New member! Brake Problem
Old Dec 15, 2012 | 04:23 PM
aLLbLack_AC's Avatar
5th Gear
Hey guys, just wondering if anyone knows a good place for a caliper and drilled and slotted rotors for an 05 tl with a 6 speed manual trans, theres a lot out for Automatics but i dont see much for manuals
Old Dec 15, 2012 | 04:57 PM
The Machine's Avatar
Registered Member
Not sure why you need a new caliper? Is it seized up? We have vendors here that can help you find exactly what you're looking for. Here are a few of the vendors:
http://www.excelerateperformance.com/
http://www.heeltoeauto.com/
http://www.adamsrotors.com/
Old Dec 15, 2012 | 05:20 PM
5th Gear
the bottom bolt is half way stuck while i was trying to take it off, im gonna try to heat it up but i was just wondering if anyone had a link so i could get some prices
Old Dec 15, 2012 | 07:01 PM
sauceja's Avatar
Desert Life Sucks!!
rotors/pads = BRAKEMOTIVE
Old Dec 15, 2012 | 09:50 PM
anx1300c's Avatar
I'm assuming you're talking about the front caliper. If so, you've stripped the caliper threads. Happened twice to me; one hole on each caliper at different times. They're aluminum and don't mix with steel bolts. Acura should've put steel sleeves in the holes.
Regardless, you need to tap the stripped hole and install a new bolt. Be sure to use anti-seize on all four bolts.
Old Dec 16, 2012 | 02:32 AM
UA6's Avatar
UA6
Old Dec 16, 2012 | 11:48 AM
5th Gear
any idea what that thread size is so i can get a tap, im sure its an odd size
Old Dec 16, 2012 | 11:51 AM
5th Gear
also was wondering, because my car is a 6 speed does it use the same pads/rotors/calipers as the TL-S? i know they are different from the TL w/AT just want to be sure i get the right parts
Old Dec 16, 2012 | 12:53 PM
nfnsquared's Avatar
Do a search, someone here has already tapped it. Don't remember who.
Edit:
https://acurazine.com/forums/3g-tl-problems-fixes-114/brembo-stripped-caliper-thread-724300/
Post #5: 19mm M14 x 1.5 bolt
https://acurazine.com/forums/showpos...8&postcount=11
You're welcome
Old Dec 16, 2012 | 01:20 PM
nfnsquared's Avatar
OP, just curious. Did you use an impact wrench to remove the bolts?
Highly recommend not using impact/air wrench for these bolts.
and one more link (this one for heli-coil)
https://acurazine.com/forums/showpos...0&postcount=46
Old Dec 16, 2012 | 03:31 PM
5th Gear
no i used a 1/2 inch ratchet thanks for the info
Old Dec 16, 2012 | 03:59 PM
truonghthe's Avatar
make sure you go out and buy a 1 foot long metal pipe that should give you enough torque to unbolt it.
Old Dec 16, 2012 | 08:29 PM
Excelerate's Avatar
Former Sponsor
Here's a link to our drilled and slotted brake package.
http://store.excelerateperformance.c.../i-338784.aspx
The packages include Powerslot/STOPTECH performance rotors and STOPTECH Performance pads. All of the rotors have a black e-coating on the hubs and vanes and an advanced alloy composition. The Powerslot slotted rotors for the front of most Acuras also have a Power Alloy composition and a curved vane construction, which helps reduce heat in the brake system. The STOPTECH Performance pads are a para-aramid compound, which has great initial bite and long-term performance and lower dust and noise than most aftermarket brake pads.
mada51589
Jan 9, 2025 04:40 PM
kmawani
Feb 8, 2023 05:09 AM
obert
Dec 14, 2015 11:36 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
