Passenger window issue?
Old Jun 11, 2022 | 10:46 PM
TPR-10's Avatar
Thumbs up Passenger window issue?
I have a 08 TLS and tried to roll the window back up on the passenger side and it kept going back down instead.
I had to go to the passenger side door to roll up the window since the drivers side door could not do so.
please help with any insights.
Old Jun 12, 2022 | 08:51 AM
peter6's Avatar
If it works fine from passenger's switch, but doesn't from driver's (master switch) then suspect master switch.
Old Jun 12, 2022 | 10:45 AM
Maybe just take some crc qd electronic cleaner and spray clean it real good, if you have the skill set to remove?
If you would like to 'roll the dice', here's a salvage one for $49 before shipping.
2004 Acura TL Power / Master Window Control Switch 35750-SEP-A02 (ahparts.com)
Otherwise, it's OEM master switch for $234.44 before shipping.
83560-SEP-A01ZA Genuine Acura Part (acurapartswarehouse.com)
Old Jun 12, 2022 | 11:18 AM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Perform the relearn procedure 1st before replacing the drivers window switch assembly. Prior to doing so, assure the glass rubber seal is clean.
All you have to do is press the window button down, and hold it for two seconds once it is all the way lowered. Then, pull the button upwards and keep it lifted for another two second once all the way up.
Old Jun 12, 2022 | 05:31 PM
csmeance's Avatar
You have 1 touch close from drivers door, so if you pull up the switch all the way it commands the passenger window to close completely. IF the pinch sensor logic (so you don't crush your hand in the window) detects abnormal resistance the window rolls right back down. Clean and lubricate the window channels first.
iamyiyaj
Oct 5, 2021 06:38 AM
theorginalFrank
Aug 14, 2016 11:03 PM
lucnex
Sep 27, 2015 08:16 AM
Bill C.
Mar 20, 2014 03:28 PM
shaolin
Jul 1, 2003 10:48 PM
