Heater issues
Old Dec 27, 2022 | 08:56 PM
sujitroy's Avatar
Heater issues
With the AC off, I only seem to get any cabin heat when the temperature is set to HI. Do I need to replace the heater control valve? I see a wire connected to a lever on this valve. I'm assuming this lever should move depending on temp. setting. is this correct?. If so, I will get a helper to adjust the temp. setting while I look it the lever.
Regards, Sujit
Old Dec 29, 2022 | 08:10 PM
BillMFD3's Avatar
Just an FYI
mine went bad and the lever moved.
turned out the shaft to the valve broke inside
Civic-98
Nov 14, 2017 09:21 AM
kkilmer
Oct 21, 2014 07:38 AM
anagramjones
Nov 27, 2013 04:16 PM
flyromeo3
Oct 20, 2011 01:58 PM
slickshoes
Feb 19, 2006 11:05 AM
