Need left rear LED light bar
Old Jan 26, 2016 | 05:06 AM
flwrngls's Avatar
2006 Acura RL @65k miles!
Hi ~~ Any suggestions on where to get an OEM LED light bar?
I need the left rear LED only. The red plastic covering and wiring are fine.
My mechanic suggested I look online because from the dealer, it is something like $330. not going to happen!
Thanks much!
Old Jan 26, 2016 | 08:50 AM
WDPanda's Avatar
Check you local listings for the complete tail light. Very rare to find just the LED strip. Ebay should have some as well. Some of the Craigslist listings will have accident cars for part out. If there is rear taillight damaged TL you could have it your way.
Old Jan 26, 2016 | 10:02 AM
Trav2390's Avatar
OP certain parts for our 3G tl's do not need to be OEM. The side markers are a perfect example. I have DEPO smoked rear side markers and they fit and work just as well as the OEM ones. I have been using them for over a year now and no problems. The smoked rear side markers look much better IMO as they match the front LED side markers. The Type s model TL's come from the factory this way. Use your broken side marker as the incentive to upgrade the look of your Acura for cheaper than OEM. Depo 04 05 06 07 08 Acura TL Type s Look Rear Smoke Side Marker Lights | eBay
Old Jan 26, 2016 | 10:12 AM
guitarplayer16's Avatar
Are we talking about the tail light LED board, or the rear sidemarker?
Old Jan 26, 2016 | 11:25 AM
flwrngls's Avatar
The tail light LED. The side markers are fine. Thanks for asking. 😊
Old Jan 26, 2016 | 11:27 AM
flwrngls's Avatar
Thank you. The side marker is not broken.
Old Jan 26, 2016 | 11:30 AM
flwrngls's Avatar
I hadn't thought of craigslist, thanks. Interesting idea.
Old Jan 26, 2016 | 11:49 AM
Trav2390's Avatar
Oh my bad I misread your post.
Old Jan 26, 2016 | 12:00 PM
GKinColo08TL's Avatar
Check the black market on AZ, or a local salvage yard, the 3G is old enough now there should be some available.
Old Jan 26, 2016 | 12:33 PM
flwrngls's Avatar
ok, thank you!
Old Jan 26, 2016 | 11:26 PM
flwrngls's Avatar
Smile
No luck with a local or regional salvage yard, unfortunately.
1) So, has anybody used go-parts.com ?
They have a:
2004-2006 ACURA TL TAIL LIGHT REAR LAMP - LEFT (DRIVER) (OEM #: 33551-SEP-A01) for $55.95 compared to an OEM LAMP UNIT on oemacuraparts.com for $126.71
Is it unadvisable to use a non-oem part in this case?
2) On oemacuraparts.com, what's the difference between buying
OEM LED UNIT, L. - 2004 ACURA TL (33552SEPA01) for $121.86
and the aforementioned OEM LAMP UNIT, L. - 2004 ACURA TL (33551SEPA01) for $126.71
I see the visual difference of the two, but on the LED unit, I'm not sure I'd be getting the LED light bar.
MANY THANKS!!
Old Jan 27, 2016 | 09:35 AM
it's not a "light bar" per se, it's an entire tail led board so you'd be replacing the entire board behind the tailight.
have you checked ebay for used ones?
Old Jan 27, 2016 | 11:53 AM
They have a:
MANY THANKS!!
Some of the aftermarket lights are great...Depo for instance. I changed the tails on my TL when I owned it to Depo TLs taillights and they fit great and looked great. If you don't do both at the same time you might have 2 different colr lights, which will look crappy. Try Ebay too as he said ^ there.
Old Jan 27, 2016 | 03:17 PM
flwrngls's Avatar
I'll check out Depo, thanks for the suggestion. I kinda think it's worth it to do both anyway, since the bumper has to come off. I can't believe 'they' would design a car that way - it's predatory to make consumers have to spend more money!
I'll check again on eBay. I hesitate to get used ones b/c I don't want them going out anytime soon.
Old Jan 27, 2016 | 03:20 PM
flwrngls's Avatar
[QUOTE=thoiboi;15666883]it's not a "light bar" per se, it's an entire tail led board so you'd be replacing the entire board behind the tailight.
Thanks for clarifying this. You cleared up my confusion. My mechanic was calling it a light bar so no wonder I couldn't find it anywhere.
Old Jan 27, 2016 | 03:22 PM
Oh i'm sorry , I didn't read the post properly
Lamp: the outside plastic housing
LED Unit: the part that actually lights up (with the electricals): a la what you need
Old Jan 27, 2016 | 03:23 PM
When G is talking about the Depo lights, he's just referring to the lamp/housing.
I'm not sure if DEPO has a aftermarket LED board.
Old Jan 27, 2016 | 03:30 PM
flwrngls's Avatar
Yes, this is what I need. The plastic housing is still good. Oh, this is perfect, thanks so much for sending both of these images!!
Old Jan 27, 2016 | 03:34 PM
flwrngls's Avatar
This looks like it, then....
LED UNIT | Genuine Acura | 33552-SEP-A01
Old Jan 27, 2016 | 03:43 PM
Check out acuraoemparts.com or oemacuraparts.com
They're our vendors so might be cheaper
Old Jan 27, 2016 | 03:57 PM
flwrngls's Avatar
LED UNIT, L. for 2004 Acura TL|33552-SEP-A01
Old Jan 27, 2016 | 04:02 PM
flwrngls's Avatar
oemautopartz.com is $10 less. Thank you though!! :-D
Old Jan 28, 2016 | 11:09 AM
Glad you found what you need...rock on!
Old Jan 28, 2016 | 09:54 PM
flwrngls's Avatar
Thanks!! I actually got a used LED for $60 on eBay after all.
Grateful to have saved so much. Thanks for everyone's help. Much appreciated!
Rockin' on!
Old Jan 28, 2016 | 10:23 PM
AckTL05's Avatar
Former Sponsor
Damn, too late. I had a used one for sale 50$ shipped, $90 shipped for both.
Old Jan 28, 2016 | 11:36 PM
LaCostaRacer's Avatar
Did your mechanic check the electrical pins for the tail light or just guess that you need a new board? The reason I ask is I also guessed and found that I had a broken wire instead. You need to remove the felt trunk liner to get to the connectors so hopefully your mechanic used a multimeter to reach this assessment.
Feb 20, 2019 08:58 AM
bradntx
Jan 31, 2016 12:54 PM
jonnyj32
Jan 28, 2016 10:26 AM
vpasla1
Jan 14, 2016 07:47 PM
DDTsx06
1G RDX Tires, Wheels & Suspension
Jan 9, 2016 04:51 PM
