View Poll Results: Which grade of gasoline do you use in your TL?
Voters: 173. You may not vote on this poll
Which grade of gasoline do you use?
Realizing the increasing price of gasoline ... Just want to start a poll to see which grade of gasoline most people use on their TL. I am sure the most popular one would be the premium grade 'for now'
... but I can totally see myself use the plus or even regular grade near the end of my lease ... :thefinger
93 in my area is only between 5 and 7 cents more than Plus (89 octane). For 5 to 7 cents a gallon I would rather no loose HP by having the engine computer alter the engine timing to accomodate the lower grade fuel I use.
Using 86 or 87 will nor ruin your motor, so why would you put it in at the end of your lease ?
If you want to save a couple of bucks a month after each full tank of 93 put in a few galllons of reg, the result will be a 90 or 91 octane mix and you may save a bit. Never tried it but it should be ok, since the car requires 91 octane
Hi,
I usually put 50% of 89 and then fill the rest with premium, i have not noticed a significant performance degradation and it saves a bit of money. Although, premium gas is $1.59 where I live, much better than some of the other states.
Originally Posted by berlinrl
Dips009, premium is 1.59 in Philly ? I'm in Pittsburgh and its like 1.80.
What's up with State of PA??
Rachel
Rachel
But, you know, anything to keep my car happy!
We in Northern Orange County, CA. pay in the range of $2.45 - $2.50 for premium now. I expect close to $3 by mid-summer.
It's getting ridiculous...
Stu E.
04 Satin Silver/Ebony 6MT
Stu E.
Originally Posted by automata
And it's 91 octane. Everyone else is getting 93. :rocketwho
Live in Phoenix and use 91 from Sam's Club where I get a much better price on it than with normal gas stations: 209, versus 225 at most regular pumps.
However, a little off-topic I know, but some people have been telling me that the quality of gas that Sam's Club and Costo has is sub-standard. I haven't had any problems with mileage on the car, nor any other problems with the way the car runs when I use this gas. Does anyone have any evidence that their gas is not as good as say 76, or Texaco gas?
Thanks...
Thanks...
I had a friend that worked as a buyer for Wal-Mart / Sam's and he said that basically Wal-Mart buys from the lowest gas distributor. They basically buy the cheapest stuff on the market. He said that quality controls were only as good as the vendor. Basically, you never know what you are getting from them.
Originally Posted by harddrivin1le
Why do you run 93 octane gasoline when 91 octane is the recommended fuel?
BTW I'm not trying to whore the thread, but the lack of knowledge about fuel being displayed in this thread is bothering me and I feel the need to try and educate some of you a bit so you can make more informed, and hopefully better, decesions.
TheNip
Originally Posted by TheNip73
Although I am not EluSiOn, I would like to point out that premium fuel is what is recommended. Premium AKI (also refered to as octane) ratings vary by location for the reason I described above. Chances are Acura used a value of 91 in the manual as the minimum recommend generic value due to the fact that it is most likely the lowest AKI one would find for a premium fuel in the States. Look at your fuel cap. It says PREMIUM. In EluSiOn's area premium is 93. Therefore he or she uses is.
TheNip
TheNip
Fuel octane ratings also vary by BRAND (in the same area). I can buy 91 octane, 92 otane, 93 octane or 94 octane within a 5 mile radius of my home, depending on which station (CITGO, SHELL, MOBIL, SUNOCO, etc) I choose to visit. And in many cases, the same BRAND (e.g. Sunoco) markets the same octane fuel (albeit with location specific chemistry) nationwide.
91 octane fuel is all the TL requires; anything more than that is a waste unless 91 isn't available.
How do you know that 91-92 octane fuel isn't available in that person's area?
As for the TL only neededing 91, believe what you must. I think it needs premium. Whether it be 92 (almost all brands) or 93 (only Holiday that I know of) in MN, or 91 in some areas of the Dakotas and elsewhere, I'm going with whatever the station is selling as their premium gas with their highest AKI value.
The extra 99 cents per fillup is worth it to me.
I didn't say it wasn't availible. It is probally the mid-grade gas.
Period.
If that's the "mid grade" then so be it.
The question of what octane to use is really not an easy question. I live at altitude (lowest point is 5000 ft and my house is at 6000 ft.). At this altitude, they don't even sell anything higher than 91 octane. As someone mentioned already, the reason for higher octane is to limit the combustibility of the fuel to prevent pre-ignition. At higher altitudes, this is not a problem since there is not enough oxygen for this to happen (this also means a reduction in HP). I believe most engines today can detect pre-ignition and compensate for it. However, this does reduce the performance of the engine. I am a firm believer in using what the manufacturer recommends (even if it is overkill). I worry that if I don't, there is a possibility the manufacture will blame the fuel for engine problems and not cover them under warranty. So despite my statements that premium is not needed where I live, I still use it.
Anyone running 93-94 octane in their new TL at an altitude that remotely resembles "sea-level" is throwing money away.
cycdaniel
Dec 17, 2019 10:58 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Rob144
Sep 21, 2015 08:18 AM
