iJdmtoy DRL stopped working properly
Old Jun 29, 2014 | 12:53 PM
intel_908's Avatar
Unhappy iJdmtoy DRL stopped working properly
My ijdmtoy led drl were working well for more than a month since a few days ago they stopped working. Yesterday when my car was parking at night, i noticed a few led in the drl led tower were on while the car was off!
The fuse on the wiring is fine. Do you guys have any clues of what that could be?
Thanks a lot!
Old Jun 29, 2014 | 01:14 PM
guitarplayer16's Avatar
Check the relay
Also I would get new bulbs. The tower LEDs usually have problems.
Old Jun 29, 2014 | 09:43 PM
paperboy42190's Avatar
if a few leds are off then its a problem with the led for sure. the tower smd leds are known to be problematic. I had the ijdmtoy ones too but they also started dying so I got new drl leds
Old Jun 30, 2014 | 12:15 PM
tj19855's Avatar
2007 TL
Those are cheap led towers upgrade to vleds, same thing happened to me. Check out my post. https://acurazine.com/forums/3g-tl-2004-2008-93/regret-buying-ijdmtoy-led-drl-blinkers-switchback-912716/
Old Jun 30, 2014 | 01:24 PM
mvp2765's Avatar
Also check the positive connection on the battery. I recently had some acid build up around my positive terminal connections that blocked the electrical current from getting to the lights. I cleaned around the connection with a wire brush and they work now.
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
Fadij
Sep 2, 2015 08:31 PM
