HELP! Car in tint shop as we speak and they can't get the Moleskin to stick!
Hi Guys (& Gals),
My car is in the tint shop as I write this. They called me few minutes ago to say they cannot get the moleskin to stick to whatever it is they have to stick it to. They said they tried cleaning the part with everything they have in the shop and still cannot get it to stick. They are the best tint shop in my area. Any ideas from anyone here would be appreciated.
Thanks in advance.
Thanks in advance.
AZ Community Team
Received 7,770 Likes
Originally Posted by 08 wdp type s
wat is moleskin ? is that a special kind of tint or something ? i keep hearing about it but dont know wat it is
[/THREADJACK]
OP - if they can't properly clean and/or degrease your weather stripping, I'd question their abilty to do the rest of the job.
there is a DIY in the garage, but I don't think the link works anymore - i haven't checked it recently. in any case its pretty easy to do, just need to pull back the trim and pull off the weather strip or you can remove the entire door panel and do the same
Full of water...
Hi Guys,
The Tint shop called me back. They said they were able to get the Moleskin adhesive to finally stick after some more cleaning. I only had them put it on the front doors, so I will keep tintprotector.com in mind for the back windows if I find a need. I really appreciate all the input from you guys. Thanks!
Check out this thread:
https://acurazine.com/forums/ramblings-12/how-set-up-transactional-web-sites-139437/
UPDATE - Bad News
Well I got my car back the same day and found a scratch on the driver's door tint the very next day. I took it back to the shop and they replaced the driver side door tint as I waited. The weather here has been crappy for the last week so the tint took a while to cure, dry, bond, or what ever it is that it does, but yesterday was hot and sunny all day so the sun beat down on it all day finishing the drying process. So as I walked up to my car after work I noticed two bubble on the driver side passenger door and upon closer inspection I found several other specs of dust and bubble in the tint.
I immediately called up the shop and spoke to the owner. He had me bring the car in for him to inspect. He look at it and then proceeded to try to convince me that was a really good tint job and that I would not find a better one
He seemed like a nice guy so, beside being clueless, I remained civil with him. I point out like a 100 little spots of dust and bubble to him and he still said that was a good tint job
He agreed to redo the doors but not the rear window, which I did not agree to. So we decided to have him remove his lousy tint job and give me back my money, minus the felt strip cost. He is removing my tint as I post this
This place was suppose to be one of the best shops in the area. The guys been tinting windows for 20 years, but I guess he's lost his touch or have had great luck with customers who don't care. I am sure I could have done a better tint job than what I paid him $420 for.
Anyway, I thought I would give you guys an update.
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
![Blink](https://acurazine.com/forums/images/smilies/blink.gif)
Suggestions?
If you want something done right, do it yourself. That is my creed, and I should have known better.
Who here has tinted there own windows and where did you buy your tint?
I have NAV in my car so I will need Non-metallic Tint.
$420 for a tint job? are you serious? Did you get the Huper Optik tint?
Yep, $420, I got the reciept right here. The film Llumar ATX 40% in front, 30% in the rear.
I knew $420 was a little steap, but I was expecting perfection for that price. Boy was I wrong.
Not just another newbie!
Wow, thats expensive. I paid $175 for 35% 3M film all the way around. That sucks about the work quality, if he's the "best", you're screwed.
Originally Posted by flnsx
Tint Protector use’s an adhesive that is similar to Super Glue.
That's why ours lasts and the generic stuff doesn’t.
I purchased Moleskin from Tint Protector and did a DIY on the rear windows AFTER the tint was installed. Cleaned the rubber with alcohol, used sandpaper, let it dry for 45 minutes then installed it. The front windows i had done professionally and they tell me they did the same process as per the instructions in the Ziploc bag i got from you. It was fine for 3 weeks. Now, the weather got very hot and humid and i have 4 windows with glue all over them. I have read on this forum that other people have experienced the same issues with your product.
Now, i have to go back to the tint place and pay $125 for the 4 windows to be retinted...but this time i am using the "moleskin" which the tint place normally uses. You fooled me once with your "my product is superior"---not happening again!
Originally Posted by ajdigerati
Hi Guys,
The Tint shop called me back. They said they were able to get the Moleskin adhesive to finally stick after some more cleaning. I only had them put it on the front doors, so I will keep tintprotector.com in mind for the back windows if I find a need. I really appreciate all the input from you guys. Thanks!![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Originally Posted by deltaboxxx
moleskin is a waste of money.. im from a sandy ass desert and been thru many sand storms (ive even had to get a whole new paint job) and my inside tint is less scratched than my friends type s with moleskin...whoopty doo...not worth the trouble.
Originally Posted by vinnier6
ouch
I wouldnt mind buying flnsx's moleskin and installing it myself, but say if it does come off and ruin my tint..will he cover the cost to get it repaired? Probably not. Since that's the case, I'd rather go to a tinter who installs the moleskin so if it ever does come off or if the tint does get scratched they will replace it all for free (lifetime warranty).
One of mine actually did come off about 2 weeks after the installation, but thats because a little part of the felt got caught to the window when i rolled it down and then when i rolled the window up..the window just pulled it off. The other 3 windows are fine..i roll them up/down a couple of times everyday. Normally, I would be pissed about this, but Steve at Tint Max guarantees his work so I can get it done for free + get a free car wash
hey ajdigerati where are you located? i'm sure other Aziners can recommend good tinters in ur area
OMGosh...you paid $420 for that?!?!?! Dude...i got mine for 150 and it's fine...aside from the scratches, but that's just because I didn't know about the moleskin...
As said before, I too am experiencing the streaking with the "Tint Protector" moleskin. Installed as per instructions and I've got a mess on both front windows! Driver's side is actually starting to come up as I can see it peeking up in the forward corner! Still need to pull the panel and see if I can fix it and prevent anymore mess.
Besides all that, I still got a scratch immediately after having installed the 'skins.
My advice: let the buyer beware. It's awful easy to read a few things on a message board and assume it's gospel. "Tint Protector" paid a fee (I'm assuming) to be an "authorized vendor" here. That doesn't mean their product went through stringent quality control analysis.
Not trying to be a dick, just sharing my personal experience.
King of NYC
+1
One of mine actually did come off about 2 weeks after the installation, but thats because a little part of the felt got caught to the window when i rolled it down and then when i rolled the window up..the window just pulled it off. The other 3 windows are fine..i roll them up/down a couple of times everyday. Normally, I would be pissed about this, but Steve at Tint Max guarantees his work so I can get it done for free + get a free car wash![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I too bought moleskin at 1st with the intention of doing it myself but opted to let Steve do it for me for a $10 extra because it would be covered warranty. I looked at the stuff and it ISN'T as good quality as flnsx's. I just looks to be some regular felt from Michael's arts and crafts or something and I can tell he cut the strips off a big piece of felt, they are not from a roll.....One of mine already came off too but no scratches yet. I don't care, as for me I am covered under Steve's warranty.
I don't think anyone can really 100% guarantee that the moleskin will stick at all temperatures. It's tough to make something peel/stick and self-adhere to rubber. Even if they used 3M adhesive. You will need to supplement the adhesive with some type of liquid glue that will stick to the rubber and have a high melting point. I'm sure home depot would sell an epoxy-like glue that is good for rubber/felt. In order to prepare and reglue an area the surfaces need to be completely recleaned. Use alcohol or even goo-gone if necessary. Sanding as mentioned would help too. After gluing it will need a proper curing time and I think it's good to go.
rockyfeller - "Sanding as mentioned would help too. After gluing it will need a proper curing time and I think it's good to go."
I'm hoping the ol' Gorilla Glue will do the trick!
I'm not using Super Glue; apparently, Tint Protector's adhesive uses the same stuff that's in Super Glue...
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Master Tasker
King of NYC
$420 is absolutely outrageous BTW!!! You seem to be a nice-guy who got run-over!! Someone fed you some mumbo-jumbo.
You can get a top-notch job done for under $250 anywhere in the US. Just be smart and shop around. Some have even done it for $100! See who your friends have used, that way you know for sure. You can see how happy they are and how well their car came out. Don't worry about metallic, I have 3M HP as well with 0 side-effects!
Originally Posted by rockyfeller
+2
Btw..did you end up getting yours fixed? I have yet to do mine..i'm thinking i might get my rear window re-done to 20% because the 30% is just too light..if i do get it done, i'll probably have him fix the felt then. for now though im still driving without the seal in place..not bad but the road noise is getting annoying.
WE have sold thousands of kits. Our Moleskin has lasted for years and years customers cars and my two personal ones as well.
If you sand the weather strip to much the Moleskin can't stick to it. How much did you sand it?
It think it's an installation problem. Either over sanding or using to coarse sandpaper that left deep groves in the plastic of the weather strip.
You should also install the moleskin AFTER the tint is applied.
BLUE07TLS, I had NO intention of "fooling you". I started this company to fix my two cars tint from scratching. I wouldn’t sell it if it didn’t work better than the generic stuff that is out there. I have no seen any other moleskin that works better than mine. Have you tried others? Why knock my product before you tried others? They don’t work AT ALL! Not even for a short period of time.
The TL's door panel is VERY tight. Much tighter than most other cars. The heat and pressure can sometimes cause it to detach under extreme conditions if it was not installed correctly in the first place.
James
James
King of NYC
Mine was off of a roll. Its probably still the same stuff..as you said its not the best, but its always covered so no complaints.
I have 30% too but had my rear done in 20%. Absolutely the perfect darkness. Not too light not too dark, just right.
In the spirit of full disclosure...
Just wanted to point out several things:
- First, I bought Tint Protector moleskins based upon what I thought to be very positive customer feedback
- I received my product in a very timely manner and found it to have fairly comprehensive instructions
- The stuff is sticky as hell! For the life of me, I can't imagine it coming off which is why I'm disappointed at my situation
- I never contacted Tint Protector to seek any sort of assistance. Therefore, I can not say what options I would have been given. Shame on me.
- I'm not bashing Tint Protector, I'm simply saying that, as with any product, things don't always work out perfectly and this has been MY experience. YMMV, etc. etc.
In fairness, wanted to give all aspects of the story.
Yeah mine is not from a roll because it isn't even cut evenly lol. I stuck my hand in there a bit today and half of it is hanging down into the door. It's not bothering me much and rarely anybody sits there, and nowadays even if they do, the window rarely goes down because I ahev the AC on most of the time. I'll just get it done when of these days when I'm in the neighborhood.
I have 30% too but had my rear done in 20%. Absolutely the perfect darkness. Not too light not too dark, just right.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
as for the 20% rear.. you got that? for some reason i was under the impression that you got 30 all around so when i was looking at your pictures, i was like that rear looks good therefore i got 30 all around. looks like i have to dish out another 100 bucks? or so to get it down to 20%
