Fuel system cleaner
Fuel system cleaner
How often if at all do you guys use this? The ones that come in a little bottle and you pour it into the gas tank and you are suppoesd to run the car for a couple minutes?
BANNED
as long as you run 91-93 grade gas you should never have to use a fuel cleaner.
Ya if you use Top Tier premium fuel there is no need for fuel system cleaner but once in a while is good.
But if you do want to try one, Techron and Redline SI-1 are two of the best, and when I use it I usually put it in before a long trip that way it gets used up in one shot.
never.
I used Techron and Redline SI-1 and gumout with regene. Good stuff help increased my MPG big time before a long trip. Used it every 5k. before the trip 30mpg with gumout ~33mpg drove from merced to LA
Rich and Famous
The only good way to clean a dirty system is open it up replace and sand blast clean.
Ethanol is often what fouls up the system.
A-SPEC 6MT
For years...on all my vehicles I have always run Lube Control LC20 and FP Plus. The LC20 is for the oil and the FP Plus is for the gas. Together, they help burn carbon deposits and lubricate your fuel system. Check out their website here... http://lubecontrol.com/index.php
You can only buy it directly from them. I can't confirm that it actually helps increase your gas mileage, but I like the piece of mind that it is always running through my system helping to lubricate and eliminate water.
SinCityTLX
20
10-19-2015 11:23 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
