LED DRLs not working!!
I installed LEDs into my DRLs on my TL-S and they arent working. I dont have a DRL light on my dash. Just the lights are turning on. Not sure what it could be before I dive into it. Its been raining for the past few days havent had a chance to look into it yet.
THANKS!!!
THANKS!!!
THANKS!!!
THANKS!!!
Did you use a relay harness? If not i'd suggest doing a search for LED DRL installs on this site,
https://acurazine.com/forums/third-g...nstall-960677/
https://acurazine.com/forums/third-g...8-drls-887865/
Summarizing - your LEDs are 12v and not dimmable (not detecting lower voltage) and your car installation is 12v divided by numer of bulbs in circuit 🙂
That's what the links that @thoiboy provided are about.
did you do the DRL LED harness or just plug and play bulbs? DRL's run on a lower voltage than regular bulbs do when operating, and the car kicks the voltage up when used as high beam.
The DRLs run in series, meaning that each of the two lights take 6V, not 12. If you plug in the first DRL LED, it will light up, until you plug in the second one. Then the total circuit goes from 12V to 6V, and that is not enough voltage to light up both LEDs. Get the harness.
kpsharp929
2G TSX Performance Parts & Modifications
27
12-30-2015 11:23 PM
