Need Help Securing Type S Spoiler
![](http://www.acuraautomotiveparts.org/acura/jsp/mws/catimgs/14sep801_b5510.png)
i had some dipshit take my spoiler off my tl and prior to that they used automotive adhesive to secure it onto my trunk... well that failed
![](http://farm3.staticflickr.com/2878/13461851023_f8f165f673_c.jpg)
well lucky for me i found another one for $150.
ok i found the bolts clips and etc
27, 31, 4, 26
so my thing is theres 7 holes in the spoiler and the diagram is confusing me.. whoever done this before point me to the right direction please... and thanks
whats so confusing about it? I just installed my decklid spoiler couple hours ago. it was super easy. theres 2 threaded bolts(#4), 2 clips(#31), and 3 white stick things(#27). this adds up to 7 attachments to the spoiler.
The 2 bolts have 8mm nuts(#26) that attach from inside the trunk, the 2 clips pop into the 2 holes on the trunk, and the 3 white stick things line up into the 3 yellow grommet things
and factory uses 4 strips of small double sided tape, less than 1" in size. If you look carefully on the spoiler you will see the markings to place the tape. there is absolutely no need to use adhesives and excessive tape if you use all the factory clips and bolts. with the bolts in place, you would have to break the spoiler before taking it off
well reason why i ask because i have a base tl with no hole marks whereas the type s has..
so soon ill take it to a shop to get it drilled and line up the markings
but thanks paperboy
but thanks paperboy
OP this is something you are going to have to measure and create your own template. I made mines out of cardboard and I only drilled where the bolts go (trunk end). The rest are clips IIRC so I didnt bother with that. I use the arcylic 3M doublesided tape and super bond adhesive on the nuts where I tighten to the bolts.
Oh sorry that some faggot decided to take what doesnt belong to him
Turbo - If your car came with the A-spec package from the factory at the time of purchase; there was the option of having a deck lip spoiler or wing attach to the trunk. If so, then you should have the holes in place.
Turbocoop (03-28-2014)
Land of 10,000 lakes
I ordered the extra 5 studs and nuts to replace the white and green clips. You will need to widen some of the holes to place the studs in though. I haven't had time to install it yet plus I'm scared to start drilling into my trunk lid. May just bring it to the body shop and have them do it.
[x] FWCC [x]
I'm surprised they haven't taken mine yet but i don't have the type-s one. I have the M3's trunk lip spoiler
thieves stay away from it since it's very very difficult to take off
mugen_kid
11-13-2015 10:38 PM
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
