Nokya DRLs
Old Dec 21, 2008 | 08:57 PM
  #41
chairguru22's Avatar
Unregistered User
My Nokyas are 7000k... but they aren't HID??? Personally I'd rather have that white appearance than the blinding light.
Old Dec 21, 2008 | 09:38 PM
  #42
ABP_04TL's Avatar
6-SPEED LOVER
these bulbs we have, has a tint in it...
No they are not HIDs (High Intensity Discharge)
compare to HIDs which is a gas, except sum of the 3000k which those have sum type of color on the bulb itself, from wat ive seen
Old Dec 22, 2008 | 02:36 PM
  #43
Supraman7675's Avatar
Nokya arctic white stage ll
Does anyone have a photo of Nokya arctic white for headlights (as opposed to fogs)
Old Dec 26, 2008 | 03:53 PM
  #44
Unregistered User
I just got the Nokya 9005 100W bulbs and will get the harness before install. The DRLs are hard to get to also because I tried changing them before...
I also got the Nokya H8 Fogs and installed those, looks great. Will post pics once night comes.
Ok an update on my DRL mod:
I got the Luminics Heavy Duty Wire Harness and installed that plus the Nokya Arctic White 7000k 9005 for the DRLs (in the newer TLs, the DRLs are where the fogs used to be). I installed one light and tested it, works great, looks great. When off it gives the housing a cool bluish tint and when on it's white but not as strong light as yellow is.
Here's the problem though. When I installed the second light, tried testing, nothing worked. And the DRL warning light comes on in the dash. The other problem though is it's getting dark outside and so the DRLs won't come on automatically (can you turn those on manually somehow?). I will need to test it more in the morning.
I'm thinking the problem could be that it's rated at 100W and therefore is not working when both lights are installed. Someone in this thread noted they have 80W bulbs and a harness and it works though. Is there a way to lower the wattage?
Old Dec 27, 2008 | 11:49 AM
  #45
Unregistered User
I tried again this morning, same issue. It's raining so I will have to solve it another day but any thoughts on what else it could be? I really hope it's just a faulty wire or bulb.
Old Dec 27, 2008 | 02:43 PM
  #46
rockyfeller's Avatar
King of NYC
Yes BINGO, those pics are on the money, that is what I was talking about too. I am looking for bulbs like that too!! I know a long time ago they seemed easier to find. The latest bulbs out seem to be white throwing off yellow, why??
Old Dec 27, 2008 | 03:02 PM
  #47
Steven Bell's Avatar
[QUOTE=chairguru22;10283558]I did the fog light bulb switch to Nokya Arctic White
My girlfriend got these bulbs for me for the holidays. Buda and I are going to install them tomorrow with step by step instructions from Bearcat! I'm excited.
Old Dec 27, 2008 | 03:26 PM
  #48
Unregistered User
Well if you have a WDP TL you know exactly what they'll look like.
Old Dec 27, 2008 | 03:47 PM
  #49
I've got an ASM. I just wanted the fog lights to be as bright as the headlights. This should do the trick.
Old Dec 29, 2008 | 12:14 AM
  #50
Bearcat94's Avatar
AZ Community Team
Old Dec 29, 2008 | 06:32 AM
  #51
Cecilt's Avatar
Steven, let us know how your install went. Also, I don't believe your comment above is accurate. I want my fogs to match the color of my HIDS but also be as bright (or should I say give off as much light) as the stock fogs. I belive the Arctic Cats 7000k will match the color of the HIDS but WILL NOT give us as much light. Is there a simple plug in bulb that will?
Old Dec 29, 2008 | 10:18 AM
  #52
Cecil..you are right. First, the install went great. Thanks to Buda-I went to his house and we installed them fast. Second, the 7000k's are nice and bright, but they don't seem to be quite as bright as the HID's. I wanted my foglights to look as bright as my HID's when turned on for the evening. The stock foglights looked "off" to me when they were on. But the 7000k's are much better. Mine are 55 watts, and they're not as bright as the actual HID's, but they look really good. Maybe a higher wattage bulb would be brighter, but I like what the way these look. It's a definate improvement from the stock bulbs.
I'll take some pictures tonight and post, if possible.
Old Dec 29, 2008 | 02:40 PM
  #53
Unregistered User
So I did more testing on my Nokya DRLs and determined that it's the higher 100W that's the issue. Using one bulb at a time on either left or right side works. So it's not problems with the wires, bulbs, fuses, etc. This stinks because I initially couldn't find any 9005 bulbs in the right wattage and color I wanted.
Steven Bell, I can't wait to see what yours looks like!
Old Dec 29, 2008 | 03:20 PM
  #54
Unregistered User
http://cgi.ebay.com/ebaymotors/9005-...5237QQtcZphoto
Brand New Luminics Ultra White Halogen Bulbs
Type: 9005 / HB3
Sold As: 2 Bulbs
Wattage(input): 65
Wattage(output): 140
Color: Ultra White
Color Temp: 5150K
These are lower in wattage, 65 input, but the output is still 140. Would this still work you think?
Old Dec 29, 2008 | 05:36 PM
  #55
Here you go boys...just took these pictures.
Old Dec 29, 2008 | 05:39 PM
  #56
Unregistered User
very NICE
Old Dec 29, 2008 | 05:54 PM
  #57
Thanks Guru! Here's a new link of all the new aesthetic additions I've made to my Type S.
https://acurazine.com/forums/showthr...8#post10331418
I hope you guys like it!!!
Old Dec 30, 2008 | 09:17 AM
  #58
LoveMyTL-S's Avatar
Very bright and white. Looks great
Old Jul 13, 2011 | 03:01 PM
  #59
no44specialk's Avatar
So i can run nokya hyper yellow 65w bulbs safely for my DRLs? I have a 07 TL-s. I'm having a hard time finding a straight answer. I know LEDs will look better but I just want to try yellow bulbs for now.
Old Jul 13, 2011 | 04:48 PM
  #60
VicTL06's Avatar
^^ Same question: except I have a Canadian 2006 TL. I have DRLs and the module stock, as per Transport Canada regs.
In theory, I ought to be able to take ought my stock bulbs are replace them with a Nokya Hyper Yellow or Arctic White, provided they are 55/60W bulbs? Plug and play, no harnesses, no fuss, no muss?
Old Jul 13, 2011 | 06:10 PM
  #61
Bearcat94's Avatar
AZ Community Team
Your answer is actually on page 1 of this thread. Posts #6 & #12.
Old Jul 13, 2011 | 06:28 PM
  #62
Yea I saw that I'm just curious where he found that info. I pulled my drl and to my knowledge its still the stock bulb (Im the second owner) and it says 60w. I just want to make sure @ 65ws no damage will occur. In post #12 he says that up to 70w would be used, but with a relay wire. Does that mean I'm safe without a relay wire at 65w? Sorry if the questions overlap I just want to be 100% sure before I proceed.
Old Jul 13, 2011 | 06:41 PM
  #63
Bearcat94's Avatar
AZ Community Team
Originally Posted by rockyfeller
.... You can do up to 70 watts with a relay wired in. Stick to 55 watts to be safe, you will not see as much improvement as you'd think beyond that. ....
Why not just go with the 55W version?
Old Jul 13, 2011 | 06:53 PM
  #64
I accidentally already bought the 65w bulbs. If there wasn't much cause for concern I would just keep them. But seeing how there isn't a clear cut answer I think I may just send them back once they arrive.
On a side note, I can't seem to locate the nokya hyper yellows in 55w or 60w 9005s damnit!
Old Jul 13, 2011 | 07:21 PM
  #65
Just looked at nokyas website... They only make a 65w for the 9005 plug... Is there a bulb that other people have been using instead? I'm not sure how they are using a 55w??
Old Jul 13, 2011 | 09:46 PM
  #66
tlmailman's Avatar
has anyone tried HOEN fog lights? I did not see 9005 listed but they do have 9006. Since my 04 TL doesnt have DRL, I plan on using these in the fog lamps. They supposedly have a real yellow look.
Old Jul 13, 2011 | 10:05 PM
  #67
ez12a's Avatar
the overexplainer
Their 9006 bulb is a 55w, and is used on 04-06s.
Old Jul 14, 2011 | 05:24 AM
  #68
tlmailman's Avatar
[QUOTE=ez12a;13089059]Their 9006 bulb is a 55w, and is used on 04-06s.[/QUOTE
specs fall within range so no worry about frying your wires, but how is the color? Anybody have hoens in their car now, just wondering if it is true yellow or piss yellow?
Old Jul 14, 2011 | 05:48 AM
  #69
hondadna4's Avatar
I'M GOING IN
Yep I have bought Nokya yellow's before and never had any problems before.........Until.......I installed Nokya's 3000k on my girls car. Looked good for 7 minutes then we smelt a burning smell pulled over one of the lights were out. Inspected it and found it burnt thru the harness. All the Nokya bulbs says 55w=100 watts but its all bullshit. Its marketing but this pair of bulbs is hit or miss. I have tested TONS of lighting for the drl on the TL and I must say that the best one is LED it will always look the best take almost no power up and best color output.
Old Jul 14, 2011 | 05:56 AM
  #70
Yea i agree about the LEDs being the best, I'm just not sure if I'll like the yellow for the DRL so I want to buy and use a simple bulb for a while. I emailed Nokya to see what they say about their 65w hyper yellow working for my 07 TLs and whether or not it would cause damage to the wiring/harness. Everything Ive seen while searching has said to use a 55/60w but nokya doesn't make that wattage for the 9005 so I'm clueless to where they go the bulbs from.
Old Jul 14, 2011 | 06:29 AM
  #71
And correct me if I'm wrong the 3000k bulb is a HID bulb. Without the proper wiring problems would definitely occur.
Old Jul 14, 2011 | 08:40 AM
  #72
ebelp's Avatar
2014 Jeep SRT
"3000k" is the color temperature and does not mean it's an HID bulb.
Old Jul 14, 2011 | 09:47 AM
  #73
Yea I knew that but I've noticed many bulbs don't advertise above a certain output without the wattage going up or it being marked as "HID". Oh well whatever.
Old Jul 14, 2011 | 09:53 AM
  #74
ez12a's Avatar
the overexplainer
I bought a pair of Nokya 9006s at 2500k temp as fall back bulbs if my Xentec crap HID fogs take a dump. Even with a relay they flicker like a candle (not on and off, just the beam twitches which is a common problem). Got the kit for 30 bucks..
Old Dec 16, 2011 | 02:52 AM
  #75
Skunkworks's Avatar
Im going to get these and try them out with my DRL's.
http://www.ebay.com/itm/NOKYA-9005-H...item3a68144dac
I just hope running the 65w wont burn through my harness/headlamp. Do you guys think these will work fine? I know a lot of you guys recommend just going with true HID's but hopefully these are suitable for now.
Old Aug 8, 2016 | 08:38 AM
  #76
shxwnjr's Avatar
Nokya 9005 HB3 Hyper Yellow 2500K 65W Halogen Light Bulbs | eBay
Did you gave any problems with these i just bought some and wanted to know if i should still use them
Old Aug 9, 2016 | 09:48 PM
  #77
Viny's Avatar
I have them for over a year with no problem, and look so much better than stock dtrl.
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
JnC
Sep 11, 2015 06:06 AM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
