Loud noise with back windows open
Old Aug 9, 2004 | 09:07 AM
bostongt's Avatar
I was driving with some friends this weekend, and noticed a problem that I was wondering if anyone else has it, and if there is a solution.
I had all my windows closed while driving on the highway. A friend in the back seat opened the back window, and the entire car made a LOUD noise, vibration. Due to the wind, it sort of sounded like the bass turned up to 100X. It was so bad I had to pull over, since I thought there was a problem with the car.
I then went to test it out, and could reproduce this at will. If I drive over 35, and open the back windows only.. the car makes an ungodly noise. If I crack the front window a little, then it goes away.
Has anyone else noticed this?
thanks.. and sorry if this is already addressed somewhere.
Old Aug 9, 2004 | 09:15 AM
rets's Avatar
Moderator Alumnus
Welcome to the club.
Due to dynamic design of the car, this seems normal to me. The loud loud noise in high speed. You could try to search this forum, there should be lots of threads discussing more about this issue.
Old Aug 9, 2004 | 09:19 AM
leeherman's Avatar
Supreme Underlord/Abyss
I complained about this just after I got my car.
I spent a few minutes this weekend driving the TL with the front windows and moonroof open. I couldn't take it for very long and closed the windows and turned on the a/c.
I drove my '99 Toyota Solara yesterday with windows and moonroof open, stereo cranked, and it was quite nice.
It's definitely something about the shape of the TL that causes the turbulance. I don't like it, but it's not like I'd not have bought it if I'd known. I love the car otherwise!
Regards,
Old Aug 9, 2004 | 09:21 AM
TBone2004's Avatar
Team Anthracite Member
Yep - we had a discussion in another thread about this - or a complaint session really.
Its kinda like back in the day of the Six-Million Dollar man episodes, where our Hero, Steve Austin has to walk through that white spinning tunnel thing and it makes that awful, skull splitting sound. Yep - have it so I do not put the windows down in the back for fear of rupturing something or getting sucked out of the car.
Xpditor's Avatar
What he ^ said...
Same comment as rets...
Opening the rear window creates a venturi effect making a vacuum in the car's interior which builds and then releases sounding like the whole car is a big bass drum because there is no place air can come in to replace that removed by the low pressure - until you open a front window.
It is normal and quite common with most cars that are aerodynamic. I suspect that opening the moonroof might also relieve the pressure differential.
XP
Old Aug 9, 2004 | 04:07 PM
tizo's Avatar
www.teamultraspeed.com
Originally Posted by Xpditor
...I suspect that opening the moonroof might also relieve the pressure differential.
XP
...just push the moonroof-tilt button and it all goes away...
Old Aug 9, 2004 | 04:34 PM
Dirac's Avatar
I noticed this with moonroof open and back windows open (fronts closed). Figured I could live with A/C after that. I thought my rear deck was going to tear off and flip up across my rear window.
Old Aug 9, 2004 | 07:04 PM
finishline's Avatar
XP
OMG! Venturi Effect! Now I can't stop thinking about Lisa Lombardi who sat in front of me in 6th grade science class.
The TL is not alone in being subject to THE VENTURI EFFECT. My Jeep does it. They've discussed it on a few of the Infiniti vehicle boards.....
Old Aug 22, 2004 | 09:45 AM
Rabney's Avatar
My wife's 2000 Toyota 4 Runner does it to with just a rear window open.
Old Aug 22, 2004 | 10:36 AM
nick04tl's Avatar
i think every 4 door car does this. my 94 max did this as well.
Old Oct 13, 2004 | 08:52 AM
JRock's Avatar
Old timer
Yeah, apparently someone's never owned a sedan before. :-P
omg bump
Old Oct 13, 2004 | 10:18 AM
Champcar1's Avatar
It happened on my 92 Accord as well. You ought to hear my wife's 2000 Cherokee at about 70mph with the back windows down!
Old Oct 15, 2004 | 10:44 PM
Dafried's Avatar
Enthusiastic Newbie
1992 4Runner exhibits the exact same behavior.
There are so many windows, however, that you can open the back, sunroof, or one of the other four windows and relieve the internal pressure.
Those of you who are old enough to remember when it was easy to close a car door without cracking a window should understand. Even a crappy-built modern car is more airtight than old cars.
Just my .02
Old Mar 5, 2013 | 06:21 PM
warjat's Avatar
6th Gear
If you open another window in the car, it helps to alleviate the issue.
Old Mar 5, 2013 | 06:30 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Holy 8+ year old thread revival...........
ez12a's Avatar
the overexplainer
this is a really old thread, but it's because a vacuum is created when a rear window is opened with all others closed.
edit: lol just read the answer was given mid way through the page. I have a bad habit of just reading the OP.
Old Mar 5, 2013 | 06:39 PM
LOL at some one complaining about this.
Old Mar 5, 2013 | 08:31 PM
IamaTL's Avatar
I like turtles
twas a good read
Old Mar 5, 2013 | 09:37 PM
dannyz's Avatar
TLicious Type S
Thankfully this is no longer a problem. Back in the old days of the last decade when this thread was started, the air was much thicker.
Now in modern times with our TLs, it's smooth sailing! :-)
(This thread wasn't just revived--it was exhumed!)
Old Mar 6, 2013 | 07:14 AM
^the fuck does that mean!?
lol thicker air?
doesnt happen with the TL? LOL
it does happen to the TL.
Old Mar 6, 2013 | 07:33 AM
anx1300c's Avatar
Lol, he was joking.
Old Mar 6, 2013 | 07:46 AM
I didnt have my coffee yet.
Old Mar 6, 2013 | 08:20 AM
zachlone's Avatar
I have noticed this in alot of vehicles these days and there really is no way to cure it other than just roll the front windows down. it sucks
Old Mar 6, 2013 | 08:31 AM
Undying Dreams's Avatar
Holy shit, Justin got trolled!!
This thread is so dumb
Old Mar 6, 2013 | 08:33 AM
Franchise1124's Avatar
Old Mar 6, 2013 | 08:45 AM
Acura_Dude's Avatar
David_Dude
Old Mar 6, 2013 | 09:26 AM
350's Avatar
350
My first ricer
Why do I hear wind noise with my windows down? This is the worst car I've ever owned please help me I'm at my wits end. If I put Dynamat over the window openings will the noise go away?
Old Mar 6, 2013 | 09:41 AM
Steven Bell's Avatar
Really, don't you guys have anything better to do than play around in a thread from 2004?
Warjat, welcome to Acurazine. We try not to re-open threads this old. It gives Justin ideas..........LOL
Thanks.
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
mazen222
Oct 27, 2015 12:01 AM
ahsm
Sep 9, 2015 08:35 AM
dlknight
Sep 3, 2015 07:54 PM
