O2 Sensor
Old Nov 21, 2022 | 05:23 PM
Marsalis Simms's Avatar
UA7_Unknown
O2 Sensor
Replacing all 4 sensors on my 08 TL-S, buying Denso replacements and wanted to be sure I was using the right part numbers from Rockauto as I only found the numbers for the 3.2 on here. Also saw some were listed for the auto trans specifically and others manual (mine is the 6spd) so also wanted clarification on that.
Denso Upstream 234-5010
Denso Downstream 234-4351
Thank you in advance.
Old Nov 21, 2022 | 07:13 PM
If you take the OEM part #'s for each of the four 3.5 TL-S 6MT O2's you want to replace #9, 10, 11 & 13
Converter - 2008 Acura TL 4 Door TYPE-S KA 6MT (acurapartswarehouse.com)
and plug them into the rockauto part number search functionality, on their website, it will bring up a list of specific sensors available, then you can pick the Denso's that are present.
Old Nov 21, 2022 | 07:39 PM
UA7_Unknown
Thanks, didn’t know that was a thing on Rockauto.
Old Nov 24, 2022 | 10:17 PM
Chad05TL's Avatar
https://acurazine.com/forums/3g-tl-p.../#post16813055
Old Nov 30, 2022 | 12:52 PM
Brock's Acura TL AT 2004's Avatar
Marsalis, RA can be good for some stuff?? But my #1 parts supplier is OEMacuraparts.com. Especially electrical parts. Cheers
Old Nov 30, 2022 | 01:33 PM
^ That's great advice; however, why pay nearly double the price when you can get the same OEM O2 sensor at RA for nearly 50% off?
Acura online vendor eample:
RockAuto:
Either one is acceptable for Acura / Honda applications.
Old Nov 30, 2022 | 02:16 PM
Great question Zeta! I have bot many AM parts that have failed. One example is the AT 3rd & 4th gear switches, that only lasted one month. After searching this site, someone suggested OEMacuraparts.com were way better. Changed dem out 3 years ago and still going strong. Yes, they were more $$, but........Cheers
Old Nov 30, 2022 | 04:31 PM
The problem with your comparison is that the NTK & Denso O2 sensors ARE OEM from the factory offered on a retail parts vendor at half the price.
The AT 3rd & 4th gear switch comparison is OEM against non OEM aftermarket cheap $$ foreign junk that one would pick-up on amazon or the local Autozone.
It is well known that, when talking about trans. pressure switch replacement for Acura / honda, OEM is the ONLY way to go and 'do it right the first time' no matter the cost.
Aftermarket foreign AT 3rd & 4th gear switch(s), not so much.
A-110(a): DIY Guide to replacing 3rd & 4th gear pressure switch for 3G TL (2004-2006) - AcuraZine - Acura Enthusiast Community
Old Dec 1, 2022 | 09:12 AM
TheSauceBoss's Avatar
Just to supplement what zeta said, when it comes to the switches, I would try to avoid buying "OEM" ones from amazon. I've *heard* their stocking system allows the same items from multiple vendors to be stored in the same bin. So you could have true OEM switches from a dealer sitting in the same bin as the "overseas special" parts, because they are technically listed as the same thing. There's no way to control what you're actually getting. I'd go straight from the dealer or from a reputable website.
And not to beat a dead horse, but I've had great success with Denso o2 sensors from rockauto.
Old Dec 1, 2022 | 12:49 PM
Spot on.. the 3rd/4th pressure switches have many aftermarket options and all are . While I agree with OEMAcuraParts has a favorite vendor, in this specific instance, RA has the exact same part for a fraction of the price.
Old Dec 1, 2022 | 05:51 PM
UA7_Unknown
I appreciate all the tips/advice. I’ve had good experiences with RA as well. I’m typically the buy directly from Acura and OEM only kinda of guy, but yeah I was able to get all 4 (Denso) for $300 from RA which isn’t bad at all. Will be installing this upcoming week and hoping this fixes everything, since it’s gotten cold the car has started to vibrate/misfire while accelerating occasionally. If it ends up needing cats I’ll update lol not gonna be too upset if that ends up happening as RV6 HFPC’s wouldnt be a bad upgrade
Old Dec 6, 2022 | 12:56 PM
UA7_Unknown
Have put several hundred miles on the vehicle since replacing O2’s and it drives normally. However have discovered I will potentially need new CV axles as it vibrates upon acceleration around 60 MPH. Tires balanced, plugs are fine and idk what else it could be.
Old Dec 6, 2022 | 02:28 PM
Have you noticed an increase in gas mileage?
Old Dec 7, 2022 | 02:33 PM
UA7_Unknown
I have, went from 21 to like 25-26 on average. I didn’t even realize it was impacted cuz 21 was within factory rating I believe.
Old Dec 17, 2022 | 04:41 AM
bluetl04's Avatar
NTK is oem. buy them from rockauto.com
Mike734
Aug 31, 2022 05:40 PM
Mike Brazil
2G CL Problems & Fixes
Dec 28, 2018 03:29 PM
USNA93
Jul 28, 2017 12:46 PM
RA22325
Dec 12, 2013 05:44 PM
Blanco1
1G TL Problems & Fixes
Apr 11, 2007 01:23 PM
