Need Help Securing Type S Spoiler
Old Mar 28, 2014 | 02:10 AM
hostile429's Avatar
i had some dipshit take my spoiler off my tl and prior to that they used automotive adhesive to secure it onto my trunk... well that failed
well lucky for me i found another one for $150.
ok i found the bolts clips and etc
27, 31, 4, 26
so my thing is theres 7 holes in the spoiler and the diagram is confusing me.. whoever done this before point me to the right direction please... and thanks
Old Mar 28, 2014 | 03:21 AM
paperboy42190's Avatar
whats so confusing about it? I just installed my decklid spoiler couple hours ago. it was super easy. theres 2 threaded bolts(#4), 2 clips(#31), and 3 white stick things(#27). this adds up to 7 attachments to the spoiler.
The 2 bolts have 8mm nuts(#26) that attach from inside the trunk, the 2 clips pop into the 2 holes on the trunk, and the 3 white stick things line up into the 3 yellow grommet things
and factory uses 4 strips of small double sided tape, less than 1" in size. If you look carefully on the spoiler you will see the markings to place the tape. there is absolutely no need to use adhesives and excessive tape if you use all the factory clips and bolts. with the bolts in place, you would have to break the spoiler before taking it off
Old Mar 28, 2014 | 04:19 AM
hostile429's Avatar
well reason why i ask because i have a base tl with no hole marks whereas the type s has..
so soon ill take it to a shop to get it drilled and line up the markings
but thanks paperboy
Old Mar 28, 2014 | 05:14 AM
Ahh I see. I do recommend drilling the holes so it mounts like factory.
Old Mar 28, 2014 | 06:54 AM
Turbocoop's Avatar
Does anyone know by chance if the Aspec came with the holes drilled for the lip spoiler like this? Im about to take mine off and I dont want to break it.
Old Mar 28, 2014 | 09:38 AM
EvilVirus's Avatar
OP this is something you are going to have to measure and create your own template. I made mines out of cardboard and I only drilled where the bolts go (trunk end). The rest are clips IIRC so I didnt bother with that. I use the arcylic 3M doublesided tape and super bond adhesive on the nuts where I tighten to the bolts.
Oh sorry that some faggot decided to take what doesnt belong to him
Turbo - If your car came with the A-spec package from the factory at the time of purchase; there was the option of having a deck lip spoiler or wing attach to the trunk. If so, then you should have the holes in place.
Old Mar 28, 2014 | 10:31 AM
nate_0022's Avatar
Land of 10,000 lakes
I ordered the extra 5 studs and nuts to replace the white and green clips. You will need to widen some of the holes to place the studs in though. I haven't had time to install it yet plus I'm scared to start drilling into my trunk lid. May just bring it to the body shop and have them do it.
Old Mar 28, 2014 | 03:32 PM
EvilVirus's Avatar
^ This is coming from the guru guy of headlights BS you can do it.
Hey I made an extra hole because I was off by 1mm. Guess what no worries as I just bondo and dab some paint on it and the spoiler ninja the rest. I have no plans on removing it.
Old Mar 28, 2014 | 03:34 PM
EvilVirus's Avatar
Turbo I also forgot to mention. You can check if you pull back the trunk lining and locate the bolts and clips.
Old Mar 29, 2014 | 01:42 AM
tl-frank's Avatar
☆New England Patriots☆
Wow they just went up and ripped it off? Some people these days best of luck with your next spoiler
Old Mar 29, 2014 | 09:26 AM
EvilVirus's Avatar
Sadly its been pretty common on trunk and roof spoilers to be stolen.
Old Mar 29, 2014 | 10:22 AM
tones160's Avatar
[x] FWCC [x]
I'm surprised they haven't taken mine yet but i don't have the type-s one. I have the M3's trunk lip spoiler thieves stay away from it since it's very very difficult to take off
Old Mar 30, 2014 | 01:47 AM
Look from inside the trunk, behind the liner. If there are bolts and nuts used, you will see them.
o8 ENVII 8o
Nov 30, 2015 04:23 PM
mugen_kid
Nov 13, 2015 10:38 PM
MonkeyTrucker
Oct 9, 2015 07:53 PM
spoiler900
5G TLX Photograph Gallery
Sep 11, 2015 09:39 PM
