How Bad is This?
Old Apr 13, 2011 | 08:25 PM
jmr4152's Avatar
Angry How Bad is This?
So I buy a 05 TL yesterday out of state. Check the fluid before I bought it before I purchase it. Fluid was perfectly pink/red. The problem is I did not check the level because I was not real sure the procedure to check it...running, not running, in neutral, ect.
I check the procedure today and do the correct check and it is about 3/4ths of an inch up past the full marker. I drive it 200 miles yesterday and 40 today. I am hoping the dealer changed it right before I bought it. I have parked it until I can find fluid to replace it when I drain it.
Question...how bad is this? Fluid still looks good and seems to change gears ok. Fluid is not foamy. I am freaking out.
Thanks in advance.
Old Apr 14, 2011 | 05:58 AM
Turbonut's Avatar
It will be fine as it wasn't aerated, so just drain or suck some of the excess out. Looks like the dealer or someone recently changed the fluid or it wouldn't be red in color.
Old Apr 14, 2011 | 06:03 AM
jmr4152's Avatar
I think I will try to get it sucked out. I have visioned in my head a big syringe the a hose at the end. I feel like I have seen one somewhere...I just don't remember where.
Old Apr 14, 2011 | 08:23 AM
VQPower37's Avatar
u will be fine ... a little extra shouldnt cause you any problem ... sucking it out would be more accurate than trying to drain it from the bottom
Old Apr 14, 2011 | 08:41 AM
nfnsquared's Avatar
Large syringe used to mix oil/gas for 2-stroke engines. WallyWorld near the gas cans.
Turkey baster.
Old Apr 14, 2011 | 12:29 PM
MofroS's Avatar
Saysdamnalot
Turkey baster.
Sorry folks, Wally World is closed for 2 weeks for repairs.
Old Apr 14, 2011 | 03:08 PM
jmr4152's Avatar
Turkey baster.
http://www.walmart.com/ip/Mainstays-...ector/14964956
I am using the above "Flavor Injector" with a fish tank hose. Working pretty well so far. Don't think I would want to use as a substitute for a drain and fill.
Old Apr 14, 2011 | 11:39 PM
BukvaMan's Avatar
why not change the oil completely to the one you prefer and keep going on frome there.... Just for the peace of mind. whats another 50 bucks.
Old Apr 15, 2011 | 08:23 AM
Comptechtl2367's Avatar
^Thats what I was thinking! Why not just drain and then refill with the propper amount. Screw the sucking it crap.
Old Apr 15, 2011 | 09:19 AM
jmr4152's Avatar
Lazy (which it probably took more of my time), and did not want to drop $30 in trans fluid for Mobile1 when I want to put Redline in it. No Redline dealers in my area so I had to order it online and did not want to drive it while it was on order.
Old Apr 15, 2011 | 07:44 PM
07tl-s6spd's Avatar
Chapter Leader (Central New Jersey)
I agree...I would just drain and refill with fluid of my choice
Old Apr 15, 2011 | 08:22 PM
I hate cars's Avatar
Good fluid choice. As long as it shifts ok, no need to worry. The worst that would happen is leaks around the axle seals and you would have noticed that by now.
hrothgar02
Nov 2, 2015 01:29 PM
eastcoastguy
Oct 29, 2015 03:00 PM
Timmy18
Oct 17, 2015 03:58 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
hrothgar02
Sep 28, 2015 11:08 AM
