Nokya DRLs
Old Dec 7, 2008 | 08:24 AM
chairguru22's Avatar
Unregistered User
Nokya DRLs
So I just ordered these DRLs 9005 HB3 Nokya Arctic White light Bulb Stage II 7000k and then noticed that it's 100watts.
Type: 9005 / HB3
Sold As: 2 Bulbs
Wattage(input): 100
Wattage(output): 120
Color: Arctic White
Color Temp: 7000K ( Stage II )
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
would there be an issue with that? The fogs are only 35watts so it seems like its too high. thoughts?
Old Dec 7, 2008 | 10:59 AM
Unregistered User
Upon further research in the manual it lists the DRLs as 60w... would 100 affect the electrical or does this just mean output brightness is lower?
Old Dec 7, 2008 | 11:19 AM
Steven Bell's Avatar
You might want to PM Bearcat94...he is a master at this stuff.
Old Dec 7, 2008 | 03:45 PM
aquariussuperman's Avatar
Just say no to daytime running lights. If people can't see a 4,000 lb moving machine during the day, they don't deserve to be driving. (/soapbox)
Old Dec 7, 2008 | 04:41 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
100 watt is very high. They could burn your harness or headlight lens.
Old Dec 7, 2008 | 05:22 PM
TeknoKing's Avatar
The oem drl bulbs are rated 65W... The goal is to go lower in W to increase illumination and avoid harness damage.
Old Dec 7, 2008 | 05:49 PM
jptl04's Avatar
Bone stock tl-s
i tried these in my drls http://www.eautoworks.com/product-PIAA-5122.htm guess what same ugly stock color. even though it says 12v 60W=120W same stock color. i tried led's two kinds no luck. said "fuck it go the opposite way" got some nokya hyper yellow bulbs, and im cool with them. no warning light and looks better than stock.
Old Dec 7, 2008 | 05:52 PM
LoveMyTL-S's Avatar
I also have the Hyper Yellow Nokya bulbs and love them.
Old Dec 7, 2008 | 07:30 PM
jguerra23's Avatar
Looking for new mods
Originally Posted by lovemytl-s
i also have the hyper yellow nokya bulbs and love them.
x2
Old Dec 7, 2008 | 07:53 PM
Bearcat94's Avatar
AZ Community Team
Sorry, can't help on this one. Fog's I've done, but nada with DRL's.
I am still hoping someone will find an LED DRL for the '07/'08, but I haven't seen any succes reported yet.
Old Dec 7, 2008 | 07:56 PM
Bearcat94's Avatar
AZ Community Team
The reason for this is that the DRL circuit doesn't provide full power (volts, watts, amps, whatever) to the bulb. The result: Any "white" bulb will be a pissed out yellow.
Old Dec 7, 2008 | 08:06 PM
rockyfeller's Avatar
King of NYC
It's hard to know what bulbs will do at the lower DRL voltage without testing it out. DO NOT do 100W bulbs with the normal 12V input though!! They are known to melt headlights, connectors and wiring. They are meant only for large aftermarket driving light housings that can handle the heat and power requirements. You can do up to 70 watts with a relay wired in. Stick to 55 watts to be safe, you will not see as much improvement as you'd think beyond that. But because these DRLs are being driven at low voltage maybe 70 watts won't hurt?
If you REALLY want a marked improvement over what you have, nothing beats HIDs. But as mentioned it is not going to work with your DRL wiring because of the low voltage......THERE IS a way around it to supply 12V if you really are interested.
Old Dec 8, 2008 | 08:05 AM
Unregistered User
If that's the case then maybe I won't do this mod afterall. I just don't like how it's yellow lighting on my white car. The fogs I don't like either with the HIDs being bright white then you have yellow fogs...
Since they don't run at "full power" would a higher rated bulb just run lower as well, in a range that wouldn't fry the wiring? Since the DRLs are rated at 65w, would that mean they actually run at lower wattage instead?
I guess I need some first-hand opinions.
Old Dec 8, 2008 | 12:24 PM
kipros's Avatar
100 watts too much..you will be drawing almost twice as much current, which will lead to wires failure..
Old Dec 8, 2008 | 06:50 PM
OStateBeaver's Avatar
What is the bulb type for these bulbs? And what site did you guys use to pick these up?
Old Dec 9, 2008 | 05:48 AM
R*D*X*'s Avatar
i also changed ddl and my fog lights on my rdx, fog lights looks great after i changed it with this: eBay Motors: XTEC OF JAPAN H11 SUPER WHITE LIGHT BULBS HEADLIGHTS (item 310097035203 end time Dec-31-08 22:36:11 PST)
Its only 55 watts and it looks the same as my HID lowbeam,,, I would not suggest changing DDL(high beam) coz it will just look yellow unless you turn on your high beam.
Old Dec 11, 2008 | 09:57 PM
LessisBestmakingendsmeet's Avatar
Hello!
I've had these bulbs for a couple years, very impressed with how they have held up.
Old Dec 12, 2008 | 10:50 PM
ayabei's Avatar
i have 80 watt Nokya hyper yellow for my drl's with heavy duty wire adapters so it won't melt your stock drl's wires. Had mine on for almost a year without the wires or headlight lens melting. I suggest you put on heavy duty wire adapters before putting those 100 watt bulbs in or else you might have problems later. Here's a site or you can go look for it on ebay...http://www.racinglab.com/headbulwirha.html
Old Dec 13, 2008 | 01:52 PM
Unregistered User
I just got the Nokya 9005 100W bulbs and will get the harness before install. The DRLs are hard to get to also because I tried changing them before...
I also got the Nokya H8 Fogs and installed those, looks great. Will post pics once night comes.
Old Dec 13, 2008 | 03:31 PM
TeknoKing's Avatar
In a TL, we have bi-xenon headlights. And fog light size is H8. DRLs are 9005
Old Dec 13, 2008 | 05:33 PM
Unregistered User
I did the fog light bulb switch to Nokya Arctic White
Before:
After: Left is stock, Right is Nokya bulb
NIGHT SHOT! No more yellow (bleh) color.
Old Dec 13, 2008 | 06:28 PM
ABP_04TL's Avatar
6-SPEED LOVER
2 me its iight...
but bro throw sum HIDs in there would look 10x better, i aint hatin tho just to clear that out
Old Dec 13, 2008 | 06:35 PM
Unregistered User
HIDs are a pretty complicated mod that I don't feel like doing, yet at least.
Old Dec 13, 2008 | 07:03 PM
ABP_04TL's Avatar
6-SPEED LOVER
its plug and play
trust me i think u could install a HID quicker then puttin that H8 bulb in the socket
its kool... later on just Do that and ull b amazed with the results
Old Dec 13, 2008 | 07:04 PM
LoveMyTL-S's Avatar
Looks great. A nice improvement over the yellowish OEM bulbs.
Old Dec 13, 2008 | 10:40 PM
Originally Posted by ABP_04TL
its plug and play
How much would you be lookin at for the HID kit?
Old Dec 13, 2008 | 10:52 PM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
i agree with ABP; the HID kit is a real easy PNP mod, Cheap, and 100X better. i just upgrade the 4300K to 8000k beams and they look great. still waiting for my accord fogs to come and then ima upgrade to 8000k as well.
Old Dec 13, 2008 | 10:55 PM
Unregistered User
The search function isn't working, any info on this HID mod? Is it a new bulb? or a new light entirely? or what? and is this DRL, fog, or both you are talking about?
Old Dec 14, 2008 | 01:48 PM
ayabei's Avatar
yeh changing your fogs to hid isn't really that hard it's pretty much plug and play. The only sucky part is finding a mounting spot for the ballast, mine happens to be a fat ass one. Nowadays they have some made in a slim version that works from 35 to 55 watts. I got 6500k headlights and 3000k on fogs can't go wrong with that!!!
Old Dec 14, 2008 | 02:04 PM
Unregistered User
When you say plug and play, do you mean putting in a new bulb? it can't be any easier than that... which is what i did, i put in a 7000K bulb.
Old Dec 14, 2008 | 05:32 PM
ABP_04TL's Avatar
6-SPEED LOVER
^^^hes on the money right now
plug and play... like settin up a xbox 360 or ps3 ull b done in no time when u install a Hid kit...
Roughly u can get a KIT around $60+ maximun $120 depends where u get them at, from temp 3000k-10000k
Old Dec 19, 2008 | 05:10 PM
Liquidflex81's Avatar
LiQuiDFleX81
Question
where can a true 3k hid kit be found? i have come across several sites, but i do not know if the bulb lights up white but puts yellow on the ground,, i want yellow view yellow output,, help?
Old Dec 19, 2008 | 08:08 PM
ABP_04TL's Avatar
6-SPEED LOVER
i kno exactly wat u mean... i still havent seen a real 3000k hid kit, they all go to white color or greenish white, then throw yellow at the ground...
the best thing to do is, get a 6000k hid kit and get a yellow tint for the fogs, and BANG pure yellow
Old Dec 20, 2008 | 09:14 AM
ayabei's Avatar
i have true yellow hid fogs (looks kind of white head on but throws out a nice yellow on the ground)
Old Dec 20, 2008 | 01:10 PM
LiQuiDFleX81
no, not what im lookin for,, it MUST be yellow head on and output
Old Dec 21, 2008 | 05:22 PM
jguerra23's Avatar
He is looking for this.... So am I.
Old Dec 21, 2008 | 05:35 PM
inyong1988's Avatar
HID's on DRL are hideous.
Old Dec 21, 2008 | 07:00 PM
LiQuiDFleX81
exactly!
Old Dec 21, 2008 | 07:11 PM
ABP_04TL's Avatar
6-SPEED LOVER
ive never bought McCullough HIDs but they say they have tru yello 3000k hids
i think these r old pics from McCullough
Old Dec 21, 2008 | 07:15 PM
ABP_04TL's Avatar
6-SPEED LOVER
this is the yellow every1 is lookin for correct ====v
