LED Help
Old Jan 15, 2010 | 11:58 AM
lylen's Avatar
LED Help
Well I want to start changing the interior lightings in my car to like a white or something, but I dont know where to start. Any help?
Old Jan 15, 2010 | 12:01 PM
Izzy-Type-S's Avatar
WOT in the new ATLP V2s!
I got the blue ones & didnt like it. Also, check out the company first mine burned out in 2 weeks.
Old Jan 15, 2010 | 12:21 PM
robchimo's Avatar
i got white led's from superbrightleds.com and i love them. try a search, there are tons of threads about this...
Old Jan 15, 2010 | 05:05 PM
lylen's Avatar
well I kind of don't know how to look for like what type of parts. Also, should I go with a blue or white theme for my interior? I have a tan interior so l I was thinking about white.
Old Jan 15, 2010 | 08:10 PM
robchimo's Avatar
WLED-WHP5 wedge base bulbs. just do a search for "WHP5" on superbrightleds.com and you will find them. i would go with white-looks very clean.
Old Jan 15, 2010 | 08:17 PM
thait's Avatar
I need a car in
i recommend white!
do you want it to be bright? or a accent, or just as bright as oem but white instead? i can help you out if you like
Old Jan 15, 2010 | 08:29 PM
d.d.r's Avatar
5th Gear
how many LED bulbs should i order..and whats the difference between polarized bulb and non polarized bulb?
Old Jan 15, 2010 | 11:15 PM
lylen's Avatar
Originally Posted by thait
i recommend white!
I want it to be bright. if you can help, that'll be cool. thanks.
http://www.superbrightleds.com/cgi-b.../WLED-xHP5.htm
--would these be for like interior lighting like the dome lightings? and i would need four right?
Old Jan 15, 2010 | 11:18 PM
DeathMetal's Avatar
Fearless DIY Guy
The higher the lumen output, the brighter.
Old Jan 15, 2010 | 11:20 PM
lylen's Avatar
no idea what you're talking about. haha :X
the lights on my #8 post will fit on a '06 tl right?
Old Jan 16, 2010 | 06:14 AM
d.d.r's Avatar
5th Gear
will the lights shown in post #8 be bright enough??? i want to put blue
Old Jan 16, 2010 | 06:27 AM
d.d.r's Avatar
5th Gear
will the same bulb shown in post #8 fit in my glove compartment and side door?
Old Jan 16, 2010 | 10:12 AM
robchimo's Avatar
i have those exact lights and yes they are bright enough. they fit in all of the domes as well as the doors. you might even throw them in the license plate lights.
Old Jan 16, 2010 | 10:34 AM
07tl-s6spd's Avatar
Chapter Leader (Central New Jersey)
i use v-leds.....no problems yet with them!
Old Jan 16, 2010 | 10:59 AM
o4Komodo's Avatar
Rev High; Drive Happy
I understand the domes are the same size for the doors...
Is that the same case for the trunk lighting and the license plate?
Old Jan 16, 2010 | 11:03 AM
robchimo's Avatar
yes
Old Jan 16, 2010 | 12:35 PM
lylen's Avatar
Just to make sure, you're saying those lights fits in all the interior lightings? (dome, doors, trunk, etc..) Also, they're not hard to install right?
Old Jan 16, 2010 | 01:04 PM
robchimo's Avatar
thats correct. the only tough ones to install are the license plate. you have to take off the trunk lining. they cant be changed from the exterior. its not hard, just takes time. you might also have some trouble getting the front dome lights out since they are hard to grip. many others, including myself used tape. wrap some tape around the bulb and pull. they come right out, slide in the new ones and your set.
o4Komodo's Avatar
Yeah. They are.
Installation is very easy. The hardest part, I woudl say, is removing the covers without breaking the tabs.
Sometimes the old bulb may be a little stuck... but nothing a lil' elbow grease won't fix!
Old Jan 16, 2010 | 01:25 PM
lylen's Avatar
Originally Posted by o4Komodo
Yeah. They are.
Is there like a "technique" to take out the covers with messing it up?
Old Jan 16, 2010 | 04:46 PM
Trew's Avatar
Front dome covers: put a slim flathead screwdriver at the very front (front of the car) and pry.
Rear dome covers: put a slim flathead screwdriver at the middle of each cover and pry.
Old Jan 16, 2010 | 11:22 PM
lylen's Avatar
thanks. that'll help to not break the tabs right?
Old Jan 16, 2010 | 11:40 PM
AckTL05's Avatar
Former Sponsor
They are pretty flexable. I would not advise you to do this mod when its cold inside the car, the plastic may break.
Old Jan 17, 2010 | 12:18 AM
lylen's Avatar
thanks for the tip. it's starting to getting warmer here. if the plastic do somehow break, how would i replace them?
Old Jan 17, 2010 | 12:54 AM
Trew's Avatar
I should be more clear and say put the screwdriver on the inside of each cover for the rears (middle of light assembly).
Old Jan 17, 2010 | 01:01 AM
wasupdog's Avatar
My Garage not
use a swiss army knife blade to remove the front and rear dome plastic covers. there's no prying. just slip the blade in, push in the locking tab slightly, and the plastic cover falls right off.
Old Jan 17, 2010 | 01:35 AM
AckTL05's Avatar
Former Sponsor
go to an ACURA dealer and get that part. Be careful, you may not be able to buy just that one piece. Its not that hard, just take your time.
Old Jan 17, 2010 | 01:42 PM
lylen's Avatar
Alright thanks guys. Well i just ordered my lights yesterday night. i ordered 4 WLED-WHP5 (white) for my dome lights. i wanna see how good they are before i order more.
Old Jan 17, 2010 | 01:53 PM
lylen's Avatar
Also could someone post show me pictures of the footwell lightings? i think that's what they're called. i want to see how they look in white for the front and back seats. Thanks.
blacktsxwagon
Oct 27, 2015 10:12 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
eastcoastguy
Sep 23, 2015 06:29 AM
