License Plate Light Question
Old Jul 20, 2006 | 12:53 AM
mrn970's Avatar
I am looking to change out my lic plate lights for LED's I was wondering what type of bulb has anyone else used and where did you buy them from. I was think about going with 7443 12 or 15 LEDs. I am not sure which one to go with. I would also like to replace my backup lights as well.
Old Jul 20, 2006 | 01:06 AM
tmph's Avatar
12 or 15-LED will not work
Old Jul 20, 2006 | 07:47 AM
Andrew McCarthy's Avatar
I used the same LEDs that I used for the interior dome lights for both the plate and backup lights.
Old Jul 20, 2006 | 08:41 AM
ding069's Avatar
acura-cl.com OG
i use PIAA 2 LED's and IMO they are perfect. not too much light and perfect white coloraiton. the raybrigs i have are too blue and slightly brighter.
Old Jul 20, 2006 | 09:11 AM
rimz's Avatar
now with four rings
i used the hyperwhite 9LED lights from tec-toyz...and they look sweeeeet... ...gives off an extremely nice white w/ tint of blue look and looks great at night...
Old Jul 20, 2006 | 09:43 AM
leedogg's Avatar
RAR
The 7443 is a turn signal LED. You need a 921 for both the license and reverse lights
Old Jul 20, 2006 | 03:43 PM
Zoser's Avatar
Same here.
Zoser
Old Jul 20, 2006 | 06:08 PM
brianp6621's Avatar
And mod edit in 3....2....1....
Old Jul 20, 2006 | 08:39 PM
holybear's Avatar
B A N N E D
Alright, now. You can do a SIMPLE thing called "Search" taht will give you MANY threads on the same exact topic. I have no means of bashing. Thanks.
Old Jul 22, 2006 | 07:33 PM
Anyone had problems with their tec-toyz lights flickering?
I noticed today when I unlocked the car that one of my license plate bulbs is flickering and I'm wondering if it's a bad bulb or maybe a bad connection. I'm guessing bulb since it's a constant flicker.
Old Jul 22, 2006 | 08:03 PM
ding069's Avatar
acura-cl.com OG
i had a genaric set of ebay led bulbs that had that problem. what happens is that they have a small circuit board within the housing and it goes bad. i upgraded to the PIAA's and have had no problems. i figure they put more R&D into their bulbs than most.
Old Jul 22, 2006 | 10:50 PM
xtin's Avatar
Doctor Sarcasm
yeah it does. I have 12LEDs
Old Jul 22, 2006 | 11:09 PM
drigo's Avatar
how do you like the 12LEDs ? thinking of getting them instead of the 9LEDs...i have the 9LEDs set up in my interior and love them..i'd like something a little brighter for the license plates...
Old Jul 23, 2006 | 01:35 AM
erok72's Avatar
Team Anthracite Member
Wait... Aren't the reverse lights different from the license plate ones? I know when I swapped mine out, the bulbs weren't interchangeable between these two locations.
If I remember correctly, the license plate ones are the same size as the ones in the interior domes, while the reverse lights are larger.
Old Jul 23, 2006 | 09:21 AM
xtin's Avatar
Doctor Sarcasm
they are all the same
Old Jul 24, 2006 | 02:07 AM
vtec 6300's Avatar
Took me like almost 2 hours to replace the damn license plate bulbs from the inside for the new TL. Took me 5 minutes for my old '03 3.2TL.
Old Jul 24, 2006 | 08:20 AM
ding069's Avatar
acura-cl.com OG
remove the trunk lid liner and it takes about 5 min.....
Old Jul 24, 2006 | 01:16 PM
Darkcyde024's Avatar
if you buy led's be ready to REPLACE THEM!!!
i had some superbrightled bulbs for my license plate lights and they flickered and went out in about a month. my g/f also has um on her car and they are going bad. this is my second set (had superbright send me replacements) that has gone out. many other members have had this problem too. I really don't think the led's work well in that location. the lights are on for too long and i think they wear out the circuits. they work great in my domes but i went back to normal bulbs in the license plate and haven't looked back! just my
Old Jul 24, 2006 | 01:47 PM
rimz's Avatar
now with four rings
i've had my interior and license plate 9LED lights in for almost two months now and there hasn't been any flickering at all (knock on wood)...like i mentioned up above, i bought them from tec-toyz and they're hyperwhite...and they look sweet...
i haven't taken any pics of my license plate with the lights in yet, only the interior...i plan on doing that soon and will post them as soon as i do...
Old Jul 25, 2006 | 12:01 AM
Acuraboy7's Avatar
Don't jive my 3.5
I like what Lexus had done with their Xeon lic plate lights! anyone know where to get that hook up? I'd do it on my TL
Old Jul 25, 2006 | 12:18 PM
brianp6621's Avatar
Both you and XTIN are technically correct. They ARE different sized bulbs (stock), (the reverse being larger) but they do use the same connector so you can use the same bulbs in each if you want.
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
lland
Oct 4, 2015 04:47 PM
wusty23jd
Sep 24, 2015 11:41 AM
darksky
Sep 5, 2015 03:11 AM
