Oil Leak...has it happened to you?
Kelnshe
I've noticed over the past couple of weeks that my TL has a small oil spot underneath it in my garage. It is on the driver's side, near the front wheel. I have about 5800 miles on it, and my MID went from 30% (which was where it was at about 5500 miles) to <15% in a matter of two weeks. Now I'm getting a message that it's time for the A1 service. When I scheduled my oil change, I was told that they've seen a few TLs like this, and that the techs know how to fix it. Has this happened to anyone out there? TIA!
Team Anthracite Member
Did you try to look underneath to see where the fluid may be leaking from? It can be either motor oil, transmission oil, or shock absorber oil.
With my TL I started to notice small drips of oil in the area of the rear left wheel well in my garage at about the sime time as you did (around 5500-6000 miles) and it was pretty apparent that it was the shock absorber that was leaking.
The flatspotting/vibrating Bridgestone EL42s do wonders to the shock absorbers (as well as to the rest of TL suspension, I assume :sqnteek: )
The dealer replaced under the warranty (the leaking shock, not the intermittently vibrating tires). I'm throwing the tires out myself at the end of summer and getting myself either Michelins or Falkens.
Either way, I'm at 11000 miles now. No further leaks at this point, although the intermittent tire vibration continues off and on.
Cheers,
/tallrussian
Cheers,
/tallrussian
The Oracle of Acurazine!
Originally Posted by bluenose
Acura issued a service bulletin on Mar 26 - No. 111303 regarding oil leaks. You might want to check with your dealer.
Go to http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm for further info
Kelnshe
UPDATE - I just came back from getting my oil changed, and was told that it wasn't an oil leak. It was the "seal that connects the rack hose to the rack that was leaking fluid", per the technician. They cleaned the area, but they may end up replacing the rack. They had not seen this before on the TL :shit: , so they had been on the phone with their tech support. I have another appointment in two weeks to have it replaced. As much as I like my TL, I've been to the shop more times in 5 months than I did in 4 years with my ES300. I'm not getting annoyed, just disappointed more than anything. Oh well, it's only a 3 year lease, so I can unloaded it with a minimum of headache if it becomes a real pain. Maybe they'll get it right in 2007...
I parked at my Brothers house yesterday and after leaving he said he notice two oil drops on the driveway. I haven't noticed anything in my garage so not sure if it was a one time deal as his driveway is on a slope.
I had the same problem. I had the same leak from the rack. They had to replace 2 racks on my car to fix the issue. It also took them three tries. They replaced the power steering pump once and that did nothing. I am also suing acura to declare the car a Lemon since I am in Nj and it ook them more than 3 tries to fix the problem. Good luck. My car was in the shop a good month. When they first replaced the steering rack the steering started pulsating on turns. Hope you dont go thru what I did.
Kelnshe
UPDATE - So far so good. After three weeks, I haven't seen any leakage, and I haven't noticed any steering pulsation. I do hear a slight ticking at times when I turn the wheel. I am monitoring the situation, so I will keep you all posted if it becomes an issue again.
dsc888
Kelnshe
UPDATE: She's back in the shop again. About two weeks or so after I got it back, I started hearing noise coming from the power steering area. It sounds similar to the way a GM car sounds when the power steering fluid gets too low and the steering wheel is turned, only not as loud. In addition, I also hear a slight rattling in the same general area when I roll over uneven pavement, as if there is something metallic loose underneath. No leakage of anything, however.
When I took it in for service. The technician immediately heard the noise, as well as the metallic rattling. They are checking to see if it is related to the rack/power steering pump replacement, or if it is totally new. I'm not getting ticked yet, as they gave me a TL (with crappy Bridgestones) to drive while I wait for my car. This is starting to get old, particularly for a 7 month-old car. I might start getting my Lemon Law ammo in order after this...
Kelnshe
nick04TL - You are absolutely correct, as far as dealer treatment is concerned. I didn't expect much from my dealer (Acura of Dayton) when I first got the car, but so far they've been really good. They've let me know what's been happening every step of the way, and always had a loaner car (a TL) available for me. When and if they get this resolved, I'd probably buy from them again. As long as they show me that they're not going to give me the runaround, I'm a patient guy. I almost expected this, since this is the first model year of the new generation of a car. I normally don't buy a car under those conditions, but I liked the car so much (as well as needed one as well), I didn't think it was an issue, given its Honda roots.
As far as the problem is concerned, they are not sure yet if this is related to the power steering/rack issue yet, so it actually could be the same problem again. They are supposed to call me this morning to give me an update. In the meantime, I have a WDP 04 TL to sport until I get mine back. I never looked at a white car before, but I have to admit, with the parchment interior it looks sweet!
05 6MT NBP TL
I believe I am leaking oil on my 05. In the garage I noticed a small puddle close to the driver side front wheel. I looked under and see a couple drops of oil but can't see where it's coming from. not leaking much oil and not life threatening... but it got me worried
This thread is quite old... just wondering if anyone else had that problem.
Any help appreciated !
mada51589
05-03-2022 08:54 PM
SidhuSaaB
05-30-2020 12:40 AM
STL TL-S
09-23-2015 08:52 PM
