Glove Box rattle sure fix/quick fix
![Wink](https://acurazine.com/forums/images/icons/icon12.gif)
Here's my simple fix for that annoying clicking sound that everyone gets from the glove compartment.
Place 3 slow drops of a strong GLUE (I used Gorilla Glue) into that hole on the right side below where that plastic extension has the screw that everyone says needs to be changed. Let it set overnight in the open positon and you will never hear that rattle again. Mine has been rattle free now for about 5 weeks. Granted , you may never be able to remove that screw again but then who really cares or will need to? Good luck!
Oops! Forgot bout that air filter change although never worried bout that in any other car in the past 36 yrs so I suppose i'll live without changing it. Still rattle free!
Locktite blue,, should hold it and yet be removable when necessary.. Or maybe a drop of silicone bathroom sealant.
Moderator Alumnus
I read here, somewhere, that if the filter gets clogged, the fan will no longer be able to circulate air in the cabin. In that case, you'd want to at least remove the filter if not replace it.
Not to hijack the thread or anything but my doors for the console compartments vibrate/squeak @ certain (low) rpms... Is there an easy fix? Drives me nuts cause the rest of the car is so quiet...
Glove box is good to go though!
oyayjoe
09-12-2015 04:40 PM
3GTLOwns
09-09-2015 09:51 PM
