How to reset the airbag light
Old Jun 14, 2019 | 02:20 AM
Abraham Casarez's Avatar
4th Gear
PLEASEE HELP!!!
I have a 2008 acura tl with the airbag light on does anyone here knows how to reset it?
Old Jun 14, 2019 | 07:11 AM
Jackass's Avatar
Assuming this is the salvage titled TL you previously posted about? Guessing you will first need to pull the codes to figure what it is angry about.
Old Jun 14, 2019 | 07:26 AM
TheSauceBoss's Avatar
It could be anything from your seatbelt sensor to a front impact sensor. You won't know until you read the code it's throwing.
Old Jun 14, 2019 | 05:00 PM
peter6's Avatar
Were airbags deployed? If yes then you will need to send the airbag module to somebody that can reset it.
If not then it might be bad sensor, but you will need "powerful" scanner that can read airbag codes. $10 ebay Bluetooth brick won't do.
Billu99tl
2G TSX Problems & Fixes
May 26, 2016 03:26 AM
Rdub81
Aug 11, 2013 07:56 AM
DeathMetal
Jun 1, 2010 12:22 AM
