My 2007 CBP TLS!!! (issues and questions)
BrownBuck
What's up everyone. Fairly new on the board, forgive me i will ask tons of noob questions. I'm pretty much a virgin when it comes to car issues especially a luxry car.
By brownbuck at 2012-04-15
By brownbuck at 2012-05-08
Okay! so here are some questions, thanks in advance!
This might not be a horrible issue, but is this part replaceable? it's the little rubber seal that runs across the under hood right by the windshield. No clue how this happened..but as you can see there is a bit cut in it.
This has been a issue with few of you i've read so far...but has anyone found a fix for it? I hit a fin' curb when i was pulling up close to the sidewalk so my buddy could get in. BLAH
And last but not least, this one is prolly really dumb. But you gys see the i's on the map? the manual says they are exit info...how the hell do you look it? you can't do it with the lil + that appears with the joy stick i tried that already.
Chapter Leader
(Northeast Florida)
(Northeast Florida)
http://img851.imageshack.us/img851/9103/imag1017.th.jpg[/IMG][/URL]
The rubber seal is replaceable. Let me check the part number. Maybe part #11 below:
http://www.oemacuraparts.com/find-pa.../ENGINE%20HOOD
BrownBuck
The link doesn't work. But i think this is what u are talking about right?
http://www.oemacuraparts.com/product...sep-a00-acura/
Thanks man! much appriciated. So you think the dealer might have someone who fixes it? cool i'll have to check it
OH and i wanna get rid of that rust real bad...it's pissin me off. I would probably have to take off my tire to do that i'm guessing...but what would i get rid of the rust with?
Here's a pretty great video DIY on fixing curb rash on wheels. The only problem I can see with this though is that it might be difficult to find a paint that matches the dark gray finish on your TL-S wheels.
BrownBuck (05-08-2012)
http://www.youtube.com/watch?v=CDfnui1M4OE
Anthracite Metallic touch up paint from Acura is a close match!
BrownBuck
wow that's cool....except i don't understand half the stuff they said lol...
Okay so
-cloth
-greaseand wax cleaner
-sandpaper
-paint
What kind of fillers are those? Have you seen them or used them before?
oh and here is a bigger image of the third question...
By brownbuck at 2012-05-05
Whata hell r those lil i's?!? manual says exit information but what kind of info and how do i look at it? the lil + you get when you move the joystick isn't giving me any info when i put it on the i and press down.
I believe the two question marks you had were polyester body filler (that creamy stuff in a can they called "bog" in the video, which is commonly referred to as "bondo" here). This stuff is widely available, just go to any auto parts store like Napa and ask for bondo or plastic body filler.
The second thing is filler primer, which is also widely available. Just look in the section of your local auto parts store with all rattle can spray paints and you should be able to find some.
i's might be points of interest, or some sort of information...
about the rust, that's a rusty hub...you can remove the wheel, sand that thing down and spray with high temp paint, or you can spring for some brakemotive or xlr8 zinc coated brake rotor packages!
My method is a QUICK fix for the wheels...but I used my dremel with a grinding wheel on it and grind down the ridges of the curb...clean it all really well and then use duplicolor wheel paint sprayed into a can bottom and apply it with an artists paintbrush. Good enough to not have your eye go straight to it. All 4 of my wheels were curbed almost all the way around...
Welcome to the forum. If I didn't already have my 04...Carbon Bronze type S would be the 3G car of my dreams!
The following 2 users liked this post by rockstar143:
Guiltyox (05-09-2012),
Undying Dreams (05-09-2012)
BrownBuck
Yeah, they're Australian so they're sometimes hard to understand.
Looks awesome man....i am thinking about using some crazy sandpaper on it right now. But i'll consider some drill attachments if i have a real hard time with the sandpaper.
Chapter Leader
(Northeast Florida)
(Northeast Florida)
Oh, and Brownbuck, that's me in the first link that LoveMyTL-S gave you.
Jacksonville ain't Florida! It's an extension of Alabama!
Good luck, man...easy fixes, I'm sure...
about the damaged seal from the engine bay...google acurazine and ultimate cooling mod...you might not even want the cowl on there after you read that.
BrownBuck
yah it says exit information in the owners manual. but when i click on them with the lil red target lookin thing all i get is information i would have gotten if i clicked close to that icon about what's in the area. Is that all it is? lol
I would start with a sanding block, not a dremel, to fix the rash. That way you know you're getting a flat line and not making it too wavy...
BrownBuck
You are talkin about the rims right? I talked to few of my friends and they all said they might know some dude who the dealships use to fix wheels...so i'm looking into that right now. If it's 75-100 for both wheels i might do it.
If it's $100 or less for both wheels then yes, let someone else do it.
Received 6,470 Likes
BrownBuck, welcome to AZ.
In the lower right hand corner of each post, the middle icon is a Multi-Quote button. This allows you to reply to more than one person in a single reply.
Be sure to check it out!
BrownBuck
Yah that's what i was thinking...i called and left a message...NADA yet
Wheel Medic downtown will take care of you pretty well.
BrownBuck
No problem man. I knew they would be pricey. I just recommended them because I know they do an amazing job.
wusty23jd
09-24-2015 11:41 AM
