Nav System Problems
Old 03-26-2004 | 11:18 AM
TedH's Avatar
5th Gear
Nav System Problems
Nav System is not working. Msg states Hard Drive must be reformatted, See Dealer. This happened about a year ago and system recovered and continued to work. Do I have to take it back to the dealer or is there something I can do to fix the problem. The last time I contacted the dealer they wanted $400 to fix it. This seems a bit price. Any suggestions appreciated.
Old 03-26-2004 | 12:40 PM
TLGator's Avatar
Sounds ugly. But what does it mean by hard drive? Is there a hard drive in the unit as well as the DVD? I always assumed the boot-up system was just a bunch of chips.
Old 03-28-2004 | 11:27 AM
ronvanr's Avatar
hard drive
Try going to ebay and purchasing a new hard drive there, it’s cheap, easy and you’ll get the most up to date map for your region.
Old 03-29-2004 | 01:32 PM
TedH's Avatar
5th Gear
ronvanr
Thanks very much for the info on NavSys hard drive. I'll surely give it a try.
TedH
Old 03-29-2004 | 02:06 PM
Xpditor's Avatar
Isn't your Nav system under warranty?
Old 03-31-2004 | 10:02 PM
ou sig's Avatar
Boomer SOONER
Mine says the same thing...I got a new drive and it didnt do anything!!! I am talking to someone about this now - he is trying to get some inside info on these systems since Acura isnt supporting them anymore at all - if you ask me. I have been to countless dealers and none of them no a damn thing about it - pisses me off.
Old 03-31-2004 | 10:24 PM
rets's Avatar
Moderator Alumnus
Question
Your 04TL or 99TL?
Old 04-05-2004 | 04:33 PM
TedH's Avatar
5th Gear
Nav System Problem Resolved
I posted a msg on 3/26/2004 about problem ie msg stating the hard drive had to be taken to the dealer to be reformatted. I was concerned about the various price quotes from dealerships to fix the problem. I would like to thank those who responded with some good advice.
The bottom line is that I took it to the dealership ( Crown Acura, Clearwater, Fl) and they reformatted the disk in less than 30 minutes and it's up and running again. The cost was 75.00 plus tax. What a relief. When this same problem had ocurred about a year ago a dealer in Ft Myers, Fl wanted $400 to fix it. The system corrected itself and was good for the next year. This time I checked the parts dept on a price for new hard drive....$1300.
I use the Nav System for my work and it is a real time saver. However, I think some dealerships will put a real squeeze on your wallet it you have any problems. It pays to shop around. I still don't know what caused the problem and would be interested to know if a non dealer tech could correct the problem or if Acura puts out a manual which would allow you to fix it.
Old 04-05-2004 | 04:50 PM
TedH's Avatar
5th Gear
Nav System Problems
Just to let you know that I took the 99TL into the dealership and they reformatted the hard drive at a cost of $75 which I consider fair. I hope you can resolve your problems.
TedH
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
koju01
ILX Audio, Bluetooth, Electronics & Navigation
12-14-2015 02:17 PM
brandnewcolony
09-12-2015 10:39 AM
chrisr
5G TLX Problems & Fixes
08-31-2015 08:24 PM
Quick Reply: Nav System Problems
