LED DRL, Resister Required?
Old Apr 28, 2014 | 09:03 PM
kpsharp929's Avatar
Hello,
Does anyone know that I need to get resister to install LED DRL?
please let me know
based on my research there will be error sign without the resister
in addition, I want to know about this type of bulb's performance
Old Apr 29, 2014 | 06:29 AM
Cu2Suspect's Avatar
No resistor = code on dash and blinking leds
Old Apr 29, 2014 | 07:18 AM
UTAH TSX's Avatar
V leds is the only on who makes a LED that actually puts out light the ones in your post will not light up the road
http://www.vleds.com/bulb-type/dayti...led-bulbs.html
Old Apr 29, 2014 | 12:12 PM
ssjoeboe9's Avatar
ROTAREDOM
Your lights won't blink since it's DRL but you will get a code
DRL is for daytime, you don't need to light up the road. If you just want the white color then these will be fine.
I have 5k LED fog lights with no resistor or code showing. It's perfect for me cause it was plug and play. I never thought the OEM fogs did much anyways so LED was fine for aesthetic purposes.
Old Apr 29, 2014 | 01:32 PM
Cu2Suspect's Avatar
So joe, I have Nokya DRLs and want the LED white because it looks so cleaner ... Don't need to light up the road with my DRLs what do u recommend ?
Old Apr 29, 2014 | 03:38 PM
bagwell's Avatar
2010 TSX
you do realize your DRLs are also the high beam bulb right? as long as you are fine with pretty much losing high beams then go with any bulb you think will be prettiest.
Personally I made my fogs my DRLs...turn on when the car starts!
Old Apr 29, 2014 | 06:43 PM
soupi's Avatar
I noticed that after swapping my DRLS to leds, why is that?
also
was this hard?
Old Apr 29, 2014 | 07:43 PM
bagwell's Avatar
2010 TSX
also
was this hard?
DRL uses the high beam bulb
not hard to make fogs DRL.....I just used this.... http://store.ijdmtoy.com/H8-H10-H11-...ibrate-drl.htm
(the switch doesn't work well tho, I just cut it out and its wired directly to a power source)
Old Apr 29, 2014 | 08:19 PM
kpsharp929's Avatar
I don't expect to light the road with DRL, I just don't want to loose highbeam function on my car..so am I loosing the high beam function if I get those LEDs? I thoght it will keep the high beam features as well
Old Apr 29, 2014 | 09:07 PM
bagwell's Avatar
2010 TSX
Originally Posted by kpsharp929
I just don't want to loose highbeam function on my car..so am I loosing the high beam function if I get those LEDs? I thought it will keep the high beam features as well
yep, if you put in LED as DRL (which is the high beam bulb running at reduced power) your high beam will still function but at a very reduced output level...which was unacceptable to me.
Note: VLEDs makes a "V3 Trition" LED that I never tried for this but its pricey with a lifetime warranty.
Old Apr 30, 2014 | 04:27 AM
JR_Rider's Avatar
I have V3 Triton switchback bulbs as my front sidemarker/turn signals and they are outstanding although they work best for this function. If you are looking for drl/high beam combination that is as bright/brighter than halogen bulbs, look no further than the 2100 lumen/3000 lumen headlight/foglight/drl setup they offer. I have the original version of the 2100 lumen setup and they are terrific. Very white, and very bright. Output is better than the original bulbs and even nokya hyper white bulbs. They now also have a 3000 lumen setup but it's $200. I may upgrade to that setup at and move the 2100 lumen system down to the foglights.
Old Apr 30, 2014 | 06:42 AM
ceb's Avatar
ceb
Being able to light up the road in front of your car is way overrated. Just go with the cool bling factor.
One day these guys will grow up (unless they've crashed and burned) and say "wtf did I do that for?"
As far as fogs are concerned (from a different post), the fogs on the TSX are some of the best designed and work exactly as intended. They only "don't do much" if you don't understand what a fog light is supposed to do. If you do understand the role of fogs then you also know why it isn't a good idea to leave them on all the time.
Old Apr 30, 2014 | 06:51 AM
Cu2Suspect's Avatar
Well I don't really use my high beams since I live in the city and are useless...to me... Only use em on the high way to flash ppl to get the Fu*k outta my way
Old Apr 30, 2014 | 12:01 PM
bagwell's Avatar
2010 TSX
....or when people cut right in front of me...so I can't do without my high beams.
Old Apr 30, 2014 | 01:01 PM
UTAH TSX's Avatar
UHHH old people
Old Apr 30, 2014 | 03:03 PM
ceb's Avatar
ceb
They don't do periodic inspections in your locale?
Old May 1, 2014 | 07:41 AM
Cu2Suspect's Avatar
We have an anual inspection here in NY... Never seen them check high beams... Even if they did I know they guy... Wouldn't busy my chops
Old Sep 5, 2014 | 03:40 PM
krilla929's Avatar
5th Gear
For the price and time factor I would definitely get the resistors. As far as not being able to have functional high beams. My oem hid's are brighter than my high beams, cuts right through it. I got the 68led ones with the resistors on eBay for like 30. Been 6 months no problems whatsoever. When you use your brights out does get a bit brighter but it looks good.
Old Nov 29, 2015 | 01:46 AM
melojose94's Avatar
Hello,
please let me know
Yes
Old Nov 30, 2015 | 11:38 AM
soupi's Avatar
I a led bulb similar to the one above, but the high beam output is shit, what do you guys recommend for white LED DRL, but has a decent Highbeam output when used?
Old Nov 30, 2015 | 05:31 PM
26Shaun's Avatar
I use these. They are plug and play, i.e., you don't get any error or "codes" when they are running as the DRLs and they are insanely bright as high beams. Be wary they are discontinued now though and once their stock runs out they won't be sold any longer.
Old Dec 1, 2015 | 09:40 AM
soupi's Avatar
did you know resistors for these and can you post pictures of your car with these DRL's ... thanks
Old Dec 3, 2015 | 11:22 AM
opboarding's Avatar
Hello World
robpp bought ones that had a decent high beam output:
https://acurazine.com/forums/second-...-850242/page9/
Old Dec 3, 2015 | 02:52 PM
26Shaun's Avatar
No resistor required, they really are plug and play. Sorry for the bad pic, it's really difficult to get the true color/output captured with a camera. Notice the high beam/DRL is whiter than the low-beam HID though.
Old Dec 4, 2015 | 10:19 AM
soupi's Avatar
Thanks for the picture, aslong as they do the job at outputting a good high beam result at night time I will buy...
Also did you choose 3000k or 5500K? which one is better?
I bought this CREE High Power 9005 LED Lights For High Beam Daytime Running Lights for my DRL and the highbeam output is HORRIBLE!
Old Dec 5, 2015 | 08:42 AM
26Shaun's Avatar
I bought the 5500k as it would have a whiter look than the 3000k.
Old Dec 29, 2015 | 07:33 PM
avarela86's Avatar
So the general consensus seems to be that the VLEDS if you want a usable high and low beam for the DRL to get their 9007 LMZ PLATINUM ULTRA OUTPUT HIGH/LOW LED HEADLIGHTS - 9004 9007 - Headlights - Shop Bulb Type
Old Dec 30, 2015 | 11:23 PM
KillerG's Avatar
Op is too busy to care
^Not for use in high//low DRL applications listed on bottom of page but they look nice and im curious if anyones ever tried them in that application. Maybe some of the accord guys
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
eastcoastguy
Sep 23, 2015 06:29 AM
