LED lights
Old Mar 3, 2012 | 12:21 PM
laosboi504's Avatar
LED lights
Hello fellow acura owners! i bought some led lights to replace my factory license plates ones. The problem is that they one of them only lasted a week. I order mines from ijdmtoy.com. Is there another website that sells longlasting ones? Or how long are led lights suppose to last. It was for an 06 acura tL. I also replaced the interior lights with leds and one always blows out within 6 months or less. Help plzzzzz!!!!!!!
Old Mar 3, 2012 | 12:45 PM
EL PESADO's Avatar
vled.com or https://acurazine.com/forums/3g-tl-photograph-gallery-96/full-led-conversion-kit-super-bright-panel-leds-849269/
Old Mar 3, 2012 | 04:10 PM
CubanLynx84's Avatar
under renovations....
did you check to see if the bulb loosened out of the socket or if the points on the bulb itself are making good contact within the socket. sometimes they move out of place making you think the bulb blew out.
Old Mar 5, 2012 | 10:05 PM
allin's Avatar
I've had the interior and license plate leds from ijdmtoy for about a month with no issues. Check the fitment as previous poster suggested.
Old Mar 5, 2012 | 10:24 PM
acurabum's Avatar
I replace mine after 3 months or so ... do not know why !?!?
Usually , it starts to blink then go out after a week .
Old Mar 5, 2012 | 10:48 PM
LaCostaRacer's Avatar
I would check the fitment as well- the lights blink then go out typically. Sounds like the bulb was barely inserted and the normal closing of the trunk may have caused a bad connection.
I have bought lights from jdmtoy of recent and also superbrightleds and have no issues from either vendor.
Old Mar 5, 2012 | 11:31 PM
guitarplayer16's Avatar
Check out cold cathodes
Or if you want to stick with LEDs, get the 6 SMT angled flank bulb from VLEDs.
Those were pretty bright!
Old Mar 6, 2012 | 01:30 PM
vietxquangstah's Avatar
www.v-leds.com 'nuff said.
Old Mar 6, 2012 | 03:11 PM
jjdrivesajazz's Avatar
www.automationLED.com
Old Mar 7, 2012 | 03:36 PM
North323's Avatar
when you buy these kits, how do you remove the cap of the light? I do not see a screw.
Old Mar 7, 2012 | 05:52 PM
Grab a small flat head screw driver and lightly pry it open. There are plastic tabs that keep it held in place.
Old Mar 7, 2012 | 06:11 PM
swoosh's Avatar
takin care of Business in
my work here is done
GP and VIET !!! you guys are the BOMB !!!
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
baowheezy
Sep 22, 2015 09:03 PM
Greengecko
Sep 16, 2015 08:19 PM
