LED Lights
Old Feb 27, 2015 | 10:13 PM
  #81
CrazyEights's Avatar
So not a sociopath
IMO, these are going to be some of the brightest you can buy, put as big a lens as you want in front of those Samsung 2323's, the Cree XB-D's are still going to produce more light.
http://www.ebay.com/itm/2-Pcs-Cree-XBD-800LM-Super-White-30W-2825-168-W5W-Running-Parking-Led-Lamps-Bulb-/231491573876?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item35e5f91874
Old Feb 27, 2015 | 11:10 PM
  #82
vietxquangstah's Avatar
I remember you recommending those in another thread I created asking for suggested led reverse lights.
I didn't buy those yet because of the price. I found these dt autotech ones for about $12 compared to $25 for the ones you recommended.
Maybe I'll buy them eventually in the future. Your pictures really show how bright they are.
Old Feb 28, 2015 | 05:36 AM
  #83
EddieOnAZ's Avatar
Originally Posted by vietxquangstah
The reason why I bought those is because my brother wanted some for his QX56. After purchasing the first set I realized I ordered the wrong ones and ordered another set soon after. I told myself that if they are brighter than my current VLED one I was going to replace it.
I had CREE style LED reverse lights 3-4 years ago and they sucked. However years ago the CREE reverse lights only consisted of a LED (or 2) behind a glass/plastic projector lens. Output sucked because it shined light straight forward and not at the ground. When reversing at night you want to see what's on the ground near the car, not the color of the house across the street. On my backup camera it showed up as a giant white hotspot in the center of the display. It was useless, you couldn't make anything out.
These new style reverse lights incorporate a projector style lens as well as LEDs shining light 360 degrees around the bulb.
I don't know much about LED chips however I know for sure that you can't judge brightness solely on "the size of the LED" on the bulb. There are other factors that determine the brightness output of the LED chip.
A smaller LED chip can outshine a bigger LED chip even if the power source is the same between the two.
"5050 SMD" chips were known for being very bright (they are pretty big like you mentioned) however I have come across many smaller single LED chips that have the brightness equivalent to 3 or 5 "5050 SMD" chips together.
I have a 08 with a standard backup camera. The reason why I first purchased LED reverse lights (back in 2011) in the first place was to improve images in the back-up camera at night.
My brothers QX56 also has a standard back-up camera and he's getting LED reverse lights for the exact same reason.
Yeah I agree 100%. That's why I said it's a better indicator, not the best. The perfect example of this is the newish 2323 LEDs. They're tiny but apparently they shine like crazy. I haven't had the chance to try them out yet though.
Old Feb 28, 2015 | 07:38 AM
  #84
Waldo's Avatar
2007 Type S
Yes, i understand, am purchasing for same reason. But, i would like to know what works best, without seeing just white light on the camera.
Thanks Al
Old Feb 28, 2015 | 07:39 PM
  #85
So I got around to installing them today. They would NOT fit into my brothers QX56 reverse light housings because the LED bulbs are TOO LONG. When trying to slide the LEDs into the housing, the bulbs would actually hit the plastic lens of the housing so you could not fully seat the bulb to lock it in place.
Instead I installed them on my dads Infiniti EX35. They fit fine. I actually installed one 2323 and one 2538 bulb on each side to compare it. The brightness of both were pretty identical. Looking at the reflection of the light on the wall as well as looking at both the lights directly the brightness of both were similar.
The only difference is the 2323 bulb appeared closer to pure 5k white while the 2538 appeared more 6k white. Other than that, the brightness are identical.
I think I am going to try out those $25 from ebay for my TL instead.
Old Feb 28, 2015 | 08:06 PM
  #86
guitarplayer16's Avatar
Report back, I have the same VLED bulbs as you.
Old Mar 3, 2015 | 09:23 AM
  #87
Waldo's Avatar
2007 Type S
any results or updates
Old Mar 3, 2015 | 11:53 AM
  #88
didn't mean to get you guys hopes up but I'm not planning on buying it anytime soon. Probably in a month or so.
I noticed all these led reverse lights look bright when looking at the reflection off a wall behind the car but they don't light up the ground too well. The brake lights out shine them.
I'll never understand why so many sellers and customers post pictures of led reverse lights will looking at them directly. Of course they are going to appear bright when you take a picture looking directly at the lights.
They should post pictures of the before and after of the light output that hits the ground. That's what matters most
Old Mar 3, 2015 | 12:55 PM
  #89
polobunny's Avatar
Registered Bunny
Arguably, I believe reverse lights aren't meant to illuminate on the ground but directly behind your car. The backup cam should not replace anyone eyes.
Old Mar 3, 2015 | 03:10 PM
  #90
314_04TL's Avatar
Honestly I still have not purchased any LED Lights. Two Reasons 1. its too damn cold to change them out right now. and 2. There are too many to choose from. I feel like if I buy one I will want another. I will say this I do have an AEM V2 on its way along with pre filter and I just received OEM type-s pedals
Old Mar 3, 2015 | 07:14 PM
  #91
You're right about the back up camera shouldn't replace anyone eyes, however I've owned my TL for 4 years and the only time I turned my head around to look back while reversing was the first 2 weeks of owning the car.
I wasnt familiar to using a back up camera. After I got used to it I can honestly say I never completely turn my head to look behind my car while reversing anymore and it's been over 4 years.
The only time I don't use the camera while reversing is when I look at the side view mirrors to see how close my car is to the curb (don't want to curb rash my rims) or to another car/wall (don't want to scratch my car or anyone's car).
I find it very useful to have reverse lights that illuminate a little bit of the sides of the car while backing up at night. It helps you see objects close to the car at night like curbs.
My vled reverse lights gets the job done. They perform very well illuminating images in the camera as well as things directly behind the car. I just want something even more bright but do not want hid reverse lights.
Old Mar 3, 2015 | 07:25 PM
  #92
So not a sociopath
I had nearly forgotten about this thread.
https://acurazine.com/forums/third-generation-tl-2004-2008-93/just-installed-55w-hid-reverse-lights-817380/
C'mon where's your sense of adventure, all the cool kids are doing it.
Old Mar 5, 2015 | 07:22 PM
  #93
CGPAcuraTL3G's Avatar
7th Gear
I purchase some LEDs for my dome, map and trunk light from Diode Dynamics a month ago. I do not regret it!
Old Mar 5, 2015 | 07:52 PM
  #94
Some of his leds are over priced. He charges $14 for one 12 led board. $28 for two boards. Plus $5 for shipping.
http://www.diodedynamics.com/store/l...d-board-12-smd
That's $33 for two 12-led boards.
Seller snb331 on eBay sells the same 12-led board for roughly $5.75 each with shipping. You can buy two for about $11.
http://www.ebay.com/itm/111111515444?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Diode Dynamics charges $4/each for these
http://www.diodedynamics.com/store/2...runk-light-led
For 10 of those it'll cost $40 + $5 shipping. $45 total.
You can buy a 20 pack of the same bulbs from amazon for only $15 with free 2-day shipping via prime. A 10-pack is $10
Amazon.com: OnlyŽ Newest, 20pcs, W5w 194 168 2825 T10 Wedge 5-smd 5050 White High Power Car Lights Bulb,brighter,green Energy, Lower Heat, Eco-friendly,better Quality,longer Life (20pcs - T10 - 5smd): Automotive Amazon.com: OnlyŽ Newest, 20pcs, W5w 194 168 2825 T10 Wedge 5-smd 5050 White High Power Car Lights Bulb,brighter,green Energy, Lower Heat, Eco-friendly,better Quality,longer Life (20pcs - T10 - 5smd): Automotive
Just saying there are other alternatives out there but if you are happy than that's good I guess
Old Mar 18, 2015 | 03:20 PM
  #95
Waldo's Avatar
2007 Type S
how did the led s work out ? or did the wheels fall off this thread.
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
baowheezy
Sep 22, 2015 09:03 PM
Greengecko
Sep 16, 2015 08:19 PM
