Light Help
Old Jan 5, 2012 | 12:43 PM
lamonicas33's Avatar
Light Help
So im new with the whole mod scene so I need some help with my lights. I have a friend who told me some good lights to buy and all that but Im starting to get nervous that i might have screwed up a bit. I have a 2008 TL.
For the Fog Lights I got- Hipro Power Xenon HID Fog Light Bulb.
I got switchbacks from v-leds.com- Type 2 Dual Color Changing 5K White Amber 60 Turn Signal
And here is what is getting me nervous. For DRLs I got: Putco Pure 9005 Halogen Lights.
So the question I have is can I just switch the bulbs and be good to go, or do I need a kit. Any help would be much appreciated. I would like to do it myself so i can learn.
Old Jan 5, 2012 | 02:24 PM
xander569's Avatar
My First Acura
When you upgrade to real HID lights you need a kit. Anything else should be plug and play as long as get the right size.
Old Jan 5, 2012 | 02:32 PM
LoveMyTL-S's Avatar
The 9005 is correct for the DRL bulb. Plug n play.
Old Jan 5, 2012 | 02:53 PM
thank u guys I really appreciate the help
Old Jan 6, 2012 | 02:36 PM
kane337's Avatar
2007 Acura TL
I am looking to upgrade my lights also.
For clarification...the headlights require the kit and all others (i.e fog, DRL, etc) are plug n play?
Old Jan 6, 2012 | 02:39 PM
nate_0022's Avatar
Land of 10,000 lakes
The headlights don't require any sort of kit. If you're ordering anything other than a 35w D2S bulb then you'll need to get new ballasts to support a higher watt bulb.
Foglights, DRL's will need an HID kit along with a new wire harness if you're going the HID route. If you're staying halogen then you need nothing but the bulb.
Old Jan 7, 2012 | 06:42 AM
CesarRod's Avatar
Just get this for your DRL's http://www.jlclightings.com/9005-LED...-p/sku_066.htm 98 SMD. I remember a member was comparing this product to the cree one with great pictures but i can't find it for you. Maybe if someone else can post the link for you
Old Jan 7, 2012 | 06:43 AM
CesarRod's Avatar
also this won't give you an ERROR code in your dash
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
