Hit curb @ 25MPH! Car undrivable. What could be damaged?
Old Nov 12, 2006 | 12:24 PM
Actuary's Avatar
18,000mi. 29000km
Angry Hit curb @ 25MPH! Car undrivable. What could be damaged?
So last night I was coming near an 90 degree turn and slowed down but obviosuly not enough because road was full of ICE.
In that split second I thought about it and instead of going over the curb and risking front bumper and airbag deployment, I manged to take hit on front right wheel at an near zeero AOA(angle of attack) to curb.
Car got undrivable as it started making metalic scraping noise and now I'm waiting for dealer to open on Tuesday.
What could be damaged and what should I expect? Is it going to be bent wheel, new tire, drive shaft or suspension? could roter be bent?
Old Nov 12, 2006 | 12:27 PM
Fulani has a TL's Avatar
Have a feeling that if you hit the curb when your tire was parallel with it, there is something wrong with the axle or something. Give us an update whenever you find out what it is, because I am curious
Old Nov 12, 2006 | 12:47 PM
subinf's Avatar
One on the right for me
Some guy in car talk hit a curb in his TSX and messed up a bunch of suspension stuff. His entire wheel moved back a few inches. Post some pics if you have the chance.
Old Nov 12, 2006 | 01:02 PM
csmeance's Avatar
But luckily, he didn't have any frame damage. Post pics and we can help u out more.
Old Nov 12, 2006 | 01:03 PM
trancemission's Avatar
Regions Leader
Man that doesnt sound good. Theres really no way to tell till you get it on a lift. Im sure you bent a bunch of shit under there. Curbs are the worst.
Old Nov 12, 2006 | 01:04 PM
bhelsdon's Avatar
25mph is pretty fast and can cause alot of damage.
Bent wheel
bent upper/ lower control arms.
injured wheel bearing( This one will probably show up a few months after the initial repair, it will sound alot like an airplane propellor)
bent axle.
bent inner tie rod.
damaged outer tie rod.
and worst case would be a bent engine cradle.
I hope for your sake you were not going that fast and didn't hit the curb square on.
Old Nov 12, 2006 | 01:34 PM
jackasswhy's Avatar
i did that in my bmw once and the damage was bad.... struts, axle, control arm, tie rod
Old Nov 12, 2006 | 03:24 PM
SouthernBoy's Avatar
Registered Member
Add to the list;
Damage CV joint.
Wheel bearings.
Possible transaxle damage.
This is one of the primary negatives with FWD cars. The amount of potential damage to expensive components with a FWD car is quite a bit more than that of a RWD car in a situation such as yours.
Hopefully, your damage will turn out to be less.
Old Nov 12, 2006 | 03:35 PM
TheAcAvenger's Avatar
that metallic scraping noise is a cracked strut
Old Nov 12, 2006 | 08:17 PM
KJSmitty's Avatar
WDP Director of R & D
Actually,,, that noise could be a number of things. Given the hit and proximity of brake components etc., my immediate guess would be a definite bent rim hitting the caliper....
Any oil leaks associated with the right side hit?? Hopefully it didn't bend the lower control arm enough to interfere with the oil filter/adapter plate..
Bottom line, with an inevitable hit with a curb like you described you should have attempted to turn to the right to hit with the wheel perpendicular to the curb. IE - an attempt to drive over it. I would much rather have body/bumper etc. damage vs frame, suspension, and trans axle+..... A wheel hit usually wouldn't deploy the airbag unless it significantly decreased the forward momentum of the car, IE "high onset" of G-forces. I've had winter driving moments of the same nature. Best to release the brakes and drive over vs continuing to attempt the stop prior. You could definitely be looking at some significant damage.
Keep us posted
Good luck
Old Nov 12, 2006 | 09:16 PM
FlashG's Avatar
My 04 was stolen and recovered after the thief ran it into a curb. Broken LF wheel + $5000 in suspension parts and the car is as good as new.
Old Nov 12, 2006 | 10:45 PM
alexkcha's Avatar
I actually had something similar happen to me. Instead of ice, i was trying to turn away from a pot hole while driving off of a highway ramp. While turning away from the pot hole, i ended up hittin the curve with the front right tire. The tire was blown and there was damage to the rim. I put on the spare and i noticed the alignment was totally off. Luckily, I didn't hear anything out of the ordinary with the spare on.
Because it was a Sunday, the dearship was closed. I ended up driving to about 4 tire places (Sam's, Pepboys, and some local places...), but none of them carried the Michelins that I had (I forgot exactly what the model is, but it's the stock tire for a 06 with nav.). I went to the dealership the following Monday. They gave me a new tire, balance, and alignment. Luckily, that was all that was needed. The damage to the rim was minimal. You can see a small mark if you're looking for it. The service guy was telling me that the most common problems that arise from these incidents was a broken tie rod or a broken control arm.
With the new tire, balance, and alignment...the total came to about $420.00.
Old Nov 12, 2006 | 11:40 PM
Actuary's Avatar
18,000mi. 29000km
Note: Steering is slightly turned to left so that's not the real issue
Taken with camera phone. Tell me your opniions. Also should I get this done at Acura or say some other place? How about tire? I'd love to able to save it somehow
Old Nov 12, 2006 | 11:48 PM
subinf's Avatar
your cell phone takes good pictures
Old Nov 12, 2006 | 11:57 PM
Actuary's Avatar
18,000mi. 29000km
Here are more information
1. metalic scrape occurs in a pattern (almost sound like once per revolution of wheel)
2. I checked steering and both tires steer fine.
3. I checked doors and hood for any gap changes. Only thing I noticed is bumper on right side has bigger gap. Other panels are fine
4. No oil leakage of any kind
5. No VSA or ABS check light on
Should I get this done at Acura or save some money by going to other shop?
Old Nov 13, 2006 | 04:35 AM
superfloofay's Avatar
I think I would just let the guys at Acura handle the problem..
btw, what kind of phone is that? Those pics are AWESOME coming from a phone.
Old Nov 13, 2006 | 05:39 AM
speedytsx's Avatar
just curious but would your insurance cover that. I had the same thing happen to my tsx, I was making a right turn going way to fast, and before i knew it i had hit the front left hand tire. I was so pissed i got out of the car and my damamage to my rim was just like yours, and as when i got back to the car to drive it my alainment was all screwed. I took it to one of this places over here in Chula Vista and they said that they couldn't fix, but they recomended me go through the insurance company. I just got back from Belize so the week I'm going to see if my insurance will cover it, if not this will have to wait another month before i can get it fixed
Old Nov 13, 2006 | 07:57 AM
CobraGuy's Avatar
There was another thread here a while back from a similar deal that had a cracked wheel. I can't see that in your photos...but I would sure take a good close look before I drove it again.
If you're mechanically inclined and have a good understanding of the suspension in this car, you can take the wheel off and start inspecting things. But you are dealing with some very important safety features here...so if you're not, I would take it to the Acura dealer...or a shop that is familiar with these cars...and have it professionally diagnosed.
Old Nov 13, 2006 | 08:08 AM
jdb8805's Avatar
Do you have a way to lift the car?
If so, lift the front tire you hit off the ground and tell us if you can bump it front to back (does it move) and top to bottom.
Old Nov 13, 2006 | 09:47 AM
Teddybear's Avatar
Subsonic
i had a buddy of mine make a turn.. it was too icy, the car sled sideways... and his passenger side hit the curb. like he basically was sliding sideways, and he hit the curb. that scrued up his suspension, drivetrain (cause it was an A4).
but if its icy for u... and it looks liek u just got some more snow n slush.... y dont u ahve snows?
Old Nov 13, 2006 | 09:55 AM
jdb8805's Avatar
My guess is it will move top to bottom and that plus the scraping sound would lead me to busted wheel bearing.
Old Nov 13, 2006 | 10:07 AM
CometVR4's Avatar
A buddy of mine did that with his Legacy GT...
It broke the rim in half and the wheel came off the car. But by the wheel breaking and coming off it saved some suspension damage. The rear tire didn't break and bent the cross-member.
Old Nov 13, 2006 | 10:28 AM
sixsixfour's Avatar
sounds like a broken shaft or rod to me. similar thing happened to a friend's civic before. it pushed the whole left-side shaft inside towards the engine and broke a lot of expensive things.
Old Nov 13, 2006 | 11:29 AM
Desert_TL's Avatar
Insurnace would cover this damage. However it would be considered a "solo vehicle accident" which the insurnace companies consider even worse than if you rear end someone. Your premiums would probably go through the roof and/or your policy cancelled at the end of the policy term. Call your insurance company and ask them yourself. Just be like "hypothetically speaking, if i hit a curb at a high rate of speed and damaged my wheel and suspension, would it be covered and if so, would my premiums go up and if so, by how much?"
Old Nov 13, 2006 | 01:30 PM
KJSmitty's Avatar
Looking at the pictures that would be my first "self diagnostic" measure as well. From your initial post I figured it was going to look much worse...
Lift the entire front so both wheels are off the ground rotate tires and look for noticeable wobble etc.. I would do the same with right wheel off and on. The rim is most likely bent, the axle and hub assemble could have been compromised as well..
I would definitely have "a" shop look it over. Doesn't necessarily have to be Acura but a dependable and reliable one.
I wouldn't drive it much, never know what could be tearing itself up over an out of round/true item etc..
Good luck
-Nice camera phone
Old Nov 13, 2006 | 03:10 PM
ForeverStock's Avatar
5th Gear
Sorry to hear about the incident but looks like your front tire is bald.
nt
Old Nov 13, 2006 | 03:55 PM
Actuary's Avatar
18,000mi. 29000km
front tires are at 4/32" but I'd like to get this winter out of them. I signed in at the acura this morning. The car has been sitting there for few days but I had to wait until they are open. I told them to please look at it today so they can order parts in and get it fixed sooner. The sooner they look at it, the sooner parts will be here.
Upon close look at this morning, I noticed bottom of wheel is definintely pushed inward. I suspect lower control arm damage for sure. I hope nothing much. There is zero body damage which is good. Labor rate is outragious though, they said $105 an hour. That's like 85-90 bucks US still.
Old Nov 13, 2006 | 06:14 PM
Actuary's Avatar
18,000mi. 29000km
Estimate came in.
1. Wheel disk (rotor?)
2. low arm control (I knew)
3. hub assmebly (can't they replace parts individually?)
4. wheel bearing
5. drive shaft (F*ck)
6. Disc
4 hours of labor
= $2073 + tire and rim = $2800 bucks
sh1t, f*ck crap all I can say.
Considering insurance premium increase for next 5 years, 46 dollars a month. Service advisor told me to go with cash. I need to go look for a student loan at bank now.
Old Nov 13, 2006 | 06:32 PM
DanL's Avatar
Check with your insurance agent first. If this is your first accident and you have no tickets many, if not most, won't increase your rates, especially for something like this.
Old Nov 13, 2006 | 06:45 PM
The Dougler's Avatar
Unofficial Goat
i think if you source out the parts on your own you will be able to bring that price down substantially, from delray acura i managed to find your parts list
1. 42700-SEP-A11 DISK, ALUMINUM WHEEL (17X8JJ) (ENKEI) 2005 TL $221.94
2. 51350-SEP-A00 ARM, R. FR. (LOWER) 2005 TL $113.40
3. 44600-SEP-A01 HUB ASSY., FR. 2005 TL $41.74
4. 44300-SDA-A52 BEARING ASSY., FR. HUB (NSK) 2005 TL $54.20
5. 44305-SEP-A01 DRIVESHAFT ASSY., R. 2005 TL $154.62
6. Disk is a little vague so im assuming the brake disk the price is for 2 45251-SEP-A51 DISK, FR. BRAKE (17") 2 2005 TL $124.48
Grand total: 710.72 USD +shipping approximately 80bucks call it an even 800+ exchange rate @1.12=896 plus labour 4 hours @ 105CAD= 420+896=1316 A DAMN LOT OF SAVINGS!!! I would go this route if i were in your situation, the only downside is it will take a few days longer to get all your parts. Goodluck!
Old Nov 13, 2006 | 08:05 PM
neuronbob's Avatar
Dang, my worst fear in winter driving is exactly this situation. With aluminum control arms, this sort of damage is inevitable in a curb accident.
Good luck to you, Actuary!
Old Nov 13, 2006 | 08:36 PM
subinf's Avatar
x2.
If you don't mind the wait, get your own parts. Also call around to see if there are any independent shops that have a lower labor rate. I'm guessing you had the dealer quote you the labor? They are usually the most expensive because they think they are all high and mighty and are second to none, which is pretty much bull shit. Find a shop, bring your parts, fix car for a lot less.
Old Nov 13, 2006 | 10:46 PM
gqchicago's Avatar
5mins2disney.com
Any local body shop should be able to do this repair..something like this is a piece of cake for them considering how mangled many of the cars they work on come in!! You might even get a better repair job to be honest...body shops are the BEST at doing alignments...
Old Nov 14, 2006 | 12:03 AM
KatyTL's Avatar
Are you kidding? All 4 of my wheels look like this if not worse and I have NO problems. I hit curbs I would say at LEAST 3 times a week going between 30-50 mph in the city. What the hell - I have yet to have any problems other than some now ugly rims.
P.S. I'm totally aware I can not drive For whatever reason I don't watch the road let alone the damn curb.
Old Nov 14, 2006 | 12:12 AM
subinf's Avatar
holy crap
Old Nov 14, 2006 | 12:39 AM
datmrman's Avatar
Sorry to hear about the incident Actuary.
Good luck with the repairs! Thats a whole lotta money!
Old Nov 14, 2006 | 10:39 AM
Teddybear's Avatar
Subsonic
maybe u should consider getting a SMALLER car... sicn u cant drive.. or mayb invest in some driving lessons... (i have this urge to take ur car away from u if u continue punishing ur TL... what did it ever do to u!?!?!)
Old Nov 14, 2006 | 02:44 PM
alexkcha's Avatar
I know I'm not the best driver out there...you can even see by my previous post with busting my own tire. I've probably hit the curve a couple times in my 10 years of driving, but damn...atleast 3 times a week going 30-50 mph?
Old Nov 14, 2006 | 03:29 PM
Actuary's Avatar
18,000mi. 29000km
I have update on quote.
So I went to Acura and negotiated.
CDN$1294.61 = ($1050 US)
I will have to pay for "express" delivery which Acura promised to have parts in by tomorrow so I can get the car back before the weekend and my parents find out about it. Labor is still at 4 hours @ 105 which means grand total will be $1817 tax incl, + 4 set of tires (1000 bucks).
51210-SEP-A11 Knuckle, R. FR.
44305-SDB-A00 DRIVESHAFT ASSY., R.
45251-SEP-A11 DISK, FR. BRAKE (17")
Old Nov 14, 2006 | 05:56 PM
kart69's Avatar
Why 4 SETS of tires? I assume you mean a set of 4 tires.
Why do you need 4 tires? Did they ALL get damaged, or just the right front?
What does you parents have to do with it? Dont tell me your Mommy bought the TL for you.
Just kidding, I wish I had someone that bought me a TL.
