Help with replacing front passenger side window
Old Dec 8, 2012 | 11:44 PM
NC916's Avatar
Hey guys so some jack ass broke into my parents 08 Mercedes bens GL 450 and shattered the glass. I was wondering if anyone know any DIY to replacing the glass and would it be same as changing it on a TL? Searched all over the web and no luck for DIY for GL. So I'm asking if anyone can help a fellow out, thanks in advance.
Would rather do it myself then pay dealership $1000+(thats what they quote me) in parts and labor when the side window is $200 and pillars probably $150.
Old Dec 9, 2012 | 01:12 AM
4drviper's Avatar
1. try indy mercedes specialist shops.
2. as far as i know there's no "special" way of moving the window up and down.
and this is how i would do it if i were you.
a. study the interior clips of the same generation's other mercedes models (C, E, those popular ones gotta have some sort of interior-teardown DIY)
b. study how the bottom half of the window looks like (probably not much different from ford focus)
c. figure out as-you-go and if you could post in-progress pictures i'm sure benzworld people can help you out.
Old Dec 9, 2012 | 03:20 AM
paperboy42190's Avatar
It's very easy on the TL and other Hondas, I've done it before. Mercedes might be trickier though those cars are always tricky about anything, but who knows. You should probably post this on the Mercedes forums.
Old Dec 9, 2012 | 11:35 AM
NC916's Avatar
yeah I will try taking a look at this and figure it out, I heard there was a metal plate after you take the panel off. so well see how that goes. as for benzworld I tried to sign up but wont let me post or anything and was never confirmed about that site. Tried searching it up on that site also but no luck at all.
Do we have an DIY here havent seen it might check it out and check the steps out, yes mercedes bens are tricky little bastards always have to be complicated hah.
Old Dec 10, 2012 | 12:05 AM
NC916's Avatar
okay i got the panel removed and now im really stuck looking at this big metal plate and dont know where to start, anyone ever took apart a European car panel before? any help on where i should begin?
Old Dec 10, 2012 | 12:33 AM
4drviper's Avatar
pic please?
anyway
i think, i'm guessing but
1. secure the window
2. feel behind the metal plate where the screws are that holds window regulator
3. maybe these might help?
http://www.benzworld.org/forums/w210...placement.html
Old Dec 10, 2012 | 01:30 AM
NC916's Avatar
pic please?
anyway
http://www.youtube.com/watch?v=10PqXN7FZUQ
I wish i have a window to secure its shattered
Thanks for the reply, will post pictures up tomorrow. when i removed the door panel there is this big sheet of metal with 13 bolts and the regulator is attached to the metal sheet. so im guessing if i need to remove the sheet with the regulator i need to remove the 13 bolt and the door lock and unlock module, but where to start?
Old Dec 10, 2012 | 01:33 AM
NC916's Avatar
found this online this is how it looks like when you remove the panel
Old Dec 10, 2012 | 02:51 AM
NC916's Avatar
ah I found a video to remove it, well from a volkswagon jetta. took me hours but it will do thanks for the help and replys though guys, will attempt this tomorrow.
Old Dec 10, 2012 | 03:24 AM
4drviper's Avatar
^ best of the luck to you.
may the DIY god be with you.
Feb 25, 2020 09:57 AM
mike from annapolis
May 7, 2017 08:21 PM
HairyMonkey019
Apr 22, 2016 10:50 PM
Ny1718
Sep 11, 2015 09:21 AM
MyKids&Cars
Sep 1, 2015 12:53 PM
