Interior Lighting Question
Old Dec 1, 2011 | 08:17 AM
de1nonly23's Avatar
Been a TL owner for about 3 weeks now and while driving to work this morning I noticed the VSA and the side mirror buttons to the left of the steering wheel do not light up. Is this the way it is suppose to be. Thanks.
Old Dec 1, 2011 | 09:51 AM
carbngrytl's Avatar
No. They are supposed to light up.
Old Dec 1, 2011 | 09:57 AM
SharksBreath's Avatar
BANNED
^what he said.
luckilly, these are easy to replace.
the lights that aren't so easy are the ones behind the radio/nav/etc.
advice...replace ALL the bulbs in the area that you are working in. common problem on TL's and you might as well replace all of them once your in there so you don't have to go back in 6 months and do it again.
Old Dec 1, 2011 | 10:36 AM
de1nonly23's Avatar
Thanks for the input. I will be replacing them tomorrow. I would guess I just pop off the covers and the bulbs will be right there...
Old Dec 1, 2011 | 11:03 AM
DeathMetal's Avatar
Fearless DIY Guy
You will need to remove the drivers side knee panel, which has a small plastic screw to the right. Remove this, then slide the alignment pin slot off; this is located above the pedals. Remove. Then you will need to pull the console cover off...beware, the clips are TIGHT.
There will be 2 or 3 screws retaining the panel.
Old Dec 1, 2011 | 01:21 PM
vietxquangstah's Avatar
oh damn I thought it was normal.. Mines are out, and a friend who has a 07 TL was also out.
deathmetal, do you have any pictures of yours lit up?
Old Dec 1, 2011 | 02:13 PM
DeathMetal's Avatar
Fearless DIY Guy
No close-ups with the foglight switch installed, its in there now, though...
Old Dec 1, 2011 | 06:33 PM
thanks for the pics led master!
Old Dec 2, 2011 | 07:53 AM
de1nonly23's Avatar
Thanks for the pics....
Old Dec 2, 2011 | 05:56 PM
guitarplayer16's Avatar
Yup as stated, they light up.
They're EXTREMELY easy to replace.
Hell, I replaced mine in a damn parking lot when I bought the bulb.
All I did was remove the plastic screw on the right and pulled away the dash (NOT COMPLETELY), just enough to give me room to replace the bulb. Then I push the lower dash panel back in making sure all clips are in. Presto. Done in 5 minutes.
Don't know about the "2-3 retaining screws" mentioned by DeathMetal
Old Dec 2, 2011 | 06:38 PM
carbngrytl's Avatar
Deathmetal... How did you install the LEDs in your door handles like that? I have always wanted to do this but I'm not sure how easy it will be. I just want a nice glow like the footwell ambient lighting is. Thanks!
Old Dec 3, 2011 | 07:53 AM
DeathMetal's Avatar
Fearless DIY Guy
G-100: DIY: LED Lighting For your TL!
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-0-retrofit-oem-bayonet-housings-led-747846/ - Part 0 Retrofit of OE Bayonet Housings with an LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-i-map-light-console-746609/ - Part 1 Map Light Console
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-ii-rear-door-window-switch-w-handle-leds-746947/ - Part 2 Rear Door Window Switch w/ Handle LEDs
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-iii-steering-wheel-leds-audio-cruise-modules-763640/ - Part 3 Steering Wheel LEDs (Audio and Cruise Modules)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-iii-steering-wheel-746972/ - Part 3 Overview
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-iv-center-vents-747870/ - Part 4 Center Vents
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-v-cluster-console-easiest-bunch-747874/ - Part 5 Cluster Console (EASIEST OF THE BUNCH!)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-vi-front-passenger-door-w-rl-door-handle-led-750657/ - Part 6 Front Passenger Door w/ RL Door-Handle LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-vii-front-driver-door-w-rl-door-handle-led-750671/ - Part 7: Front Driver Door w/ RL Door-Handle LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-viii-knee-panel-lights-vsa-mirror-etc-750880/ - Part 8: Knee Panel Lights (VSA, Mirror, etc)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-ix-heated-seat-switches-755070/ - Part 9: Heated Seat Switches
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-x-cupholder-illumination-755388/ - Part 10: Cupholder Illumination!
Old Dec 3, 2011 | 08:06 AM
AUTO Design's Avatar
Former Sponsor
^^^ damn thats awesome!!
Old Dec 3, 2011 | 12:09 PM
~Lefty~'s Avatar
Well damn, you learn something new everyday...my trunk button is out too
Old Dec 3, 2011 | 04:57 PM
carbngrytl's Avatar
Great write up. The doors handle led looks like its a lite brighter than what id like tho. I can see it shining off of the dash. Is there any way to make them dimmer? Maybe a higher resistor?
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
PortlandRL
Sep 14, 2015 12:01 PM
