memory seats simple question
I know this question was asked multiple times, but I have a hard time using search option. I just wonder if a light by memory switch 1 or 2 should be lit all the time or not? Thanks
an Acura has-been
Originally Posted by mlody
Does it stay untill you shut off the engine/turn off the ignition? or does it come up for couple sec and the led turns off?
Tell your dealer, this was only for TLs built in the first 6 mo or so of production for the 04 MY (which from your sig you have).
See the 3rd Gen Garage for more details.
Originally Posted by need4spd
If the LED is turning off, you probably still have the old memory module, there is a TSB where they replace it since it looses the memory and sometimes reappears, and the LED turns off when it looses its memory (I had this issue, that is why I know).
Thanks guys for responses. My memory seats work just fine – I just wasn’t sure if either light (memory 1 or 2) should be lit all the time when driving – I know that when I readjust the seats when driving the light goes of, but the settings are not saved automatically (I have to save new settings)
BTW i would prefer the light to be off all the time
Regions Leader
Regions Leader
Originally Posted by acuraTL44
Yes, you have to save the new settings by pressing the mem. buttom then pressing you number. This is good because if somebody else is driving the car, other than the normal two drivers, they can set the seat or mirrors anyway they like, but those setting will only stay until driver 1 or 2 unlocks the car again.
so simple but yet so cool..
AZ Community Team
One last thing about the memory lights.
As soon as you adjust the drivers seat with the controls on the side of the seat the light also goes out. Indicating that the seat is no longer in that memory position. Haven't noticed if changing the side mirrors does it also, suppose it does.
rockyboy
12-06-2022 02:29 PM
wusty23jd
09-24-2015 11:41 AM
