HID Kit HELPP!!
HID Kit HELPP!!
I am having difficulty with my headlights and ballasts. I was wondering if anyone went the route to do an aftermarket HID kit instead of getting OEM replacement parts. Please let me know what kit you went with and what it included. Also please let me know where i can get these kits and how much. Also le me know if it would be easier to just get oem parts. Thank you
it wasnt a matter of switching oem for aftermarket. I am having trouble with the lights in general. When i twist the switch most of the time only one light goes on. Then i turn it off and do it again and the other one comes on. then i keep repaeting this and sometimes ill get them both and other times none will come on. Also sometimes the one light flickers when it comes on or when im driving it will flicker and go out. Any help would be great.
i have the stock kit on it right now. i didnt change anything out yet. thats why im trying to decide if its easier to go aftermarket or OEM and which will benefit me more.
NO i did all the research i needed to. Plain and simple i dont have fog lights. i have the stock OEM hid lights in it now that are acting up. i was seeing if itd be cheaper or easier to go with an aftermarket hid set up for the headlights or stick to oem parts.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Stick with OEM parts to fix your OEM HID headlight issues.
Being an Acha Bacha in
Sounds like a bulb issue... can you please describe your problem in more detail? Is the problem of failure to light up restricted to one side or does it happen radomly on both sides? Does it come back on if you turn it off and then back on? How long does it stay on after you have it on?
Reason why people are advising you not to go aftermarket is becuase its not smart to replace your OEM ballasts with aftermarket cheap junk. If you elaborate your problem a little more I'm sure I can help you a bit more and so can the other guys on here.
I will also tell you this... 95% of the time OEM HID lights are acting up, it can be traced back to the bulb... only 5% of the time is it the ballast, because OEM ballasts are made of the highest quality.
I already switched bulbs and still didn't come on. It's not the bulb. The fog on that side won't come on either. My guess is ignitor.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
