Heater issues
Heater issues
With the AC off, I only seem to get any cabin heat when the temperature is set to HI. Do I need to replace the heater control valve? I see a wire connected to a lever on this valve. I'm assuming this lever should move depending on temp. setting. is this correct?. If so, I will get a helper to adjust the temp. setting while I look it the lever.
Regards, Sujit
Regards, Sujit
flyromeo3
10-20-2011 01:58 PM
