Locking combo
Old Apr 15, 2004 | 05:35 PM
moreace's Avatar
Anthracite Trend Setter
Locking combo
Is it possible to have it so when you unlock the car, only driver door unlocks then press again for the rest of the doors AND when you auto unlock the doors after driving (car is put in park for me) all doors unlock and not just drivers?
Old Apr 15, 2004 | 05:46 PM
zeezz's Avatar
Team Anthracite Webmaster
i think so... arent' they seperate options?
Old Apr 15, 2004 | 05:50 PM
w1n78's Avatar
100k miles club
i think you can set it on the keyless entry settings on the MID
Old Apr 15, 2004 | 05:52 PM
rynpamn21's Avatar
That's the default setting. Fool around with the Keyless settings in the MID. Or better yet RTFM
Old Apr 15, 2004 | 06:25 PM
moreace's Avatar
I tried, I can do one or the other at one time
Old Apr 16, 2004 | 03:32 PM
TLGator's Avatar
The answer is no. The auto-unlock setting unlocks the doors according to the setting for a single push of the keyfob.
Old Apr 16, 2004 | 03:37 PM
i thought i had it where my door unlocked out of park, but all other doors remained locked unless you manually hit the unlock button.
my keyless system is fucked now though, i need to take it in so i'm not sure.
Old Apr 16, 2004 | 03:39 PM
kilrb's Avatar
That is one of the options available when you decide if the car is to unlock when put in park. You can either choose to not have it unlock at all, unlock only the driver's door, or unlock all. Don't know about the single vs. double button thing, though.
Old Apr 16, 2004 | 03:52 PM
TLGator's Avatar
OK...
From the MID, you can choose to have the car unlock when put in park, unlock when you turn off the ignition, or do nothing. Whether that unlock function targets the driver's door only or all four doors depends on how you have the keyfob set.
So, if the keyfob is set to unlock the driver's door only on the first push, and you set the car to unlock when in park from the MID, the unlock in park will be the driver's door only.
No way that I know of to unlink the keyfob choice from the MID choice.
This seems hard to explain, hope I made sense.
Old Apr 16, 2004 | 03:58 PM
caball88's Avatar
Originally Posted by TLGator
OK...
he's right there is no way to get it work the way you want to. i wanted the car to react the same way to my key fob and ignition off but the MID setting for the unlock feature dictates how the key fob and ignition off will work. i tried just about every combination with no luck.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
