Fuse help!
Fuse help!
I hope I didn't bite off more than I can chew.
Anyway I went to Best Buy today and bought the X50 and a hardwire kit. The hardwire kit is very confusing and I'm not quite sure what to do. There are two wires, a black and a white one. At the end of both wires are a double pronged piece of metal that fastens into the fuse. However, I don't know which one is power and which one is ground. I DO know that the white wire has a cylinder in it that when opened reveals a glass tube with metal ends. I'm not sure if this means that is the power or ground. Anyway, I would appreciate some help. I need to figure out how to connect the prongs to the fusebox, which one on the left of the other one, and any other info. Thanks
Gale,
Look in here for the hardwire install. How much did you get the x50 for at retail?
http://www.acura-tl.com/forums/showt...light=hardwire
Can someone explain what the ground wire does? I would have thought that it was used to complete the circuit but I guess I am wrong. I am now assuming that it is literally there to ground the power, however I am not sure what I connect it to. It looks just like the connector for the fuse.
Alright I did some research and figured out I have to connect the ground wire to the screw on the frame. I did that, attached the fuse to an open fuse in the fusebox, powered up the car, and it still doesn't work. I'm going to give it another shot tomorrow.
Gale see this post by RoadRage;
http://www.acura-tl.com/forums/showpost.php?p=877592
and his in particular;
http://www.acura-tl.com/forums/showp...2&postcount=26
Ummm ... GaleForce: Why not let Best Buy professionally install it for only $20 - $25 and get a lifetime guarantee on the installation? I'm glad I did.
See my installation here.
Acura604
20
Aug 5, 2017 12:55 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
ripit
Sep 26, 2015 06:19 PM
