fluids confused.
Old Mar 12, 2014 | 09:57 PM
IamaTL's Avatar
I like turtles
is that why my blinker is dim on the right side rear? I haven't changed the fluid in 40k miles.
Timthetoolman's Avatar
The need to change pressure switches is at least partly driven by age of car, which your car is fine. On the other hand, you have enough miles on the car to easily justify the minor effort and cost of change to ensure that transmission will have a long life. Waiting until you see issues will cause excessive clutch wear do slow plate engagement and may reduce life of transmission.
Old Mar 12, 2014 | 11:21 PM
Drei's Avatar
I think what Bill meant was rear differential
And I suggest you replace the pressure switches regardless of whatever advice the dealership gave you
Here's the DIY https://acurazine.com/forums/3g-tl-2004-2008-93/110-b-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2007-2008-a-840630/
Old Mar 13, 2014 | 09:21 AM
GKinColo08TL's Avatar
Thanks for this, I found the rear blinker fluid reservoir under the spare tire...kind of silly to put it there when it needs changed every 3K miles...
Here's the DIY https://acurazine.com/forums/showthread.php?t=840630
This is a front wheel drive car, why would there be a differential in the rear? Just an axle back there.
Old Mar 13, 2014 | 09:28 AM
so, he's a little confused.
which we cleared up.
let's not drag on the simple mistake the OP made.
we dont have a rear differential. so no fluids need to be changed.
Old Mar 13, 2014 | 09:29 AM
lusid's Avatar
FTW
Rotator splint comes to mind.
Old Mar 13, 2014 | 10:44 AM
Bill C.'s Avatar
Thanks so much for the heads up, I got the blinker fluid at Auto Zone, what a difference "YOU ALL"
Old Mar 13, 2014 | 12:00 PM
rockyfeller's Avatar
King of NYC
As we've said many times, the dealer is just going to "recommend" and tell you what his "Acura" book says. He's not doing anything wrong, just doing as he is trained. He can't go any other way, he can get in trouble.
If anyone needs a slap it is Acura itself. This is a KNOWN problem that they will NOT admit to. By changing their maintenance schedule that has been in place all these years is like admitting fault that there is a problem. What they really deserve is a class action lawsuit from all of us regarding this crap transmission.
You can trust them (people who defend their own interests) or us. (owners who are just like you that want to do the best thing for the longevity of our car.)
Thousands of threads about this at this point. The benefits of doing the switches and fluids is a no-brainer.
Old Mar 13, 2014 | 03:48 PM
1KLRTOY's Avatar
Here ya go, real "blinker fluid" http://www.mazdatrucking.com/forum/s...-Blinker-Fluid
Old Mar 13, 2014 | 04:09 PM
Drei's Avatar
Duly noted
Old Mar 13, 2014 | 06:50 PM
tones160's Avatar
[x] FWCC [x]
OHHH ROFL I was like still WTHHH is a blinker fluid!
Originally Posted by 1KLRTOY
Mike Pilipenko
Mar 26, 2024 09:21 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
eastcoastguy
Sep 23, 2015 06:29 AM
