Light installation help!!
Old Jul 30, 2011 | 10:54 PM
typeS219's Avatar
i just bought a set of red lights for my trunk and some for the doors of the car......can any give me a guideline to follow to install these?
Old Jul 30, 2011 | 11:15 PM
SpiderX1016's Avatar
Use a butter knife or something and pry the lens off.
Old Jul 30, 2011 | 11:36 PM
guitarplayer16's Avatar
The doors lights are easy to get to; there are notches in the side which you use a flathead screwdriver to pry open a little bit, then use your fingers to pull them off.
Old Jul 30, 2011 | 11:38 PM
typeS219's Avatar
thanks....and do u know anything about the lisence plate???
Old Jul 31, 2011 | 12:03 AM
Bearcat94's Avatar
AZ Community Team
DIY's with Service Manual scans in this thread.
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
For example:
G-052: DIY: Replacing License Plate and backup light Bulbs
https://acurazine.com/forums/showthread.php?t=105472
https://acurazine.com/forums/showthread.php?t=125207
https://acurazine.com/forums/showthread.php?t=124574 Backup light replacement
Old Aug 23, 2011 | 11:23 AM
sourial84's Avatar
All you guys are awsome this thread has been a big help just finish my led interior conversion now waiting on the reverse lights to come on so i can change everything in the back all at once
Old Aug 23, 2011 | 01:23 PM
garrett's Avatar
please tell me your not putting red lights in the license plate lights.... not to mention thats illegal as hell in all 50 states. Youll get pulled over in less then a week if you make it that long.
especially in NY.
Old Aug 24, 2011 | 10:39 PM
customade's Avatar
8th Gear
Hi everybody. I'm new to this site, so this might sound off. Can anyone tell me what I need to install HID lights for Acura Tl 05? Do I just need to but the bulbs or is there anything else to it?
Old Aug 25, 2011 | 07:04 AM
CesarRod's Avatar
I didnt want to type new instructions so i took it from another site.
Disconnect your TL negative battery terminal
Disconnect and remove your stock headlight bulbs from the harness
Install the new HID light bulbs into your TL 3.2's headlights. Be sure to use clean rubber gloves or avoid touching the glass on the HID light bulbs. Dirt or oil left on the glass of the bulb could cause the xenon gas to overheat and blow up the bulb. Lock the HID light bulbs into place.
Connect the stock wiring harness from your TL 3.2 to the corresponding plug (or plugs, depending on your bulb type) on the HID Light Bulbs.
Connect the remaining 3 plugs to the corresponding plugs on the HID Ballast.
Find a place to mount the ballast where it will be stable, away from heat, and not touch any moving parts in your TL 3.2's engine bay.
Use the included installation brackets, zip ties, or double sided tape to mount the ballast in place.
Reconnect your TL 3.2's negative battery terminal.
For HID lights installed into your headlights, aim your headlights down so that the TL 3.2 HID kit will not blind others drivers in front of you. Please see your TL 3.2 owner's manual for head lamp aiming instructions. Aiming may also be necessary for HID Fog Lights.
ENJOY A SAFER DRIVE WITH YOUR NEW SUPER BRIGHT HID LIGHTS!
will this be your first mod? just curious
Old Aug 25, 2011 | 10:53 AM
customade's Avatar
8th Gear
Yes it will be. This and led lights for the interior. By the way thanks alot.
Oh and can yu tell me some gud website to buy the HIDS from?
Old Aug 25, 2011 | 10:58 AM
SharksBreath's Avatar
BANNED
http://www.ddmtuning.com
Old Aug 25, 2011 | 01:30 PM
jimsta's Avatar
NTMD8
Custom, just to clarify, the 05TL comes with stock HIDs, are you looking to change the Fogs to HIDs? or if you want a difference color, you can change the bulbs as well, without getting the HID system.
Old Aug 25, 2011 | 03:44 PM
customade's Avatar
8th Gear
Oh, I didn't know that. So that means I just have to buy a different color?
I want cool blue. Will those look gud? There are alot of options, don't know which one to pick.
Old Aug 25, 2011 | 04:13 PM
vietxquangstah's Avatar
if you really did put red, or attempting to put red, in your license plate lights, you truely are a kid....well no shit it clearly says your age is 18, but still.... you can be 18 and avoid doing childish color mods as such.
not just you, but to anyone that has or even thought about putting BLUE or RED leds in the rear license plate.
really? grow up
"but it looks so cool!!!" /facepalm
Old Aug 25, 2011 | 05:14 PM
customade's Avatar
8th Gear
http://cgi.ebay.com/ebaymotors/10000...mZ130514733846
Is this a good buy?
http://www.xenonheadlights.net/HID+B...ID+Bulbs/2835/
Or this? Looking for 10000K.
Old Aug 25, 2011 | 06:08 PM
Steven Bell's Avatar
Customade, first, welcome to Acurazine.
Second, in the lower left hand corner of each posting, the middle icon is a multi-quote button. This allows you to response to more than one person in a single posting!
Cheers....
Old Aug 25, 2011 | 06:46 PM
Originally Posted by customade
I wouldn't do anything more than 8000k
Old Aug 27, 2011 | 03:24 PM
ohsixMTee's Avatar
Early Shifter
Agreed, not only will it look odd but light output will be sacrificed.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Nicho863
Sep 2, 2015 08:12 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
