New member! Brake Problem
Hey guys, just wondering if anyone knows a good place for a caliper and drilled and slotted rotors for an 05 tl with a 6 speed manual trans, theres a lot out for Automatics but i dont see much for manuals
Registered Member
http://www.excelerateperformance.com/
http://www.heeltoeauto.com/
http://www.adamsrotors.com/
Regardless, you need to tap the stripped hole and install a new bolt. Be sure to use anti-seize on all four bolts.
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
also was wondering, because my car is a 6 speed does it use the same pads/rotors/calipers as the TL-S? i know they are different from the TL w/AT just want to be sure i get the right parts
Edit:
https://acurazine.com/forums/3g-tl-problems-fixes-114/brembo-stripped-caliper-thread-724300/
Post #5: 19mm M14 x 1.5 bolt
https://acurazine.com/forums/showpos...8&postcount=11
You're welcome
OP, just curious. Did you use an impact wrench to remove the bolts?
Highly recommend not using impact/air wrench for these bolts.
and one more link (this one for heli-coil)
https://acurazine.com/forums/showpos...0&postcount=46
make sure you go out and buy a 1 foot long metal pipe that should give you enough torque to unbolt it.
Former Sponsor
Here's a link to our drilled and slotted brake package.
http://store.excelerateperformance.c.../i-338784.aspx
The packages include Powerslot/STOPTECH performance rotors and STOPTECH Performance pads. All of the rotors have a black e-coating on the hubs and vanes and an advanced alloy composition. The Powerslot slotted rotors for the front of most Acuras also have a Power Alloy composition and a curved vane construction, which helps reduce heat in the brake system. The STOPTECH Performance pads are a para-aramid compound, which has great initial bite and long-term performance and lower dust and noise than most aftermarket brake pads.
mada51589
05-03-2022 08:54 PM
