iJDMtoy Led DRL Harness Install w/Pics
Old 01-07-2015, 03:09 PM
  #361
JLPTL's Avatar
There is a module for non DRL cars, that gives them DRL.
People that have THAT, and people that have cars that COME with DRL...like to run LED bulbs...but they don't work correctly without an LED module.
So...if you have an 05 TL that is not from Canada (where DRL was standard)...then you need 2 modules. One for DRL functionality...and one to be able to run an LED bulb in your DRL location.
Unless IDJM or USR have made one that does both. In which case, I'm wrong.
damn i looked but i dont seem to find the functionality module
Old 01-07-2015, 04:26 PM
  #362
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
If I were you, don't bother buying a DRL module.
Just perform the independent fog light mod and you won't even need to buy the LED harness.
https://acurazine.com/forums/third-g...switch-772633/
The reason why an LED harness is needed is to remove the DRL error on the dash which you DON'T even have since your car didn't come with DRL.
The other reason the LED harness is needed is to provide 12V to the DRLs, opposed to the 6V they receive from the factory. Your fog light bulbs are powered at 12V already, so don't waste your money on the harness.
Just perform the DIY, buy LED 9006 bulbs, and plug and play!
Old 02-11-2015, 07:58 PM
  #363
07 TL-S
UBERTL's Avatar
This is what mine looks like after less than 6 months
Im hoping I can just find a new relay cuz that looks to be the problem...
Old 02-11-2015, 08:07 PM
  #364
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
Happens to cheap LED bulbs exposed to inclement weather and condensation. One of my 20 SMD LED bulbs for my plates looks exactly like that.
Old 02-11-2015, 10:49 PM
  #365
Relays are cheap, 40A, find at any parts store, $3-$5.
Excuse to pick up better bulbs.
This is why I didn't buy iJDMToy's kit. Bought their harness, but bought the bulb elsewhere.
Old 02-12-2015, 12:27 AM
  #366
07 TL-S
UBERTL's Avatar
Yeah, I read somewhere someone was using a higher quality bulb with a single LED that is brighter than this kit but still using the harness. I actually like the output of these bulbs though, not too bright but way better looking than halogen. Perfect for DRLs in my opinion
Old 02-12-2015, 01:29 AM
  #367
Confusing Name Guy
N1h1l1ty's Avatar
Where DID you buy your bulbs GP? I actually got the JDMtoy harness and a set of bulbs and *shock and awe* the bulbs were DOA. Bummer
Old 08-18-2016, 10:21 PM
  #368
KJ TL-S's Avatar
Well, after about 4 years, my kit seems to have kicked the bucket. Got the DRL light yesterday in the dash, and both lights were off. Tried cleaning some corrosion off the terminals, but to no avail. Guess I'll need to revisit what to get and how to install it.
Old 08-19-2016, 09:18 AM
  #369
under renovations....
CubanLynx84's Avatar
my ijdm harness did that same thing with the relay burning out like that. I just had bought it too earlier this year. it must be a bad batch or they did something different with the design. I've tried both the vleds harness and the ijdm one and the ijdm one was the only one that would work for my.
Old 08-19-2016, 09:27 AM
  #370
KJ TL-S's Avatar
I was looking at the VLED one, but you had trouble with it? Earlier comments made it sound like it was a higher quality. This one lasted me a good long time, but I can't tell if it has changed now. In the listing, I only see one resistor for some reason, and people seem to be saying that their kits don't look exactly what what Chip posted up in the first post, which is what I followed way back then.
Old 08-19-2016, 10:54 PM
  #371
KJ TL-S's Avatar
Well, now I'm confused. On the way home from work, same thing with the dash light and no DRLs. Then I stopped at the store, and when I started it up to go home, the lights were on and no dash light, stayed that way the whole way home. Any ideas on why they could sporadically not work?
Old 08-25-2016, 08:48 AM
  #372
Received 8,675 Likes on 6,693 Posts
the relays are going bad
KJ TL-S (08-26-2016)
Old 08-26-2016, 09:59 AM
  #373
KJ TL-S's Avatar
Thanks. I guess that's what I'll address when I need to. As it is, I haven't had a problem in a week now. Not sure what the deal is, but I guess i'll leave well enough alone, and if it starts happening again, then I'll know what to do.
Old 08-27-2016, 04:14 AM
  #374
Zeroden's Avatar
Ayyyyyy!! I just picked some of these up for myself. I think they look alright in my opinion. I hope you like them, and thanks for the installation guide!
Old 08-29-2016, 04:02 PM
  #375
the older version of the ijdmtoy harness lasted a long time but this new one lasted not even a month. the relay kept popping within minutes of changing them. The vleds one has 2 relays on it and one of them blew out too. the vled kit looks of better quality but for some reason it just doesn't hold up
Old 02-12-2017, 07:57 PM
  #376
JDM96specCTR's Avatar
bringing back an old thread, but does anyone know if the canbus led's will work without a harness in the DRL's? im not concerned with a bright output really, im fine with them being dimmed like the oem drl's, i just want the color difference honestly.
Old 06-28-2017, 04:51 PM
  #377
6th Gear
CurtisJack's Avatar
Having an issue with this harness. Drivers side LED is always on, but passenger side cuts in and out. Seems like if I just tap the relay the passenger side will pop on but it won't stay on. Double checked ground and the rest of the connections and they are solid. Relay going bad? Any other ideas?
Old 06-28-2017, 05:56 PM
  #378
If you tap on the relay and the passenger side comes on, change out the relay - they're cheap.
CurtisJack (06-29-2017)
Old 06-28-2017, 07:18 PM
  #379
Ceaze's Avatar
can I just use this canbus plug n play for the led drl?
Old 06-28-2017, 08:05 PM
  #380
Send the link to the bulbs
Old 06-28-2017, 09:12 PM
  #381
Ceaze's Avatar
sorry I thought I put it
Amazon Amazon
Old 06-28-2017, 10:25 PM
  #382
Those will work to fix the DRL light on the dash.
However the bulbs won't run full power (12V), they'll still run at 6V which makes them much dimmer. With LEDs, you want it as bright as you can get because in direct sunlight they are harder to see.
The iJDMTOY and VLEDS does two things - gets rid of the error on the dash - and provides 12V full power to the LED bulbs.
Old 07-01-2017, 07:45 PM
  #383
Ceaze's Avatar
Thanks I just bought the ijdmtoys harness
Old 07-02-2017, 04:55 AM
  #384
Honda / Acura Fanboy
ReMiXeDg's Avatar
Is this for the 2005 so you can get drl on your car?
Old 07-02-2017, 11:00 AM
  #385
Ceaze's Avatar
No, it's for my 07 TL-S
Old 07-11-2017, 03:49 PM
  #386
spiel08's Avatar
I personally like the warmth of the normal DRLs, but those do look slick
Old 01-20-2018, 12:30 PM
  #387
nismotypeS's Avatar
Are the DRL bulbs easy to reach without having to remove bumper/headlights on the 07/08 Tl Type S?
Old 01-20-2018, 06:06 PM
  #388
MyGuti's Avatar
yes
Old 05-14-2018, 09:05 PM
  #389
El Hefe's Avatar
After hours of research I bought lucenta leds with the harness from endlessrpm. Now I’m having trouble
during the install. I can’t get either of the bulbs to light up. When I tried without the harness and direct plug and play only 1 side would light up (to make sure the bulbs worked). How to I get it work without any issues?
Old 05-14-2018, 10:02 PM
  #390
There are 2 possibilities - for my iJDMToy harness, i had to put flip the bulbs. In order to flip the bulbs I had to cut off the tab on the bulb so it can go in the other way.
The other possibility is that the harness is plugged into the blue connector the wrong way. Verify that the wires are positive to positive on the harness before you switch that around though to avoid blowing a fuse.
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
BoricuaTL
04-08-2016 01:08 PM
Skirmich
09-15-2015 06:41 PM
spiel08
09-07-2015 08:19 PM
Quick Reply: iJDMtoy Led DRL Harness Install w/Pics
